Go Back   ADVrider > Riding > Regional forums > Australia > OZ Vendors
Old 10-19-2013, 07:34 PM   #826
Beemerboff
Oddometer: 2,306
Actually, I am sitting here with two rather painfull knee caps after chucking the F650 down the road, and feeling that description probably applies to me.
Mostly my fault, of course.
So, did I learn anything?
Probably a little, but I knew most of it and just did it wrong.
First, my new E07s have a lot more grip than old Pirelli Sport Demons of an indeterminate age, which the PO had fitted.
Unless there is a recent reciept for tires and tubes I usually change them on a new bike as soon as possible - just why I didnt do it this time I cant explain, as the Demons are a horrid little tire and totally unsuited to the F650.
I was actually on my way to Garage MCs to have a set of Annekey3 s fitted, and had probably let the Demons get too worn - I usually change at about 80% worn, but these were 98% on the front and 100% on the back.
But the roads were dry and I was just going on a little meander to kill time until my fitting appointment-----.
I was wearing partially lined kevlar jeans, with soft rubber pads in the knees.
The soft rubber knee pads didnt seem to make much difference to the impact, and one jeans leg split at the sticheng at the top of the knee pad pouch, where the kevlar stopped, so I have a large graze on that knee.
My elbows are fine the E marked hard elbow protectors worked perfectly, although the jacket is a write off. Ten years old anyway.
Every other pair of bike trousers I own have hard E marked knee protectors-------.
Elastoplast Spray Plaster is a good product, but it stings a bit on a small cut and is f--king agony on a large graze.
I wouldnt buy part lined kevlar jeans, or even the ones with kevlar from the knee to the waist, and I wouldnt go without hard knee protectors.
You would probably be just as well with a $20- pair of Rivers jeans and decent quality offroad style strap on knee and shin protectors.
Remember too that an old, worn, pair of jeans will split eventually, so if you want protection dont wear them until they are worn out, no matter what type.
So what happened to cause the fall?
Just cruising down Hindmarsh Valley road, approaching the main Victor Harbour road junction. I applied the front brake brake with medium pressure and the front went down like it was on ice, and I was body surfing down the road on my chest.
No squeal or skid marks, just the mark where the engine protector hit, hard.
The road had just been re sealed , using the new system they are introducing which consists of one heavy layer of bitumen spray followed by a layer of uncoated 25 mm gravel, blinded in the same operation with 6 mm to dust stone.
So the new surface was a mixture of 25mm uncoated stone and dust.
The old Highways spec was two spray layers , each followed by a layer of bitumen coated chips, the first 14 /15 mm and the second of 6/7 mm, rolled into the first, although not all councils followed this spec.
So how much was the old Sport Demon and how much the new surface I cant say, but I would tread this new surfacing with extreme caution.
A car load of nice young ladies stopped and helped me back onto the bike, and I made my tire fitting appointment.
One even lifted my bad leg over the saddle, much to the amusement of her friends. Makes a change.
The Annekey3's felt great on the way home, a different class from the Demons.
They have the feel of a quality tire, nice planted feel, good progressive turn in, and good road shock asorbtion.
Havent tried them on gravel yet, or tested the ultimate grip, but as soon as my swollen knees go down a bit I will do a bit gravel.
Hopefully without testing the ultimate grip.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is offline   Reply With Quote
Old 12-16-2013, 02:52 PM   #827
Tom Bon 865
Oddometer: 6
New e07?
Howdy,
Forgive my ignorance but is there a new compound e07 on the market? The mitas website had no new listings last time I checked yet I'm reading if softer, more grippy tyres? Bring them on!
Are they the dakars? I was under the impression the dakar (yellow stripe) was even tougher than before..
Cheers
Tomo
Tom Bon 865 is offline   Reply With Quote
Old 12-16-2013, 03:30 PM   #828
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,393
Mitas softened the compound a while ago in an effort to alleviate the cracking that occurred around the tread; they still crack but not to the same extent.
There is an E07 Dakar rear made for the big chookies but it is not sold in Oz.
I'm just about to replace the E07s on my R100GS, 20,000Km on the front, 13,000Km rear and flattened out. They still stick like shit to a blanket.
