Old 09-18-2013, 04:27 PM   #1
Krol OP
_______
Oddometer: 14
690 Enduro R only starts in neutral, not with clutch in
Hi,
As the title states, my 2013 690R does not allow the starter to engage when in gear and the clutch in. I used to be able to start in gear with the clutch in, but now I have to put the transmission in neutral for it to start.
Any ideas what this could be?
Thanks in advance.
KTM 690 Enduro R '13
Krol is offline   Reply With Quote
Old 09-18-2013, 04:32 PM   #2
Slimak707
Hard On Equipment
Slimak707's Avatar
Oddometer: 124
Probably the safety switch on the clutch lever is out of service, causing the bike to think the clutch is not disengaged. There is probably a wire coming off of it going "somewhere". Follow that wire and unplug it. See if it effects the operation. If not it may require a jumper wire. Basically making the bike think the switch is working, or go buy a new switch.
Slimak707 is offline   Reply With Quote
Old 09-18-2013, 04:36 PM   #3
Slimak707
Hard On Equipment
Slimak707's Avatar
Oddometer: 124
Make sure you Re not missing this part on the clutch lever.
Old 09-18-2013, 06:40 PM   #4
Krol OP
_______
Oddometer: 14
Thanks slimak, I'll check it when I get home.
Times are GMT -7.   It's 07:55 PM.
