Old 08-22-2013, 01:32 PM   #226
Gigglingoth
Oddometer: 24
Trying to remember
So I've hit my 1000 mile mark (okay, Im a bit passed it) and it's time for me to change the belt. I remember that I need to change it up to a Gates but does anyone know the number? I had it written down but I can't find my notebook
Gigglingoth is offline   Reply With Quote
Old 08-22-2013, 08:56 PM   #227
deezildennis OP
Its a what?
Oddometer: 824
835-20-30 is the size belts i run in my ssr ruckclone. My stock belt was a Bando brand and in my opinion was just as good as the gates i have in it now.
Take care
deezildennis is offline   Reply With Quote
Old 08-22-2013, 09:10 PM   #228
Gigglingoth
Oddometer: 24
Thanks Dennis Also, is this motor considered the long case? The rear bolt hole where the air box connects snapped when the wind caught the scooter and blew it over. Thankfully that's all that happened but I need to replace the front pulley cover and just really want to make sure I'm asking about the right part. BTW did you ever get my pm? Thanks for all the help. Learning so much about this bike has actually been a lot of fun.
Old 08-23-2013, 05:15 AM   #229
deezildennis OP
Its a what?
Oddometer: 824
It is a long case Gy6.
I'll check on the pm.
Old 08-26-2013, 04:22 PM   #230
deezildennis OP
Its a what?
Oddometer: 824
My 600th post.
I get to tell you my Speedo has started to fade out on me. A few days back I nailed a huge pot hole and really shook me and the bike up pretty hard. I noticed it fading around then.
Luckly these are easy to find and cheap enough.
I'm really just glad I didn't get hurt or bend the front wheel.
Other than that the bike is still doing great.
Old 08-26-2013, 05:10 PM   #231
Birdmove
Birdmove's Avatar
Oddometer: 1,720
Why are you replacing the belt at only 1000 miles? Is it of bad quality? Some SYM HD200 owners have gone as far as 12,000-16,000 miles.
I am following some threads on other forums about Chinese motorcycle owners. Many suggest replacing the engine oil before you even run them due to questionable quality. Also the fuel lines. Some rubber parts break down very early, but I've even heard that about some SYMs. Some owners have found the valves were set at about zero tolerance too.
Jon in Keaau, Hi. USA
2008 SYM HD200 (wife's ride)
2009 Kymco People 150 and coming soon, another dual sport mc
Birdmove is offline   Reply With Quote
Old 08-26-2013, 08:05 PM   #232
Gigglingoth
Oddometer: 24
Honestly, just because I can....this bike is 100% new learning experience for me and since I'll be adjusting valves for the first time I figured I would go ahead and do the belt. I will keep the original as a back up in case it's ever needed.
Old 08-28-2013, 07:04 AM   #233
DudeClone
DudeClone's Avatar
Oddometer: 1,724
Originally Posted by klaviator View Post
After reading the article in the link, I'm not sure I believe this guy. Although he gives a lot of good advice, he also makes some very questionable statements. He says that the Chinese scoots are just as good quality as Honda or Yamaha? Of course that's after you replace all the fluids,belt, spark plug and ignition coil. He also states that a GY6 engine requires premium fuel or it will gum up and destroy the carb. That's interesting. I've been running mine on regular for 12,500 miles with no problems.
He also says not to expose your scooter to the elements. So just ride it on sunny Sunday afternoons and it will last a long time.
I'm sorry but this guy who wrote this article is full of it.
I'm not a Chinese scooter hater. I think it's impressive when someone buys one of these things cheap and then puts the effort into making it run well. But to claim they are just as good as Honda or Yamaha is just BS.