David Hunn:
R100GS Ray Peake special.
http://www.advrider.com/forums/showt...uild+australia
gsd4me is offline   Reply With Quote
Old 12-17-2013, 12:58 AM   #829
Farmer Roy
Farmer Roy's Avatar
Oddometer: 287
umm, how do you find the E07 front on loose gravel or sand ?
looking at a new front tyre soon, and i like the E07 i hav on the back
Farmer Roy is offline   Reply With Quote
Old 12-17-2013, 05:16 AM   #830
Gadget678
Gadget678's Avatar
Oddometer: 1,174
C-17 & E-09 on DRZ400
In May 2014 I'll be riding 5700km across Australia- Airlie Beach to Freemantle- with no tyre changes. My choices so far are: Dunlop D606 (not keen on them), Pirelli MT-21 (enjoy the rear, but not sure about the life span- supposedly it will make it).......
But I'd like an opinion of using the Mitas E09 rear with C-17 front. (don't bother mentioning the E09 front- not enough dirt traction for my liking.... the rears are predictable) I've no doubt the E09 rear will make the distance on the 400, but what about the C17? I ran C21's in the Aus Safari & know that they wouldn't make it.
Have you ever noticed that when you're out on the bike, nothing else matters?
http://www.advrider.com/forums/showthread.php?t=709292
Gadget678 is offline   Reply With Quote
Old 12-17-2013, 05:21 AM   #831
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,393
OK on loose dirt, but I don't ride very fast; don't know about sand. Davorallyfan took his R80 G/S PD up near Cape York to the last OCR with an E07 on the back, but had a knobbie on the front (MT21?) and did alright.
I have it on good authority that E07 rear and Continental TKC80 front on airhead beemers and DR650's etc is a well regarded combination for RTW travel.
David Hunn:
gsd4me screwed with this post 12-17-2013 at 05:32 PM
Old 12-18-2013, 01:22 AM   #832
atgreg
Africatwinarama
atgreg's Avatar
Oddometer: 10,020
gadget , try the T644 army special;
http://www.motorcycletyres.net.au/ty...ari/index.html
1990 RD04 Africa twin 750
350,000km and still going strong
atgreg is offline   Reply With Quote
Old 12-18-2013, 02:00 AM   #833
ferals5
f5eral
ferals5's Avatar
Oddometer: 1,107
after 1000k of 50/50
ferals5 is offline   Reply With Quote
Old 12-18-2013, 02:29 AM   #834
Beemerboff
Oddometer: 2,306
Mitas make the TKC for Continential, and also sell it under their own brand, a bit cheaper than the Conti.
I find the a new E07 front fine on loose gravel, but like gsd4me I dont go that fast either.
Grip seems to fall away quickly as it wears, unlike the back which seems to wear and grip forever
Old 12-18-2013, 02:57 AM   #835
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,393
And the name is.........................?
David Hunn:
Old 12-18-2013, 11:34 PM   #836
Gadget678
Gadget678's Avatar
Oddometer: 1,174
I knew of the T644, but never looked at it as an option....it looks much more aggressive in the flesh. What do you have it on, and how does it feel?
Have you tried the T644 rear? How do they wear/feel? Would this possibly be a better option than the E09 rear on the DRZ 400?
Old 12-19-2013, 12:41 AM   #837
ferals5
f5eral
ferals5's Avatar
Oddometer: 1,107
F650dakar, I like it on the dakar, gives advance notice when your playing beyond your capability felt better when traveling out west than the MT21 I have on there at the moment. But the dakar is a lump of a bike so comparisons to a DRZ may be pointless
Not tried rears as I've always matched it with the E07, always worth a shot though
Old 12-19-2013, 04:00 PM   #838
Beemerboff
Oddometer: 2,306
1 think the E10 is the TKC equivalent, but it only comes in 150 rears.
Old 12-23-2013, 08:03 PM   #839
wairau
richie
wairau's Avatar
Oddometer: 1,310
i see theyre making the e10 in the harder dakar version now too, like the e09
wairau is offline   Reply With Quote
Old 12-23-2013, 09:19 PM   #840
zoro
Oddometer: 331
I have a C02 rear that has 4000klms on it, reckon its easily got another 2000klms left on it.
50\50 dirt\ blacktop.
Bit slippery on wet blacktop but other than its been excellent.
XR650R
zoro is offline   Reply With Quote
Times are GMT -7.   It's 07:50 AM.
