Old 09-15-2013, 02:38 AM   #361
Rickrs
It take a 3 to Tango
Rickrs's Avatar
Oddometer: 2
Thumb Back on the road in Mongolia
Hi Guiltyparty,
How's the welded subframe going over the corrugations ?
They'll shake anything to bits. Interesting that in spite of the doom-sayers, a stick welder in the middle of nowhere is better than no welder at all when you need it
Good luck & keep the posts coming.
F650GSD - Just for fun
R100RS - Long distance comfort
Rickrs is offline   Reply With Quote
Old 09-15-2013, 03:37 AM   #362
TheMule
TheMule's Avatar
Oddometer: 403
Just read the whole report, simply incredible! Thank you very much!
"Animadvertuntur in desertis"
TW Goes To Alaska Solo
http://advrider.com/forums/showthrea...ght=utah+tw200
My Bike
http://www.advrider.com/forums/showt...ighlight=tw200 (Sold )
My New Bike (03/09)
2001 Tiger 955i - Fully Farkled
TheMule is offline   Reply With Quote
Old 09-15-2013, 09:12 PM   #363
Grifter
Grifter's Avatar
Oddometer: 40
I agree with you that the dam clocks are a bit of a problem when it comes to water, which is why I just contacted these blokes for a quote:
http://www.liquipel.com/
I figure if it works for iphones and tablets it should work for the Triumph. Great to see you both on the move again, even if you are dodging nutters with shovels!
Stuck on the George Washington Bridge.
Grifter is offline   Reply With Quote
Old 09-15-2013, 11:48 PM   #364
GuiltyParty OP
drifter
GuiltyParty's Avatar
Oddometer: 318
Originally Posted by WIBO View Post
Craig....
Good to check in and get your update.
We're getting orgainized here for another trip to Maroc to ride different pistes well south of Marrakech.
Your pictures of the long gravel roads have whet my appetite for sure so I can't wait to get back!
Still on the XTZ ..I've 20,000kms on it now and so far still pleased with it.
Keep at it and keep safe.
Hey weirdo, I was thinking the other day how the planning for the next EDC to Morocco is coming along. How many misfits have you got going with you?
I've seen a couple of XTC's on this trip and none of them had any problems. A solid bike. I helped a romanian guy get some tube in his wheel hub on his 660 which he said he has to do every 10,000k's.
Originally Posted by Rickrs View Post
Hi Guiltyparty,
No problems at all. We underestimated just how bad some of the corrugations can get and we thought we'd be having trouble with the frame all the way to Ulaanbaatar but it held up fine. Incredible what a decent stick welder can do.
Sounds good for a bit of piece of mind. The silicone I've slapped on it is clear and doesn't show unless you look closely. And it's almost free I'd be relying on the liquipel as a last resort if I missed a spot with the silicone.
Triumph Tiger 800 xc
Walkabout in Russia and Central Asia http://www.advrider.com/forums/showthread.php?t=877576
GuiltyParty is offline   Reply With Quote
Old 09-15-2013, 11:57 PM   #365
GuiltyParty OP
drifter
Oddometer: 318
camp - Ulaanbaatar
The days in Mongolia are a comfortable 22 degrees but during the night the temperature drops to about 2 degrees and always on dusk the winds start. Wrapped up in our all-seasons sleeping bags with the hood covering everything but our nose and mouth we feel the cold. Patty feels it the most and it's causing her rheumatoid arthritis to flare up.
We were camped only 200 metres from the road overlooking Uliastai but nobody bothered us. Elevation 1948 metres.
In the morning we had our favourite cereal for breakfast...baby food We even had fresh fruit and milk from the market in Altai City. Until now our breakfast's have been cereal with water/coffee creamer which tastes like water that looks like milk. It's tasteless so with real milk this was a morning to be excited.
The radiator needed some topping up with about 400ml distilled water.
In Uliastai we tried getting some money out but the three ATM's were out of service, so we decided to try our luck in the next town. We had enough money for one more top-up of petrol
Outside Uliastai they were doing a lot of roadworks, which in more cases than not they're better off not doing because the roadworks sections are generally way worse than the tracks to the side. I've been having some real trouble trying to work out their methods as we bump along deep potholed roads at 30km/h. They mobilise their entire crew and equipment and spend months doing really long sections and getting the roadbase down, grading it and rolling it in prep for asphalt, then demobilise...before the asphalt goes down. By the time next season rolls around the road must be full of massive potholes and corrugations so the crew would need to mobilise again to get it to asphalt phase again. I'm not trying to be critical because having roads in Mongolia is a massive leap forward but mobilising then demobilising before the road is complete seems a massive waste of resource to me...but then again this IS Mongolia.
