Old 08-25-2013, 06:45 AM   #4171
woods wizard
woods wizard's Avatar
Oddometer: 814
The connector will have a locking mechanism that will have to be released. You maybe able to get it out w a very fine jewelers screw driver or a very fine pointed pick. They make tools for pin removal, you may find one @ a auto parts store. Strip back a little until you have undamaged strands of wire , you will need to carefully fold back the connector clamps just enogh to get the damaged wire out . Use heat from soldering iron to get all the old wire & solder off. Put your new wire in the connector , fold the clamps back down & resolder . Dont leave any blobs on the connector or it will not go back in the terminal properly.
Husaberg 570FE Tagged & Tarded / KTM 250 EXC
woods wizard is offline   Reply With Quote
Old 08-27-2013, 01:24 PM   #4172
atk_nut
and atk_nut_wife
atk_nut's Avatar
Oddometer: 597
Oil leak
Anybody ever develop a leak/weep out of the top side of their alternator cover? I got one that is just enough to be annoying.....
If so, What was it? The wire "rubbers"? How did you fix it?
Mine's a 2010 450 by the way...
Teach a kid to ride.
http://members.shaw.ca/fourup
http://vimeo.com/jollyrogerranch
atk_nut is offline   Reply With Quote
Old 08-27-2013, 01:27 PM   #4173
Joe
Debaser
Joe's Avatar
Oddometer: 1,737
Stupid question that I am sorry to ask, I have read through 10 pages or so and haven't come across it yet. I may have a trade going for a 2010 FX450 as partial trade for my SMT. The bike currently has 140 hours and has yet to be apart. The owner seems to be straight up and does all his own maintenance using Moterex etc.
How many hours are you guys seeing without an overhaul? I was kind of thinking at 140 hours it should be due for at least rings?
I am guessing it's impossible to say without a leak down test but I was just looking for some input with those with higher hours/mileage.
Joe is online now   Reply With Quote
Old 08-27-2013, 01:53 PM   #4174
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,470
not sure how many hours are on my 09 450FE but I have no plans to do an overhaul....ever really. engine should be good for 10,000+ miles with general maintenance if not a whole lot more.
Seth S
Seth S is offline   Reply With Quote
Old 08-27-2013, 02:18 PM   #4175
SRG
SRG
SRG's Avatar
Oddometer: 1,259
Joe - I bought a 2010 FX450 w/ 80 hrs. last fall. It's got 155 hrs. on it now. The PO did some enduros, harescrambles, and eventually put a Sicass light kit on it and used it as a dualsport. I've put some bags (Wolfman E-12), Seat Concepts foam and cover, heated grips, a better light bulb (H4), a Kush rear sprocket and a few more things on it. I use it just as a dualsport and it is very nice at that. It ran perfect when I bought it and runs perfect now. I have been changing the oil and filter every 25 hrs. I haven't adjusted the valves or done any other engine work. The idea that it needs any kind of rebuild never crossed my mind - because it doesn't. I don't know when that time will come, but it's a long way off. If the one you are looking at runs nice now and has been maintained well then it's just now broken in and should give many more trouble free miles*
*Judging from my statistical sample of 1.
Best bike I've ever owned.
Lazy Traveler
SRG is online now   Reply With Quote
Old 08-27-2013, 02:38 PM   #4176
B1
Carbon-based bipedal
B1's Avatar
Oddometer: 3,343
the vast majority of owners are getting a lot of miles without rebuilds or even valves moving. i emailed the guy in spain who runs a hire fleet of 70 degree bergs and he did the rings on all his bergs at 15,000km but said there was no need, the engines were all in perfect nick. and his personal FE390 has done 45,000km without any engine work at all. god knows how many hours that would be. more in the threads below...
http://husaberg.org/forum/viewtopic....140222#p140222
http://husaberg.org/forum/viewtopic....144169#p144169
probably the major things to look out for are earlier models could have dodgy fuel pumps, see if it's been replaced. fuel filter mesh was too fine on earlier models and could clog easily. countershaft sprockets can wear prematurely but if it's only ever been ridden offroad then probably nothing to worry about. a detailed list of known issues is here.
free enduro training vids for gumbies here
B1 is offline   Reply With Quote
Old 08-27-2013, 05:16 PM   #4177
Joe
Debaser
Joe's Avatar
Oddometer: 1,737
Good news and thanks for taking the time. Looks like I may have a companion for my 530. My wifes not going to be happy but such is life.
