Old 09-15-2013, 06:17 PM   #5536
TCSVN
...Stays in Vegas...
Oddometer: 181
Originally Posted by ducnut View Post
I'll keep this thread moving along and put my money where my mouth is.
In the past, when solicited, I've recommended OSB for sheeting and stains for concrete. This is my smaller garage (22'X22') I just finished. I used Sherwin Williams ProBlock Primer, SW SherScrub latex paint (2 coats-this stuff is high build and thick, like paint used to be) on the walls, SW H&C solvent-based solid color stain (2 coats), and SW H&C solvent-based clear gloss (2 coats) on the floor. I used 2-1/2 tubes of latex painter's caulk on the sheeting seams, joints, and screws/nails. If you have any questions, please ask.
I'm going to be doing my shop next. It's split in halves and will get totally different colors. I'm going to try SW's water-based floor products in it, as it doesn't see near the traffic or chemical exposure as the garage. SW has a "high-gloss" product I want to try.
How hard was it to do the solvent-based stain? We are building ours right now and I went down to Home Depot and looked at the stuff they have there and it seemed pretty easy, but I have no idea how durable it will be.
Your floor looks pretty damn durable--can the average joe do it?
TC
Sent from my iPad using Tapatalk - now Free
HF&LSN.
TCSVN is offline   Reply With Quote
Old 09-15-2013, 07:15 PM   #5537
ducnut
Oddometer: 3,305
TC
Prep is the most important thing. If your concrete is "green", you need to ask the contractor how long to wait before you etch it. Any coating needs a "bite". I'd recommend a 25-40% muriatic acid mix (mix it in 5gal buckets, have them ready, just dump them on the floor, slosh it around with a broom, rinse). I've used 50% mix, but, it can get a little aggressive and leave the surface more porous than I like. I usually pressure wash twice, in perpendicular directions. Let is sit 2-3 days. If you use water-based stain, you don't need to wait.
The advantage to stain is that it actually penetrates the concrete; paint doesn't. I cut down the first coat with 10% xylene. That further thins the stain, so that it can better soak in. The second coat I use straight. If you have any cut stain left, just mix it in with your second coat stain. The clear is optional. I've done them without it and it leaves an eggshell sheen, yet as porous as the concrete originally was before staining.
I prefer to use the H&C line that Sherwin Williams sells. I'm not familiar with anything Home Depot sells, as we don't have one where I live.
Yes. A DIYer can do it. There's nothing tricky about it. Of course, there are techniques and equipment (Wooster 18" roller setup is advantageous) that does make a difference. But, don't let that dissuade you.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 09-17-2013, 02:59 PM   #5538
JagLite
JagLite's Avatar
Oddometer: 1,197
Question Sheathing?
Looks great Ducnut!
Am I understanding correctly that you use OSB for the walls instead of sheet rock? Or is there sheet rock AND OSB over it?
The reasons for using OSB?
I am guessing it is much more damage resistant and you can attach things to it anywhere, are there other reasons?
James
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 09-17-2013, 03:41 PM   #5539
Vankaye
n00b on the move
Oddometer: 225
I have H&C stained several patios (at my own house) and decks and driveways of my rental homes. While it does look great, durable would not be a word I used to describe concrete stain AT ALL!!
It scratches and is affected from the simplest of chemicals. I have ruined my back porch with gas can that had just a little bit of gas spillage on the sides. Pine-sol from your carb soak will totally eat it away. IF durability is what you're looking for, H&C (sold at both HomeDepot and Sherwin Williams) is not your answer - although it would be the cheapest and quickest. The one good thing I can say about H&C concrete stain is that it's quick and cheap. Great for rental house patios and whatnots...
Vankaye is offline   Reply With Quote
Old 09-17-2013, 03:54 PM   #5540
ducnut
Oddometer: 3,305
Just as you stated.
Like anything put down, some chemicals will play hell with it. I've got some stuff that'll go through any coating, given time to soak. Likewise, nearly anything will chip, hit hard enough. Again, proper prep makes all the difference in durability, with impacts.
