Old 07-18-2013, 11:09 AM   #226
RideAlongAtlas1
IS GOOD ! ! !
Oddometer: 147
shoei GT Air Touring Helmet reviewed
I did a product review of my Shoei GT Air helmet, after riding around in it for 2 months. I bought this instead of buying a duel sport helmet. I just posted my video on my channel if anyone's interesting in watching it. It's a pretty good helmet hey. Maybe worth considering buying this particular 'touring' helmet instead of the current range of duel sports, trade-offs are talked about on the video a little.
See my DR650 motovlog here https://www.youtube.com/ridealongatlas
RideAlongAtlas1 is offline   Reply With Quote
Old 07-18-2013, 02:53 PM   #227
pyplinr
Ta Ta Toofey
pyplinr's Avatar
Oddometer: 40
Wicked Bilt DS Helmet
Questions:
1. Now that you've had it for a while, what do you think?
2. How is it on the highway at speed?
3. Is the sun visor dark enough? It looked a little light when I tried it on.
4. Any quality issues after 1 month?
Any other
1. For a $100 helmet its great, that being said...
2. Very noisy at highway speed and also squeaked when buffeted (the roost guard mounts/bolts are crap)
3. Internal sun visor was good for all but direct morning/evening sun in my eyes (I added sunglasses in those cases)
4. 1st drop from seat height pulled the roost guard off, the two small hex bolts that hold the back of the guard pulled through the guard itself. I found longer bolts and washers to remedy the problem
5. No room/means to mount bt speakers in the helmet. I ended up carving out some styrofoam to make room.
Surely undoubtedly someone reputable will make a DS helmet with a retractable internal sunvisor and clear visor eventually....
I am a fan of this type of helmet just not the current manufacturers; I previously had a Scorpion Cobnvertible (with internal sun shade) and liked it with exception to the wieght and the street look.
For note, I also bought an Acerbis DS with similar equipment. I ordered a 2X and it fit about like a typical medium. My head is 8 5/8ths and I couldn't get an Acerbis XXL past the top of my forehead.
pyplinr screwed with this post 07-18-2013 at 02:55 PM Reason: + pic
pyplinr is offline   Reply With Quote
Old 07-18-2013, 03:00 PM   #228
pyplinr
Ta Ta Toofey
pyplinr's Avatar
Oddometer: 40
Leaky
Originally Posted by Cromoth View Post
Anyone use this helmet in rain & how was it?
It leaks, not to be smart but it is a $100 helmet. Noisy, air leaks, water leaks, cheap construction. That being said it is what I currently use because no one else makes a helmet with the same features and of better quality. (in the US/that I know of)
Old 07-18-2013, 03:06 PM   #229
pyplinr
Ta Ta Toofey
pyplinr's Avatar
Oddometer: 40
CG $69, can't get much cheap cheaper than that
Originally Posted by Yokomo View Post
Anyone have a dirt cheap XL they would like to get rid of? I'd give'r a whirl.
http://www.cyclegear.com/CycleGear/O...3193_59409_199
Old 07-19-2013, 03:30 PM   #230
mwilliamshs
Oddometer: 223
LOVE this helmet! Even more after 30 minutes of mods
Don't miss that Hundred Bucks AT ALL. My wishes for improvement match the other's, namely less noise, better ventilation, and a darker retractable shield. I've made a couple of mods that probably made the first worst but really improved the second and third.
First, remove all the screws and add LocTite then reinstall. You'll know their tight and they won't fall out. Several reports in this thread of screws falling out/parts falling off.
Second, If you remove the peak, which I recommend anyway to put LocTite on the screws, you'll see a square hole in the outer shell. This is directly under the top vent slider and is right on top of your head. The shell is cut out but the inner foam is not.
View from above:
Well, I took the handle of a plastic spoon and worked two groves into the foam connected the hole in the shell to the front of the foam. This allows the air directed into the vents on top to flow into the helmet. The air unfortunately has to make a 180* turn to enter the helmet and then another to leave but this is as good as it's gonna get without compromising the safety of it. The total amount of foam removed is MINIMAL. Wouldn't fill a teaspoon by a long shot.
View from behind, after mod:
View close-up of foam, after mod:
Makes a significant difference in overall air volume flowing into the helmet. Took maybe 5 minutes. You can tell a difference just standing in front of a fan, much less in 60 mile an hour wind.
Third, the retractable shield is not as dark as I'd like and there are no available options from Cycle Gear at this time. I used the peel-off lens protector that comes on the helmet as a template to cut out some static-cling style vinyl window tint from Wal-Mart's automotive department. I'm sure this is available in varying degrees of tint (rated in the % of light that passes through, so lower=darker) but I've had this roll a long time and used on everything from radio screen in my truck to car windows for when my niece is in her car seat to the windows in my bedroom at home (night shift=sleep during the day). Probably costs $10 or so. Given my intended uses I probably bought the darkest stuff available but don't remember. THIS FILM USES NO GLUE so it leaves NO RESIDUE and can be removed and reapplied over and over if you like. Peel the lens protector, stick on the tint film, cut around it with common scissors, and apply both to your shield.
The reason you leave the factory film on top of the tint is so you can work out the bubbles without risking damage to your tint. The stuff is pretty tough but this is most likely the most pressure/stretching/etc it'll see. I used a plastic shopping card to work out the bubbles. Took 5 minutes or less. So people use soapy water but I don't. There is plenty of room for the shield to retract with the tint on the outside of the lens, even with the factory protector on, so if you decided you wanted it even darker multiple layers could be used. This mod not only darkens the shield for sunny days but also protects it from scratches.