More often than not we ride the tracks beside the main track, and so do all the locals. They should just keep it as offroad for us bikers
We passed some eagles in a field. I flew past them without a second look because I thought they were sheep until Patty pointed them out...these things are huge! Over to the side and out of the frame a dog is picking meat off a carcass. It's all a bit too far for our lens to capture properly. We're using an 18-55 lens which has been ok so far but for Mongolia it's too small. The distances are so vast and the mountains are normally well off in the distance so the lens has trouble capturing it all. We would be making our way down a winding track in a really scenic valley with mountains on all sides and in those moments I wish I had a lens that could truly capture what the eye was seeing. It would make a great photo that ran the length of a hallway
Watercrossing
I'm now doing them without Patty on the back because we can't risk dropping the bike. I have the waterproof Sidi Adventure boots so I trudge back across and piggy back her across.
With a new bridge going in beside it. They blocked the old bridge before the new one is opened. Why? Because this IS Mongolia. That phrase came up a lot in our travels.
We rode a vast steppe which would get pretty boggy if it rained. We've been very fortunate with the weather so far. In sections the roadworks crew laid deep sand over the mud
Fun
It's impossible to make out in these photos but the Gers (called yurtas in Kyrgyzstan) have solar panels and sattelite dishes. We saw many disassembled gers on the back of trucks along with their sheep being moved to lower ground in prep for the coming winter.
We pulled into Tosontsengel expecting to find a big town with ATM's but there were none, only three banks that were closing. Two people waved us to a place down the street but we couldn't find anything. At the end of the street someone else waved us to the other end of the street so we now understand that's what Mongolians do, even if they don't know where a place is they wave you in some direction. We couldn't leave the town without the money because we needed the petrol and the next town on my map didn't seem big enough to have a bank in it so we had to persist until someone would give us money. A lady in a shop had a card machine and spoke a bit of english so I thought she may be able to help. The conversation went something like this:-
Me: May I use my card in your machine to withdraw some money, I only need 50,000 (enough for two tanks of petrol and food)
lady: No, this is xaan bank
me: Yes that's ok. Can we try? My card works with Xaan bank
lady: No, no try
me: Can you charge me 50,000 for a tin of tuna and give me the change?
lady: No, this is xaan bank. No try.
I empty my pockets and show her I have no money, put on my desperate face and hope she changes her mind. She pretends to be distracted with something else and I walk out empty handed.
Generally speaking that has been the mongol way in our experience. When we've been looking for assistance, even something as simple as asking for toilet paper they pretend they can't hear us or they say "I don't know". Eventually we found a bank that would change our russian rubles for just enough money to get us to the next major town.
We camped about 20km outside Tosontsengel up high enough and in a slight breeze to get away from the mozzies. The pump on our cooking bottle wasn't pressurising the bottle and we couldn't figure out to take it apart so instead of our delicious salami, pasta and chili sauce we ate raw noodles
In the morning we had another crack at trying to fix the pump and found the cap on the end of the plunger was pulling loose so it wasn't pressurising. We couldn't fix it so we had biscuits and the salami for breakfast and rolled out.
This was to be a day of water crossings. We could count at least 4 on our map, but who knows how many other smaller ones there are that flow into the rivers. After our previous episode we were hoping for an uneventful day
We came to a crossing we could only do by truck.
Because the bridge was out of order...
Some were easier than others
For the majority of the day we were following a river in a valley which had streams of various depths flowing into it. In total we did 6 water crossings including the one with the truck. Patty got her feet wet in one of them because we had to walk it across. She wasn't happy about that and couldn't understand why anyone would want to bring their motorbike to a place where you have to cross rivers on a bike. To add injury to insult I dropped the bike straight after walking the bike across and she fell to the ground like a turtle on its back
Coming over a big crest we got to the top and there was a big mud pit at the bottom of it between our crest and the next. I tried brushing off most of our speed before we hit it and I grabbed some front brake and tried turning away from it. You can guess what happened next. I knew what was going to happen before it happened - the front washed out and we took a low speed tumble. Rookie mistake. Better that than going over the bars in the mud though if we got stuck.
This is how I picture Siberia. We had some fun little hill climbs through this section on washed out roads.