Joe
Old 08-27-2013, 05:22 PM   #4178
SRG
SRG
SRG's Avatar
Oddometer: 1,259
Some additional thoughts on the FX450.
Comes w/ the "competition" map - no need for remapping.
No EPA stuff. The left rear side panel is not full of stuff to remove/block off and because the side panel is different a tool tube/fuel bottle holder will fit behind the panel.
No thermostat to fool with or change. Mine has never overheated (has ceramic coated pipes, FMF can, engine ice coolant and NO fan).
Be aware that the FX has a close ratio gearbox. Mine is geared 13/50 and will go 80 + easy and cruise at 70. First gear is a little high for tight/slow trails w/o slipping the clutch. Once above a crawl, ripping/blipping up and down through the c/r box is bliss.
Did I mention that I really like the bike?
Lazy Traveler
Old 09-02-2013, 11:56 PM   #4179
scorpion
Two arm bandit
scorpion's Avatar
Oddometer: 5,411
Replaced my fuel pump today.
I was wondering did I have the problematic pump?
2011 390fe
Ca-cycle pump on top oem on bottom
also, what's the trick to getting the tank back on correctly?
Been wrestling with the airbox seal
07 KTM 990 11 Husaberg 390
scorpion is offline   Reply With Quote
Old 09-03-2013, 07:48 AM   #4180
FamilyRider
FamilyRider's Avatar
Oddometer: 235
I found that some lubricant like Silcone spray really helps the air box boot slide back into place.
2014 KTM 350 XCF-W
FamilyRider is offline   Reply With Quote
Old 09-03-2013, 11:52 AM   #4181
Hank.SD
Jet Measurer
Hank.SD's Avatar
Oddometer: 1,282
What was the last year for the 70 degree motor? Why did they drop this configuration?
Hank.SD is online now   Reply With Quote
Old 09-03-2013, 12:55 PM   #4182
rensho
Oddometer: 170
2011 USA, 2012 everywhere else.
Bike MSRP was expensive and sold too few and too close to a KTM that was less money. The minor teething problem with the fuel filters and pumps likely didn't help word of mouth sales either.
rensho is offline   Reply With Quote
Old 09-03-2013, 03:21 PM   #4183
bayarearider
Oddometer: 135
Suggestions on how to disconnect the fuel hose from the fuel pump
My fuel pump finally gave up and I took the fuel pump out to replace it with CA cycleworks pump. I am having trouble disconnecting the fuel hose off the fuel pump. Its extremely tight. I read that some people cut it and then re-use the same. Is this correct. I need some suggestions from other inmates who have done this mod.
bayarearider is offline   Reply With Quote
Old 09-03-2013, 04:23 PM   #4184
scorpion
Two arm bandit
scorpion's Avatar
Oddometer: 5,411
I used pliers with a firm grip and a twist.
I figured the old pump was trash anyway. Be careful in not damaging the oem plastic hose.
I'd like to upgrade those hoses at one point.
I also slightly cut the top of the hose vertically to get the new pump on.
Heating it had a minimal effect and I used the included clamp
scorpion screwed with this post 09-03-2013 at 04:32 PM
Old 09-03-2013, 09:19 PM   #4185
Humanbeingexpert
Oddometer: 51
Any contact info for the person in spain? i plan on heading there soon, would be great to hook up a berg...
Humanbeingexpert is offline   Reply With Quote
Times are GMT -7.   It's 09:09 AM.