The flash makes the tint look a funny shade and you can definitely see all the lint I hadn't rinsed off yet. I'm super happy with the tint mod. The irregularities along the bottom are way below line-of-sight, even when looking down but I'm sure a more patient person with steadier hands could achieve more perfect results.
Perform any and all mods at your own risk.
EDIT: looks like cycle gear does sell replacement OUTER shields in clear, light smoke, and dark smoke so you could pair a smoked shield with the retractable sun shield i guess and get a little more relief from the sun but I like the tint mod because it only affects the inner shield and clear vision is always just a flick of the wrist away.
mwilliamshs screwed with this post 07-19-2013 at 10:44 PM Reason: proofing
mwilliamshs is offline   Reply With Quote
Old 07-20-2013, 09:36 PM   #231
G19Tony OP
G19Tony's Avatar
Oddometer: 411
That vent mod looks good. I'll have to give it a go.
BMW F800GT, Hodaka Dirt Squirt, Honda CL70, Honda CT70, Honda Grom.
Nothing's too cruel if it's funny enough.
G19Tony is offline   Reply With Quote
Old 08-25-2013, 11:10 AM   #232
Stromtrooper246
Lost again
Stromtrooper246's Avatar
Oddometer: 470
Does anyone know if they've changed the design? I tried a new XXL on the other day and no more ear fold. With a $20 off coupon I have it may be worth a try at $79.
stephen
http://www.caferacerpodcast.com/
13 Stelvio NTX 1200
13 Tiger 800
02 Guzzi V11 Tenni *T105*
Stromtrooper246 is offline   Reply With Quote
Old 08-30-2013, 03:25 PM   #233
smithe
Oddometer: 367
I wish I could tell, I couldn't even get the XXL on at all and any other brand of helmet I am a L or XL. I ended up getting the non visor one in an XL and it is a great fit. For $79 I would jump on the other one and if it doesn't work out their return policy is pretty darn good.
Sent from my SPH-L720 using Tapatalk 2
'12 Tiger Explorer
'93 KLR650
smithe is online now   Reply With Quote
Old 09-07-2013, 07:53 AM   #234
Stromtrooper246
Lost again
Oddometer: 470
I pulled the trigger on the $79 helmet. So far so good. You guys are right about the sunshade. It is a little light in color. Not an issue for me because I always wear sunglasses under it. The fits is not bad with it being just a little bit tight. No more ear bending though. The sales manager at my cycle gear seems to thing they redesigned the interior pads.
stephen
13 Stelvio NTX 1200
13 Tiger 800
Old 09-07-2013, 09:56 AM   #235
sjc56
Oddometer: 1,336
I tried one on and the distortion on the shield was so bad I could not see wearing it for long with out getting a headache . To bad it would go go with my XT350 I just pick up.
Steve
sjc56 is offline   Reply With Quote
Old 09-15-2013, 03:02 PM   #236
NortwestRider
TRIPOD ADVENTURER !!
NortwestRider's Avatar
Oddometer: 3,897
Originally Posted by yeroc40 View Post
It looks like they are now offering replacement cheek pads if you wanted to try another size
I just tried on a Explorer yesterday and will probably buy it but when I asked the store manager about replacement interior parts ( cheek pads,liner etc ) he said they DON'T offer any!!.
I tend to keep my helmets a long time ( my HJC IS MAX is 5 years old and has 75,000 miles on it ) and rebuild the interiors as needed.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
GS500ADV..THE PURPLE EXPLORE
[B
NortwestRider is offline   Reply With Quote
Old 09-15-2013, 03:05 PM   #237
NortwestRider
Oddometer: 3,897
The next model down is the DISCOVERY it's on sale right now for $69 till the first week of Oct.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Old 09-16-2013, 03:31 AM   #238
Matt fe2o3
Oddometer: 583
I just got my Suomy MX Tourer. Has the beak, drop down sun shield and clear visor.
Love it. Well made, quiet, seal and shield fantastic. Tight yes, no room for ear buds. Lightest helmet I have ever worn.
Yes 400 is more than 100, however this helmet is far better than my Arai Vertor 2 in countless ways (ok countable...)
Cheers.
Matt fe2o3 is offline   Reply With Quote
Old 10-11-2013, 08:02 AM   #239
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,500
I bought the Explorer exactly one week and one day ago, and have only used it for commuting thus far.
The sun visor jammed up a few days ago despite me only having used it once (during a ride to work at which point I realized the decal was still on the sun visor, so I flipped it back up).
This morning I started trying to move the deployment slider back and forth to get it to come out, but eventually it really caught up and I think it pulled the left visor's side out of its attachment. It was hanging in there at an angle, so I pulled it down and out until the other side also unclipped.
At this moment the flip down sun visor is now out of the helmet and sitting on top of it.
Hey, no worries - I normally ride with singlasses anyway (though sunglasses are painful in this helmet - I have another set of sunglasses on order that will hopefully work).
Overall, it's a very cheaply made helmet. I bought it solely for the few off-road dusty trips I do with other riders where / when I'd also want goggles to keep their dust out of my eyes. Because my good helmet (Icon Airmada) has a tinted visor on it that I don't like taking off, I started using the Bilt Explorer helmet for those commuting days where I'll be riding home after dark (because it ha a clear visor).
The straps seem so cheap that I really wonder if they're secured correctly (mainly because they skimped), but for $99 it is what it is.
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is online now   Reply With Quote
Old 10-11-2013, 01:46 PM   #240
kubiak
Oddometer: 4,829
yea i noticed sunglasses in this helmet starts to hurt after a bit of riding. i think its from pressing them into my head from a tight fit. i was thinking i might smash the foam a little where the sunglass arms press against. any other ideas?
Times are GMT -7.   It's 06:24 PM.
