Old 09-16-2013, 09:24 AM   #19831
William42
William42's Avatar
Oddometer: 3,044
Originally Posted by pluric View Post
Probably a little more than normal. I'm going to take up some of the slack and try it.
I don't think that is the issue, but it's worth a shot.
Did you do the air screw adjustment and the throttle body sync?
Mud is evil
William42 is offline   Reply With Quote
Old 09-16-2013, 09:26 AM   #19832
William42
William42's Avatar
Oddometer: 3,044
Originally Posted by fingerlakes_ny View Post
Ok, so you've changed my mind on the skid plate at least. How is the Yamaha crash bar?
I don't know about the Yamaha crash bar but the Altrider crash bar worked fine for me.
Mud is evil
Old 09-16-2013, 09:28 AM   #19833
Thagua
Let's go adventuring...
Thagua's Avatar
Oddometer: 357
Yamaha crash bars
Great if you like children. They always want to play on your bike because
it looks like you have this mounted to it.
Personally I use Altrider sidebars.
Hi Fingerakes, combine both Yamaha lower engine protection and Altrider and you have the best of both. Send the upper Yamaha protection to Pluric for his kids. Regarding sump protection you might try the Krauser which is not bolted to the sump and make a front end mod to grab the guard on the two upper bolts that hold the engine.
Cheers,
Roberto
'Let's go adventuring'
Thagua is offline   Reply With Quote
Old 09-16-2013, 09:29 AM   #19834
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,277
Way back when even before the original reflash. In T mode throttle roll on is smooth as
can be, just wimpy on power. Switch to S mode and the inner beast comes out. Just that
it's very throttle sensitive to minor input.
pluric is online now   Reply With Quote
Old 09-16-2013, 09:34 AM   #19835
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,277
Cheers,
Roberto
Yes, I promised them monkey bars for Christmas.
Old 09-16-2013, 03:07 PM   #19836
BergDonk
BergDonk's Avatar
Oddometer: 3,818
Hey all, going to be getting a new S10 here soon. I want to get crash bars and a skid plate to start for sure. I figured it would be easiest to go with Yamaha parts because I see that some skid plates require aftermarket oil pan parts or something and I don't want to have to deal with a lot of modifications or using special parts. However it seems like most people choose aftermarket stuff like Altrider, SW-motech, and others. Is there anything wrong per se with Yamaha accessories or is it all down to preference? I want quality protection but don't care about being able to say "yeah, I spent $700 on this sweet aftermarket skid plate" When it does the same as anything else! Input appreciated from an ADV bike noob :-)
Lots of good suggestions here and it's ultimately dependant on your use. As others have found though, the Yam stone deflector can result in cracked crankcases if it takes a decent hit.
I have recently gone through a similar process and ended up with AltRider bars and a Hepco Becker plate, plus some other odds and ends. Details are in the link in my sig FWIW.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 09-16-2013, 09:06 PM   #19837
avc8130
Oddometer: 1,625
Cheers,
Roberto
Roberto,
Do you have more info/pics of that Krauser skid plate? It looks pretty cool and I don't think there is much info about them on here.
ac
avc8130 is offline   Reply With Quote
Old 09-16-2013, 10:23 PM   #19838
Old Git Ray
Now retired...YeeHaa
Old Git Ray's Avatar
Oddometer: 1,466
Sod the monkey bars, give them an adventure playground...
Karen "Oh my God, I am traveling with a f**king idiot."
Blog: http://www.raykarenhall.blogspot.com
Old Git Ray is offline   Reply With Quote
Old 09-17-2013, 05:21 AM   #19839
TH
There and Here
TH's Avatar
Oddometer: 912
If you are looking for a combo set up, skid plate and crash bars, the Rumbux setup is pretty tough. Just remember, with almost all of the skid plates, there may be a reduction in cornering clearance.
"doggone and dagnabit! That's what I call a whopping' big rabbit."
Keep the rubber side down
'01 Sprint ST '12 Super Tenere
NOVA Tag-o-Rama Map
TH is offline   Reply With Quote
Old 09-17-2013, 08:36 AM   #19840
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,277
Trust you to take a bad thing and make it worse.
I think your Rover has less total body work.
Old 09-17-2013, 09:56 AM   #19841
GatSS
Canadian eh
GatSS's Avatar
Oddometer: 288
Thumb ACD skid plate
I installed the ACD skid plate last night. Easy to install and looks great. We'll wait a bit to test it
Mat
2012 Super Tenere
2002 XR400R - plated
2009 CRF50
GatSS is offline   Reply With Quote
Old 09-17-2013, 10:23 AM   #19842
jaumev
jaumev's Avatar
Oddometer: 1,511
This black plate look gorgeous in your black bike. I'm sure Pluric would like it!
Bikes, trips and farkling at http://traildreamer.com/
Yamaha Super Ténéré off road modifications: http://advrider.com/forums/showthread.php?t=797977
jaumev is offline   Reply With Quote
Old 09-17-2013, 10:39 AM   #19843
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,277
I've petitioned for black to be added to the color of the rainbow. Waiting for Skittles reply.
Old 09-17-2013, 11:15 AM   #19844
TH
There and Here
TH's Avatar
Oddometer: 912
One more thing about skittles;
NOVA Tag-o-Rama Map
Old 09-17-2013, 11:18 AM   #19845
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,277
Yeah but they would help Jaumev get rid of the taste of Lars.
Times are GMT -7.   It's 07:35 AM.