I've not had any issues with petroleum products, brake cleaner, etc. But, I wipe up my spills. Maybe, the clear makes a difference.
'96 Ducati 900SS
Old 09-18-2013, 12:16 PM   #5541
brooks
Oddometer: 323
Sweet Mother!!!!
Brooks
brooks is online now   Reply With Quote
Old 09-29-2013, 02:35 PM   #5542
Rizingson
Vintage Rider
Rizingson's Avatar
Oddometer: 244
I am new to this site, but been lurking for awhile. Enjoying everyones man castles, lots of cool shops and ideas. I'll try and post a few pics of mine. A bit crowded but working on more space.
Here's the main working area, and a couple of views. Oh! I'm an addicted Vintage Japanese Bike collector and retired. So this is my fun time
Rizingson is offline   Reply With Quote
Old 09-29-2013, 02:42 PM   #5543
JagLite
JagLite's Avatar
Oddometer: 1,197
Thumb Yikes!
WOW !!!
Attitude ~
James
Old 09-29-2013, 02:43 PM   #5544
foggy50361
Oddometer: 74
Wicked Really!!!!!
Retired millionaire:cla p
As they say if it make you happy! Carry on!!!!!!!!
This is only my opinion, other opinions are available on request.
"You have brains in your head. You have feet in your shoes. You can steer yourself any direction you choose."
"I do not like green eggs and ham".
Dr Seuss. One man getting it right all the time
foggy50361 is offline   Reply With Quote
Old 09-29-2013, 04:06 PM   #5545
crosscountry
Bear went over Mountain
crosscountry's Avatar
Oddometer: 2,430
That looks like a bike shop from the 70s! Awesome
My travel Blog, about living and riding, and living to ride.
I went for the thrill of adventure and the desire to explore - Charlie Duke
crosscountry is online now   Reply With Quote
Old 09-29-2013, 05:51 PM   #5546
Rizingson
Vintage Rider
Rizingson's Avatar
Oddometer: 244
Thanks for the compliments. I'll probably hang out a lot in the "old school" section
Sign just inside the door says "caution: entering a 60s time warp".
Your not the first person who thinks it looks like a '70s shop. Most of the bikes are from the sixties. I allow up to '75 for my collection. Still have a few newer, such as late 70's and up to '82 now, but they will soon be expendable. Still have more that I can't get into the picture or in another area.
I enjoy cranking up the '60s tune's on the sound system and just mentally drifting back to a happy carefree time, while doing maintenance or frame up restorations. I rode around a lot on the small tiddlers then, dreamed of having the bigger bikes. Now I've finally made that a reality. The shop has two lifts, one for maintenance and one for builds. Also an engine area and cleaning/blasting area. Had intentions to put in a paint area, but since that's not really in my skill set, I farm it out, when needed.
I really enjoy going to Bike show's and showing bikes while meeting people. Also attending auctions whenever possible.
Old 09-29-2013, 07:34 PM   #5547
Vincenthdfan
Oddometer: 471
Would you like to adopt a 48 year old??
I don't eat or drink too much and I love classic Japanese bikes very much!!
Vincenthdfan is offline   Reply With Quote
Old 09-29-2013, 07:44 PM   #5548
Import
Import's Avatar
Oddometer: 319
Holy...... That is an awesome collection.....think I've ridden a few of them...congrats and continue the good work..
(ps..I'm showing this to the misses...I really can justify more projects..)
Import is offline   Reply With Quote
Old 09-30-2013, 03:09 AM   #5549
CrustyD3mon
CrustyD3mon's Avatar
Oddometer: 280
god damm...what an amazing collection man...
CrustyD3mon screwed with this post 10-01-2013 at 05:43 PM
CrustyD3mon is offline   Reply With Quote
Old 09-30-2013, 12:51 PM   #5550
Patriot4570
Trail Blaster
Patriot4570's Avatar
Oddometer: 2,743
Very nice collection ,thanks for sharing.
I've learned that pleasing everyone is impossible, but pissing everybody off is a piece of cake.
Patriot4570 is offline   Reply With Quote
Times are GMT -7.   It's 01:48 AM.