Potholes. These were comical because it was like corrugations gone bad. We would be riding along then disappear down a metre hole then pop back up the other side then pop back down again. It's not often you laugh at potholes but we found the funny side to it.
We pulled off the road to look for a spot to camp and found a flat spot in the hills overlooking a lake.
We still couldn't get our cooker working so for dinner it was biscuits and water
We sat and watched as the sun set. By now it's getting too cold to sit outside once the sun goes down so we made a retreat to the tent and our sleeping bags. As night washed over the camp and we rugged ourselves in our sleeping bag in prep for the cold night we were stopped mid-conversation by a noise in the forest behind our tent. We could hear howling, from two animals. We looked at each other and asked 'what is it?'. Wild dogs? Wolves? Are there wolves in these parts because that didn't sound like a dog to me. We took a bit of comfort we were in a tent and we hadn't showered for 4 days - we smelled very human and there was a petrol odour coming from the fuel bladder. I had my tyre lever and light sitting beside the door just in case…not that I could fight a wolf off anyway. We tried our best to sleep through it otherwise we would get too paranoid. I still woke a few times during the night and heard howling and barking in the hills.
We later googled it and they were definitely wolves, gray wolves actually. Scary thought.
We were very happy to see sunrise.
We found a roadside cafe for breakfast and not understanding anything on the menu we picked the first thing she suggested, some type of sheep soup.
In western society we've been drummed that fat is bad and blah blah blah so if we were served this in Oz we probably would have turned our noses up at it. We had to eat. Our biscuit dinner the night before isn't enough to keep energy levels up. It was really nice and we ate it all but our bodies aren't used to so much fat so it sat heavily in our stomachs.
120km from Tsetserleg the slab started...but 6km from Tsetserleg the slab ended and it became gravelly goodness It's difficult getting the back out with so much weight but I could on this so we powered into Tsetserleg with the back hanging out.
Tsetserleg
Riding into Tsetserleg was like stepping into the twilight zone. We were stopped at a checkpoint but instead of being ripped off we were waved through. We stopped at a traffic light...a traffic light?! And traffic police stopped us and checked our documents without demanding money After then the locals were generally nicer and more approachable than they were in the west.
On our travels we had heard about an aussie guesthouse on thea middle route that served bacon and eggs for breakfast. That was the real reason we did the middle route, not because it was the most scenic or anything Fairfield Guesthouse was like an oasis for us. We hadn't eaten properly since our cooker bunged up and we smelled bad and this place cured all that.
We swung by Erdenne Zuu Monastery for some cultural enlightenment.
We were racing a storm and behind us a massive dust storm chased us. It felt very apocalyptic, like a scene from a movie.
Blue sky is quickly disappearing.
Tsetserleg to UB is all paved and we could have made it to UB in one day but we decided to camp about 100km from UB to save some money...away from trees that could be hiding wolves.
Early morning we could see a smoggy haze that could only be Ulaanbaatar. On the outskirts of town there is heavy industry including a coal fired power plant that's causing a lot of the smog. As we rode through I got the impression it was a city struggling to keep pace with its own economic development. Residential suburbia mixed with heavy industry and business district only a short distance away. It was all a bit chaotic and in a mess. Plus the drivers get my vote as the worst ever.
We were happy and relieved we had finally made it to Ulaanbaatar without any hiccups. The frame held up and we had no problems whatsoever with the bike...except a bothersome stepper motor and minus a bolt or two We also had amazing weather which certainly made the trip a lot easier. Even with the dry weather we still went through some mud pits and in some sections if it rained I think we would have seriously struggled. I went through our track logs and interestingly most of our time in Mongolia has been above 1500 metres.
We stayed in Oasis guesthouse which is bit of a mecca for adventurers, normally with broken vehicles we’ve been told.
Our route from camp outside Uliastai to just outside Ulaanbaatar (where I had to delete a track log because the GPS was playing silly buggers)
Now we go north to Lake Baikal
Old 09-16-2013, 02:38 AM   #366
JJBrewbus
Oddometer: 6
Wink
Huh? Really? THIS is not Mongolia.
But seriously -- Great RR; keep it up, guys.
One-wheel drive
JJBrewbus is offline   Reply With Quote
Old 09-16-2013, 09:18 AM   #367
live2ridetahoe
RN
live2ridetahoe's Avatar
Oddometer: 1,466
^^^I like your favorites tab…
Icon's 800XC
AimHi Enduro lights (Are these going on the 800 when you get back?)
But what is that last one? Is it shipping info for Vladivostok to Oz?
