Go Back   ADVrider > Riding > Mapping & Navigation
Thread Tools Search this Thread Rating: Thread Rating: 33 votes, 5.00 average. Display Modes
Old 10-20-2010, 06:54 AM   #46
rotax793
gravel hunter
rotax793's Avatar
Oddometer: 6
Originally Posted by mazman808
But, in mapsource, i have the 6.16.1 version and in edit>preferences> there is no routing option tab! so they must of changed it.
The availability of the routing tab depends on the map products installed on computer. If, for example, you only have a map which does NOT support auto-routing the setting will default to direct routing and the tab will not appear.
rotax793 is offline   Reply With Quote
Old 04-20-2011, 08:59 AM   #47
COG-528
COG-528's Avatar
Oddometer: 13
I have a Streetpilot 2610 and a copy of the 2008 edition of MapSource. I created a route for a COG ride to eat, "Springtime at Kundlas" - May 14th. I want to include a stop at High Point Monument here in NJ as part of the route but my version of MapSource does not show the roads within High Point State Park so I could not include it when creating the route.
Last Saturday I check drove the route and created a Track file that shows the way in the park to the Monument. But I've no idea how I can incorporate a section of that Track file into the route or how to create a complete Route file from the Track file in my 2008 edition of MapSource.
Does anyone here know how to accomplish either one of these goals?
Someone suggested I'd need to get a third party utility which could be a problem since I'm still running Windows 2000 on my PC.
COG-528 screwed with this post 04-20-2011 at 09:30 AM
COG-528 is offline   Reply With Quote
Old 04-20-2011, 07:38 PM   #48
lfs225
Too old less bold
lfs225's Avatar
Location: Cape Girardeau, MO April to Oct, then Naples, Fl
Oddometer: 338
Continuing a route
Mapsource 6.16.3. If you want to add on to a route that you have closed you can do it by doing this:
1. Click on the route with your arrow icon. This will highlight the route.
2. Change your icon to the hand.
3. Right click on the end waypoint. Either end will work. It even remember what direction your traveling.
4. An option will be given to "extend route".
This option is not offered unless the route is highlighted.
Now can someone tell me how to make multiple routes into one route? I know about copy and paste to move routes from one file to the next but once I get two or more routes in one file how to I convert them into one route?
The older I get; the faster I was
I'd give my right arm to be ambidextrous.
Our attitude is the crayon that colors our world.
lfs225 screwed with this post 04-22-2011 at 12:51 PM
lfs225 is online now   Reply With Quote
Old 05-23-2012, 08:21 AM   #49
Paebr332
Oddometer: 1,362
I got the document. Eagerly awaiting the gpx files.
Paebr332 is offline   Reply With Quote
Old 09-29-2013, 06:19 AM   #50
Nesbocaj
Politicians suck
Nesbocaj's Avatar
Oddometer: 990
Extending or inserting a route
In Mapsource (I am using 6.16.3)
1-choose the arrow tool
2- highlight route by clicking on it in the Route window, or the route itself in the map window
3-right click on either the beginning or the end of the route, depending on which you want to extend
4- pop up window opens- choose extend route
3a- to insert a new section within the route right click on the spot on the route
4a- pop up window opens- choose insert route section.
2014 BMW R1200GS-W
Nesbocaj screwed with this post 09-29-2013 at 06:29 AM
Nesbocaj is offline   Reply With Quote
Times are GMT -7.   It's 06:49 AM.
