Old 09-16-2013, 01:20 PM   #3601
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,421
Originally Posted by Addicted View Post
Hmmm. I will have to start using my respirator when I'm doing stainless. Never heard its particularly bad before. I better keep reading this thread!
Hexchrome is typically a plating material on regular steel.
We don't stop riding because we get old, we get old because we stop riding.
"Wisdom is knowing what to do next, Skill is knowing how to do it, and Virtue is doing it"
HellSickle is offline   Reply With Quote
Old 09-16-2013, 03:14 PM   #3602
RAZ1
Airhead fan
Oddometer: 18
What I know about welding is just enough to not try it myself.
I need an attachment pin re-welded on an oilhead muffler. The pin and its bracket appear to be stainless steel. The friend I rely on for welding doesn't have SS-specific equipment. Can the parts be welded using regular rods?
TIS
Originally Posted by KTM640Dakar View Post
Do you have a question about welding? How to weld a material or which welding process to use? MIG, TIG, stick, oxyfuel?
Raz
RAZ1 is offline   Reply With Quote
Old 09-16-2013, 03:38 PM   #3603
David R
I been called a Nut Job..
David R's Avatar
Oddometer: 2,496
TIS
The work I did on my oilhead showed me it was a SS exhaust.
Your friend only needs SS filler. Tig filler, Mig wire, or even SS stick rod.
If you use carbon steel filler, it will rust.
David
2012 R1200R ! 2000 R1100RT (parts for sale!), 1976 R75/6, 2014 Vulcan 900 Trike
There is a seat for everyone.
David R is online now   Reply With Quote
Old 09-16-2013, 05:41 PM   #3604
CodyY
ADVenture Capitalist
CodyY's Avatar
Oddometer: 9,493
TIS
Buy him a small spool of 316 for his trouble
Not an ACTUAL motorcyclist
CodyY is offline   Reply With Quote
Old 09-16-2013, 06:08 PM   #3605
fxstbiluigi
crash test dummy
fxstbiluigi's Avatar
Oddometer: 12,091
You'll need a bottle of 75/25 gas to go along with the wire or if you plan to TIG it you'll need a bottle of argon.
oops.... Tri-mix works too.
The basic question of politics is "Who does what to Whom?". -Vlademir Lenin.
"Politicians are always interested in people.
Not that this is always a virtue.
Fleas are interested in dogs." -P.J.O'Rourke
fxstbiluigi screwed with this post 09-16-2013 at 06:20 PM
fxstbiluigi is online now   Reply With Quote
Old 09-16-2013, 06:38 PM   #3606
Spacelord
Mutha Mutha
Spacelord's Avatar
Oddometer: 872
Ask your WELDING questions here.
Originally Posted by NitroAcres View Post
STOP NOW...Take up a new Hobby/Profession, perhaps something in HealthCare.
Welding is NOT SAFE and NEVER will be 100% Safe...anyone who tells you otherwise is WRONG.
I have been doing it 37+ yrs.
37 years, You should retire and give me that SW and that big table.
"I swear to god that I will beat you senseless with a sanka can before I die"
Spacelord is offline   Reply With Quote
Old 09-16-2013, 07:35 PM   #3607
jules083
jules083's Avatar
Oddometer: 3,889
TIS
Not to knock your friend's skill, but it kind of sounds like he doesn't know how to weld stainless. Unless he has only a MIG welder?
Stainless can be stick welded, best to use either 308 or 309. 308 is for stainless to stainless. 309 is designed for stainless to mild steel, but is also used when you don't know one or both of the materials. Not supposed to do that, but it happens.
If he does have a stick welder and the material is thick enough and he knows what he's doing it's an easy job. If any of the above is lacking go to a weld shop. Material thickness required for stick welding is proportional to skill and experience. Stainless will burn through easier than mild steel and is harder to weld. I've been welding it for a while now and I'd be comfortable as long as one of the pieces is about 1/8" thick. The other one can be thinner as long as there is proper fitup, as the heat can be focused on the thicker side and dragged across. Hard to explain but easy to demonstrate I'm sorry to say.
For TIG welding thickness doesn't matter as long as the welder is skilled. I've TIG welded some fairly thin material, maybe 1/16", and have seen much thinner welded. There's a video on www.weldingtipsandtricks.com where the guy welds 2 razor blades together.