JG
live2ridetahoe is offline   Reply With Quote
Old 09-16-2013, 10:49 AM   #368
Hunter-Douglas
rube
Oddometer: 355
Not sure if you're using an MSR Whisperlite stove or something similar, but sometimes the gaskets can unseat themselves or wear through in the pump assembly area. The stove repair kit usually comes with a few gaskets and usually replacing those and making sure the fuel line is seated correctly does the trick.
Love this RR!!
BMW 650gs- A bike named Douglas.
The Fool's Progress: Onward-Upwards-Global on a 650gs
Hunter-Douglas is offline   Reply With Quote
Old 09-16-2013, 01:07 PM   #369
Rango
Phaneropter
Rango's Avatar
Oddometer: 1,198
-Why do you eat ramen raw?
-Because it is Mongolia.
Giving you couple of well deserved thumbs up for the road.
Keep feet dry, head cool.
Moriunt omnes pauci vivunt
Rango is offline   Reply With Quote
Old 09-16-2013, 05:39 PM   #370
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,680
Wow. This is one of the best pictures to explain Mongolia. Do you have any Idea how long the truck has been there? It will probably stay there for a long time.
I made it into japan with out Carnet. Let me know if you two are considering it. I'll give you as much info as I can.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 09-16-2013, 11:30 PM   #371
live2ridetahoe
RN
Oddometer: 1,466
Glad to hear you are in Japan.
Mongolian bridge= FAIL!!
Wish there was a vid of the truck going down. That must have scared the sh*$ out of someone!
JG
Old 09-17-2013, 06:10 PM   #372
riverman
Life is great !
Oddometer: 179
Loving the report. I check in almost every day for updates. I know it is a lot of work for you to keep it up but am sure I am speaking for thousands when I say it is much appreciated. Keep up the good work.
Rory aka "Riverman"
'11 WR250R
'13 Tiger 800XC
riverman is offline   Reply With Quote
Old 09-18-2013, 01:37 AM   #373
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,774
Originally Posted by riverman View Post
loving the report. I check in almost every day for updates. I know it is a lot of work for you to keep it up but am sure i am speaking for thousands when i say it is much appreciated. Keep up the good work.
+1000
2002 black Tiger955i, 72000 miles and counting.
2011 black Tiger800XC, The other British Land Rover. 40000 miles and counting.
2013 black Tiger800XC, The other British Land Rover. 500 miles and counting.
blacktiger is offline   Reply With Quote
Old 09-19-2013, 06:16 AM   #374
squonker
Eat my shorts
squonker's Avatar
Oddometer: 4,026
Fantastic ride report! An amazing adventure, for sure, and your attitudes are spot on despite some serious setbacks that would have had many of us throwing in the towel. Now that I am caught up I look forward to following along as you continue. Oh, and I wouldn't worry about the wolves, it is extremely unlikely that they wouldn't leave you alone.
Ride Report: Canada North to South 2008 here
Drive Report: Ice Road Trucking 2005-2014 here
squonker is offline   Reply With Quote
Old 09-19-2013, 06:54 PM   #375
GuiltyParty OP
drifter
Oddometer: 318
Icon's 800XC
JG
Thinking about it. The lights I have on now are temporary and not bright enough at night and they let water in, so I'll have to spend a bit of time doing it up. The grill will have to go but the Lada badge is definitely going somewhere. All I know is the bike won't be going back to standard
Icons bike looks sick but it's not a practical dirt bike.
You picked it, the last one is shipping details to Oz
Love this RR!!
Thanks mate. The kit came with a replacement jet and o-rings but nothing else, it was just the basic kit. The pump cap was coming loose in the plunger so I tie wired it and lubed it and it's working fine now
We sat there and stared at it awhile thinking WTF? I'd say it's been there awhile judging from the track marks around the ramp on the other side of the river. When I rode over to take a pic the guys on the bridge playing around with the logs said I should chuck a wheelie and just ride over the top of it. Maybe that's what the locals are doing? What I'd love to know is did the guy try jump out to safety or gas it...I reckon he gassed it
Good stuff. We've gone the opposite direction and we're in Moscow now after being on the Trans-Siberian for 4 days. Asia would have been the logical way home but Patty hasn't done some countries in Europe yet so we're backpacking around now.
I still need to catch up on your report man. I've been waiting until I can sit down with a beer and read it properly...the BAM needs this sort of attention
Times are GMT -7.   It's 12:41 PM.
