Old 10-05-2013, 11:39 AM   #11311
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,803
Originally Posted by Gros Buck View Post
Problem is we do not know what alloy they are using.
You can easily triple the strength of a part with an appropriate alloy. Pretty easy to jump from 25,000 to 75,000 psi (707x T6) with an appropriated selection.
Drop forging will add up to 15% and extra life.
Heat treatment is critical to many aluminium alloy.
Paul Jr
Yes a good point. We have a tool in the lab at work that will tell the material makeup. Might be able to sneak a piece in
Seth S
Seth S is online now   Reply With Quote
Old 10-05-2013, 01:58 PM   #11312
kito
Oddometer: 281
Hi I'm on the lookout for a new bike and at the moment it looks like the 690 with RR evo 2 tanks is at the top of the list. I will be buying secondhand so are the any year models I should avoid or be looking out for ? I see a lot of you guys are changing your exhaust. Is this just to get away from the CAT ? If so has anyone removed the CAT from the OE and welded it back up ? (I did this on my x challenge and it worked great) if I did this would the bike need to be remapped ? ( on my BMW it never) . Are the any known faults I should be looking out for when going to see 690 ? What are they like to work on ? Iv never had a KTM so it's all new to me.
Sorry for so many questions
Thanks kito
kito is offline   Reply With Quote
Old 10-05-2013, 02:40 PM   #11313
Hank.SD
Jet Measurer
Hank.SD's Avatar
Oddometer: 1,298
Just took my new to me 08 out for a shakedown run. Holy crap that's fun. One problem is a leaky gas cap. Maybe its all the wheelies
What is the best solution for that?
Hank.SD is offline   Reply With Quote
Old 10-05-2013, 04:09 PM   #11314
Assfault
Exposed Member
Assfault's Avatar
Oddometer: 2,367
Buy a KLR if you need a solution for the wheelies.
Rally Raid & KTM Twins has a solution for the fuel cap.
* Assfault, Ass-Fault, Ms Ass, thier neighbors or friends, are not responsible for any incidents, accidents, or accusations, that might result from you using this forum in the pursuit of adventure greatness. Avoid taking ADV before bed time. Do not use if you experince faintness, dizzniess, inversness, difficulty urinating or an erection lasting longer than 4 hours. Thank you*
Assfault is offline   Reply With Quote
Old 10-05-2013, 04:22 PM   #11315
Hank.SD
Jet Measurer
Hank.SD's Avatar
Oddometer: 1,298
I've owned a couple KLRs.. I don't think I'll be revisiting that any time soon. This thing is fun!
Old 10-05-2013, 04:34 PM   #11316
v8toilet
Nothing to see here.
v8toilet's Avatar
Oddometer: 1,739
Thanks kito
The main reason for exhaust swap is that the stock boat anchor gets so hot it's regularly referred to as nuclear. It's not safe and it's heavy.
v8toilet is offline   Reply With Quote
Old 10-05-2013, 05:06 PM   #11317
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 3,025
Get a real 690CC bike, swap the can and swap the pleated filter for the UNI twin pod and you'll be ace!
No need to bother with a remap. It'll run like a scalded ape just the way it is.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is online now   Reply With Quote
Old 10-05-2013, 07:12 PM   #11318
kito
Oddometer: 281
Yer that's what was what was happening on my x challenge. But I'm cheep so just removed about 1KG of unwanted crap from inside the exhaust and it then ran a lot cooler.
Old 10-05-2013, 07:34 PM   #11319
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,695
The 690 is a thing of beauty. She is like a fine whiskey.. you don't mix her with diet coke. Wings and FMF both make beautiful looking and sounding high quality exhaust for not a lot of money. Call it your birthday present to yourself or something. I promise you will be happier then bastardizing the stock can for the sake of saving a few bucks.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 10-05-2013, 08:18 PM   #11320
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,689
Originally Posted by gen View Post
Big sharp hits like that can damage steering head bearings, so try to get the front wheel off the ground and check for any notches or clicks or play in the steering.
Also your forks may be out of alignment. If you know how to check this you should or have the dealer check.
I have a piece of thickish plate glass which I keep specifically to align forks. You'll have to disassemble the plastic slider guards and remove the front wheel.
While you have the axle out, spin the inner/male tubes around inside the female uppers. The inner parts should spin perfectly on their own axis. If they describe a "cone" when rotated (i.e. the ends swing around as you rotate them) then they are bent.
To perfectly align the forks, lay the plate glass across the exposed inner slider and check the tubes for parallelism: if the plate glass rocks corner-to-corner, then the tubes aren't parallel.
Loosen the bottom triple clamp pinch bolts, and slightly loosen (leave snug but not tight) the top pinch bolts. Adjust the alignment buy turning the bars to the steering stop and giving the top clamp a tap with the rubber mallet. Tighten the bots and recheck with the plate glass.
I invented this process, and it has impressed some suspension tuners with the ease and accuracy of adjustment. Of course, you need to buy a piece of glass, which is a slight PITA. You may refer to it as The Roadracer Al Procedure.
When they say Harleys are for 1%ers, I don't think they mean guys who sell crank and get in bar fights any more.
Roadracer_Al is offline   Reply With Quote
Old 10-05-2013, 08:37 PM   #11321
gen
gen's Avatar
Oddometer: 804
That is indeed brilliant! They would call that Jugaad in India.
http://en.wikipedia.org/wiki/Jugaad
DoD#1458
gen is offline   Reply With Quote
Old 10-06-2013, 04:54 AM   #11322
MeinMotorrad
MeinMotorrad's Avatar
Oddometer: 1,586
Thanks Roadracer Al. This place continues to amaze.
'12 KTM 690 Enduro R
MeinMotorrad is online now   Reply With Quote
Old 10-06-2013, 11:45 AM   #11323
CordR
Oddometer: 514
Love that.
CordR is offline   Reply With Quote
Old 10-06-2013, 11:59 AM   #11324
DirtJack
DirtJack's Avatar
Oddometer: 1,607
Thanks kito
The first post in Noah's epic RTW thread gives a good list of the issues his two 690's have had. They are representative of what to expect. It's a great bike. Caution: if you haven't started this thread already, you'll likely be needing some sleep real soon.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 10-06-2013, 02:17 PM   #11325
Canadian_Bacon
Oddometer: 211
Does anyone have any recommendations for a fuel stabilizer for storage?
2010 KTM 690 Enduro r (Current)
LOADED 2008 KLR (Sold)
2000 Ducati Monster 750 (Sold)
Canadian_Bacon is offline   Reply With Quote
Times are GMT -7.   It's 12:02 PM.
