Old 10-22-2013, 02:42 PM   #1
sjc56 OP
sjc56's Avatar
Oddometer: 1,386
XT350 1mm overbore
The new piston arrived today, I went with the second overbore of 1mm. Someone know the bore size for the second overbore? My Clymer just gives the stock bore specs of 85.97-86.02, and the second over size of piston size of 86.50 but not the bore needed. Will the machine shop know? first time doing this.
Steve
sjc56 is offline   Reply With Quote
Old 10-22-2013, 02:53 PM   #2
oldxr
oldxr's Avatar
Oddometer: 1,145
You take the piston and cylinder to the machine shop.The machine shop measures the piston and bores the cylinder for it+needed running clearence.The running clearence spec will usually be on a slip of paper packaged with the piston or if a factory oem piston in the fsm.
oldxr is offline   Reply With Quote
Old 10-22-2013, 04:28 PM   #3
sjc56 OP
sjc56's Avatar
Oddometer: 1,386
No specs with the piston (Yamaha) I'll bring the new piston and rings with me.
Steve
Old 10-23-2013, 02:26 PM   #4
sjc56 OP
sjc56's Avatar
Oddometer: 1,386
Dropped the cylinder and piston off at the machine shop, no big deal,$60.
Steve
Times are GMT -7.   It's 11:05 AM.