If its MIG, I'm not sure what to tell you. We rarely mig stainless at work, and at home I always stick weld it. The mig we have used at work has always been on thicker stuff when the company doesn't want to spend the time on stick. 1/2"-1" thick kind of stuff, just crank the heat up and run with it. I do know that we always use a different type of gas mixture, which to me seems random because it's rarely the same. Maybe different grades of stainless or something, I don't know.
Edit: just saw the above posts about mig, they are more knowlegeable than me on that aspect. Might be cheaper to pay a shop, argon bottles are expensive considering how much work you actually need done.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
COBDR and UTBDR on my klx250:
http://advrider.com/forums/showthread.php?t=1003485
jules083 is online now   Reply With Quote
Old 09-16-2013, 07:48 PM   #3608
Sparrowhawk
Sparrowhawk's Avatar
Oddometer: 2,203
Hex chrome is dissolved in the electroplating solution used for chroming. The electroplating process converts the hexavalent chromium to metallic chromium. There is no hex chrome in either stainless or plated metal. It takes much energy and a strong oxidizing environment to turn metallic chromium into the hexavalent form. These conditions can be created by arc welding.
http://www.atsdr.cdc.gov/csem/csem.a...7#tocbookmark2
Sent from my SCH-I535 using Tapatalk 2
Sparrowhawk is offline   Reply With Quote
Old 09-16-2013, 09:01 PM   #3609
fxstbiluigi
crash test dummy
Oddometer: 12,091
Depending on the 'type'(alloy) stainless can contain anywhere from 17% to 26% chrome and when welded the vapors from repeated exposure can cause severe neurological damage.
Old 09-16-2013, 10:00 PM   #3610
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 4,247
Hexavalent Chromium (aka; chrome 6 or hex chrome) is the bad chrome and it's fumes are what you should worry about. That being said, "Hex Chrome" is not the major type of chrome found in Stainless Steel or in the fumes created in the welding process. If you really want to know about the potential dangers you need to read up on Chromium and the many different forms it is found in. Beware that you may also might learn the difference between a vapor and a fume.
"I couldn't wait for success, so I went ahead without it."
Strong Bad is online now   Reply With Quote
Old 09-17-2013, 03:58 AM   #3611
NitroAcres
MotoBiggots Suck
NitroAcres's Avatar
Oddometer: 515
Ha~!!!! I am still Learning....and enjoying welding, I just ran that BigGirl last nite on a huge ass Stainless Pump, first time off the Dynasty's in a while..
You should stop by and visit sometime.
(You better be careful..I will put you to work on the SW..)
Britt Lynn
NitroAcres
Ball Ground Ga
NitroAcres screwed with this post 09-18-2013 at 07:35 AM
NitroAcres is offline   Reply With Quote
Old 09-18-2013, 09:01 PM   #3612
fxstbiluigi
crash test dummy
Oddometer: 12,091
the dictionary that I have uses fume and vapor as interchangeable, as well as everything else I've looked at.
Would you be so kind as to point out the difference between the two for the class?
fxstbiluigi screwed with this post 09-18-2013 at 09:07 PM
Old 09-19-2013, 07:03 AM   #3613
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 4,247
No problem:
"A fume is technically a solid. Welding or soldering you deal with fumes; lead, copper, rosin, tin, etc.
A vapor comes from a liquid. Water vapors, gasoline vapors, chlorine vapors, etc.
This comes from Cal-OSHA (California occupations safety and health administration) Hazwoper (Hazardous worker operations) certification course."
Old 09-19-2013, 07:30 AM   #3614
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,407
The difference between fume and vapor determines what type of respirator or personal protection device is suitable. A respirator with only filter media can separate fume particles (provided the filtration is fine enough) but not vapors. Activated charcoal or another method is needed to remove vapors (generally gases).
Having good ventilation goes a long way in removing hazards from welding. For shop work, it's worth the extra effort and trouble to have some fresh air by opening a couple of doors or moving the work. Sometimes that is not possible and a respirator or other device should be used.
Stan_R80/7 is offline   Reply With Quote
Old 09-23-2013, 04:00 PM   #3615
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,447
Currently making suspension mounts for bigger axles under the Landcruiser, obviously it's important that these are done right. These are the 1st with a few to go yet so hit me with any suggestions for improvement
200A TIG, ( Edit, actually 2.4mm 3/32" tungsten, 3mm ~1/8" filler) ER70S6 filler. 4-5-6mm steel.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz screwed with this post 09-23-2013 at 05:08 PM
clintnz is online now   Reply With Quote
Times are GMT -7.   It's 01:11 PM.
