Old 08-19-2013, 02:46 PM   #1
spencergt66 OP
Oddometer: 794
Aux Tank Cap
I installed the plastic Aux tank on my 990 a few months back love it but the issue I run into is the fill cap, its a bitch to get on/off like the last trun its running into the pannier rack. Running the KTM gobi racks. is there a different cap I can use or do I need to cut/re weld the rack?
spencergt66 is offline   Reply With Quote
Old 08-19-2013, 07:03 PM   #2
DeepInIt
DeepInIt's Avatar
Oddometer: 1,368
Assuming,yours came with the large Acerbis cap like mine, yes there is a flatter replacement Acerbis cap that will give you a little extra room. I also broke off the tube nipple , drilled out the hole a little and inserted a tire valve. Screw on a tire valve cap with a tiny hole in the side and you have a vented cap that wont spill gas when your bike decides to take a nap. This is flush with the top of the cap which is better than having the tube sticking up.
DeepInIt is offline   Reply With Quote
Old 08-19-2013, 08:48 PM   #3
spencergt66 OP
Oddometer: 794
Well dont have an issue with the tube the corner of the cap hits the support bracket for the pannier rack cap seams pretty tall do you know what type acerbis cap it takes? large or small? I would assume small. I dont need much to get it to clear but its just one of those small annoying things i would like to have fixed
Old 08-19-2013, 09:55 PM   #4
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,145
Solution is to cut the support brackets off (both sides) and swap them, re-weld. This gives you ample space to fill the tank. Let me see if i can find some pics.
edit : here you go. the full thread by a$$hole link
but when i did mine, i left the rack on the bike and took extra care while cutting the brackets off as well as removing the battery / ECU connection while getting the welding done.
'07 KTM Adv990S - Gone, to a good home , '12 KTM 990Adv, '10 KTM 530Exc-Rally
No myriad hues of laser lights, no bottles that are oozing with nectars from heaven, No beautiful body soft and warm to the touch but, i have a very small desire, Give me a dark....long....winding road, three gears to go and my Hellas on fire !!
Vicks screwed with this post 08-19-2013 at 10:09 PM
Vicks is offline   Reply With Quote
Old 08-20-2013, 06:15 AM   #5
Mark.Tate
Oddometer: 24
Hi DeepInIt, Could you post piccies of the Flatter cap and the modifications please? (A part number or link would be FAB)
Mark.Tate is offline   Reply With Quote
Old 08-21-2013, 05:10 PM   #6
spencergt66 OP
Oddometer: 794
no one has a P#?
Times are GMT -7.   It's 05:05 PM.