One thing I will say for the Chinese, they do make some scooters that the Japanese, Italians, or Taiwanese should be making like this 150cc Ruckus clone. Why can't Honda do that? Just build it in Thailand to keep the cost down. 150cc is big enough to be practical but still small and light enough to be lots of fun and reasonably inexpensive.
guy says a "valve adjustment every 1000km to 3000km." wtf my Agility 125 has 17,000 miles and the valves have never needed adjustment. maybe once but i can't recall
are china scoots high maintenance? i find my two Taiwan scoots to be incredibly neglectable but they remain reliable
bikes
DudeClone is offline   Reply With Quote
Old 08-28-2013, 10:07 AM   #234
deezildennis OP
Its a what?
Oddometer: 824
I don't think mine is more so than anything else I ride.
I really believe it depends on what China scoot you pick. I looked at a bunch. I mean really looked at them. I asked to take panels off looked at hoses, fittings, hardware quality of materials... you name it. If all you can afford is a China scoot, do your homework, realize you will need to maintain it, and buy from a local established dealer that knows how to fix any issues you have.
Make sure it has a warranty. Walk away if they say it doesn't.
Old 08-29-2013, 04:25 PM   #235
klaviator
klaviator's Avatar
Oddometer: 6,005
I have checked the valves on my Super 8 every 2500 Mi as specified in the Manual. They were out of spec 2 of 4 times. I'm about to check them again. Depending on what I find I may lengthen the interval between checks. Many people get away with neglecting the valve adjustments but it's a gamble.
I ride, Therefore I Am.
klaviator is offline   Reply With Quote
Old 10-10-2013, 06:08 AM   #236
deezildennis OP
Its a what?
Oddometer: 824
Update..
I put a larger AGM battery in the rucklone. Best upgrade by far in this bike. Had the valves adjusted by the dealer I bought it from. Going to need front brakes soon. I may just replace the disc as well since they are really cheap.
Other than all that its still kicking. Had a nice little run to a friends property about 60 miles away. For the most part it was right at 50mph. That's just right before 7k on the clock and I know guys run these harder but I'm not. 50mph on backroads is plenty.
Take care all.
Old 10-10-2013, 06:51 AM   #237
ronnath
ronnath's Avatar
Oddometer: 1,445
Originally Posted by deezildennis View Post
Update..
"cheap" as in not too costly to replace?
ronnath is offline   Reply With Quote
Old 10-10-2013, 09:41 AM   #238
deezildennis OP
Its a what?
Oddometer: 824
They are $25 through my dealer. So yes cheap to replace. I haven't checked for run out on the disc but it must not be much since it doesn't pulse or anything.
Old 11-28-2013, 08:52 PM   #239
deezildennis OP
Its a what?
Oddometer: 824
Still scooting along with this.
Still really glad I upgraded the battery last summer. It has really helped on the super cold mornings here in the Midwest. I really need to get some sort of wind protection. I toy'd around with the idea of a lap cover but haven't came up with anything yet. I like the wind guards the real big ruckus' used to be able to get and still may try and fabricate something like that for it.
Not much else done to it but check the valves and fiddle fart with the hall effect speedo pick up that's been a big pain in the ass since I busted the piss out of the original speedo cluster. A trail tech vapor may be going on it next year.
Take care all!
Old 02-19-2014, 02:34 PM   #240
Gigglingoth
Oddometer: 24
All winter, Great! But now...
So my bike has never given me any issues until now and hopefully it's a small one. Bike has fired up and ran perfectly all winter long. No hard starts or anything. So far the stock battery has been perfect. Yesterday I rode with zero issue and today....well, it starts. It varies between starting right away and then not until I lay on the starter for a long period. When it first started this it ran ok once started. But then would run for a bit and die. If it started running rough I gave a small throttle twist only to have it die. I replaced the spark plug just in case. The old one had normal burn but it fired right up with the new plug and seemed to keep running just fine. After a few minutes and a spin around the block it died. No idea what to try next. I did contact SSR because I got the performance coil and cdi for the bike and was asking about a larger jet. They said the carb is sealed and they do not recommend and upgrades on this unit
Times are GMT -7.   It's 07:16 PM.
