Old 09-28-2013, 07:11 PM   #31
BEEF706 OP
King of the dumb dab
BEEF706's Avatar
Oddometer: 713
Originally Posted by brewtus View Post
It's an ex-Butler bike. Keep going, you're not done yet.
I'm never done anyway, "if ya can't ride, fiddle with it" has always been my motto I even took it out to the desert near my house and got it dirty this afternoon.
NMOHVA Member NMTA Member
07 CRF450x, 04 Beta Rev3 270, I like red bikes
A good friend will take you trail riding, an ADV friend will double back and say, "how did you get down there?"
BEEF706 is offline   Reply With Quote
Old 09-29-2013, 05:08 PM   #32
BEEF706 OP
BEEF706's Avatar
Oddometer: 713
Sooo... I'm gutted
Well the tranny oil was NOT OK (note to self, it's not just mocha milshake to worry about, pepto bismal is bad too ) and as I dug into it to see what I needed to order the news got worse, look what I found behind the impeller
soI guess I need to order a new case? the casing behind the impeller is one piece I think?
Brewtus you may now giggle and do the I told you so dance (you cn make fun of my car next month
Old 09-29-2013, 06:47 PM   #33
DerViking
Shred
Oddometer: 344
That doesn't look good at all....
You might be able to Tig the holes, then have someone clean it up with a mill. That would require spitting the case. Bummer. I am a little amazed that the coolant ate the aluminum. I wouldn't have guessed that would happen. Motobene?
I guess you could try JB weld or high grade epoxy. Die grinder out the holes, smooth it into place with a couple of layers. If it works, let us know.
ATGATT: When you fall off your motorcycle, you will be wearing what you were when you got on your motorcycle. Dress accordingly.
DerViking is offline   Reply With Quote
Old 09-29-2013, 07:00 PM   #34
lineaway
Oddometer: 2,867
I fixed a `92 with JB weld around 2000. As far as I know it`s still running. PS. That is not aluminum.
lineaway is offline   Reply With Quote
Old 09-29-2013, 07:09 PM   #35
AteamNM
Wonna Be ADVrider
AteamNM's Avatar
Oddometer: 3,931
I hope that is the Butler Beta? FFFFKKK. Get Bob to help you. Roswell is very soon.
AteamNM is offline   Reply With Quote
Old 09-29-2013, 07:13 PM   #36
DerViking
Shred
Oddometer: 344
Is it magnesium then? If so, I have to guess Tig is out. That might be pretty exciting in a 4 alarms sort of way.
Old 09-29-2013, 07:20 PM   #37
lineaway
Oddometer: 2,867
Ironic, that `92 beta was a Butler bike too!!
Old 09-29-2013, 07:49 PM   #38
BEEF706 OP
BEEF706's Avatar
Oddometer: 713
it looks like it has already been done with JB. this is with the seal out, doabe? anyone know what a case costs?
Old 09-29-2013, 08:06 PM   #39
lineaway
Oddometer: 2,867
Trevor needs to be your new friend!
Old 09-29-2013, 08:11 PM   #40
Gordy
Team Listo
Gordy's Avatar
Oddometer: 22,756
I saw the strawberry milkshake on the rocks today and knew that something still wasn't right.
I'd buy a new seal and set it in place with some JB weld until I could justify splitting the cases. Bummer.
Gordy is offline   Reply With Quote
Old 09-29-2013, 08:29 PM   #41
BEEF706 OP
BEEF706's Avatar
Oddometer: 713
The case is already off, think Trevor has one? I have a bit set aside, I dunno which way to go.
Old 09-29-2013, 08:33 PM   #42
lineaway
Oddometer: 2,867
Trevor can get one. I thought you had other plans next week?
Old 09-29-2013, 08:58 PM   #43
BEEF706 OP
BEEF706's Avatar
Oddometer: 713
I do, but I still wanna get it fixed. I might want to go to San Yo when nobody's around I guess i could get a gasket set, try the JB weld, and then if it doesn't work get the new case before SanYo in November. It won't really hurt it any worse will it?
Old 09-29-2013, 11:58 PM   #44
Twin-shocker
Oddometer: 1,673
Magnesium is easily welded, but while cracks in cases caused by impact damage are no problem at all, corrosion damaged parts must be blast cleaned first, which in some cases leads to the damage becoming much worse, and becoming difficult/impossible to repair.
Best option for your case is to blast clean, then repair the damage immediately using Devcon titanium putty. There is a good possibility that will work for the time you own the bike, but without removing all of the corrosion with blast cleaning the repair will only last a short time.
Old 09-30-2013, 06:29 AM   #45
Brewtus
Buffoonery, Inc.
Brewtus's Avatar
Oddometer: 3,072
Originally Posted by BEEF706 View Post
Brewtus you may now giggle and do the I told you so dance (you can make fun of my car next month)
No giggle and "told you so" dance. I was really hoping that it was just a seal and not a magnesium case issue. That sucks.
Don't worry, I'll hold off until next month on telling you about my plans to make a Jennifer Aniston mask for your homely car.
Work hard. Play hard.
Team Dead End. The drinking team with a Trials problem.
2-Time winner of the coveted "Best Shenanigans" award at Capt. Rick's annual BBQ.
Brewtus is offline   Reply With Quote
Times are GMT -7.   It's 08:57 AM.
