Old 09-06-2013, 02:26 PM   #1966
nigelcorn
Wannabe.
nigelcorn's Avatar
Oddometer: 802
That is amazing.
nigelcorn is offline   Reply With Quote
Old 09-06-2013, 02:52 PM   #1967
zendirt
Circus Clown Dropout
zendirt's Avatar
Oddometer: 104
Sweet! I love the black swing arm.
zendirt is offline   Reply With Quote
Old 10-22-2013, 01:55 PM   #1968
LVCJT
LVCJT's Avatar
Oddometer: 229
Here's mine getting ready to be washed after a long weekend in Death Valley.
Sent from the depths of my pockets
LVCJT is offline   Reply With Quote
Old 10-22-2013, 02:13 PM   #1969
Hoologan
Hoologan's Avatar
Oddometer: 242
Here's my '03
Standard ADV Acerbis 6.3
Clarke 4.3 for shorter adventures
Cockpit
Western TAT 2012
Prudhoe Bay 2014
Hoologan is offline   Reply With Quote
Old 10-24-2013, 09:18 PM   #1970
DocAxeYarYar
RideDualSport.com
DocAxeYarYar's Avatar
Oddometer: 784
ADV Convert
My XR650R Build:
http://ridedualsport.com/forum/index.php?topic=2748.0
DocAxeYarYar is offline   Reply With Quote
Old 10-24-2013, 11:24 PM   #1971
Trigxrr
Oddometer: 84
Here is mine
Trigxrr is offline   Reply With Quote
Old 10-28-2013, 05:21 PM   #1972
Mikey Boy
Mikey Boy's Avatar
Oddometer: 236
New owner here. I rode Hoologan's 650R on a 3 day Nevada trip last weekend and was hooked. Sold my wr250 and picking up a plated 2000 XR650R on Wednesday. Has Q4 pipe, Clarke tank, 3/4 inch risers with Renthals, K&N filter and a bunch of other mods.
Edit: I'm gonna need a bigger tank for DV and such. Acerbis 6.3 or IMS 7.0 Gallon tank? Thoughts?
Work to ride, and ride to work.
2014 Tiger 800xc - Meow
2000 XR650R - plated
Mikey Boy is offline   Reply With Quote
Old 10-28-2013, 06:15 PM   #1973
LVCJT
LVCJT's Avatar
Oddometer: 229
Get rid of the k&n. They are a well none weak spot on the Xr650r. Tons of info here. http://www.advrider.com/forums/showt...php?p=22643783
Old 10-29-2013, 09:25 AM   #1974
Mikey Boy
Mikey Boy's Avatar
Oddometer: 236
Uni? Moose? Gracias amigo!
Old 10-29-2013, 04:05 PM   #1975
LVCJT
LVCJT's Avatar
Oddometer: 229
I use uni. But as long as you stick with foam you should be okay.
Old 10-30-2013, 08:44 AM   #1976
Shibby!
Oddometer: 1,656
Stock is actually best for filtering. Maybe not for flow.
I run Twin Air, but i think they are all pretty much the same with Moose, Uni, etc.
Stock's are pretty pricey but seem to fit the best and have nice thick filter media.
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 03-26-2014, 06:26 PM   #1977
BronkoRob
Oddometer: 60
how many of you guys are running bigger batteries? what battery and where have you placed them?
I am looking into a small LED light bar and wiring GPS and speedo to the bike. I have noticed the well known dimming of lights at idle, and I want to get away from that. Right now I have a 200W stator running threw the ricky stator reg/rect, so the whole bike is DC.
I am thinking about adding a battery in a small tail bag and running accessories off of that. I do have dual outputs from the stator and was wondering if there would be any benefit or issues to running all power threw 1 reg/rect to the battery than to devices.
I hope to get the lighting and light bar setup and either making a taller rally style fairing or just going the BMW Dakar wind screen route and cutting an opening for the light bar.
No Pads, No Helmet.....Just Balls!
BronkoRob is offline   Reply With Quote
Old 03-27-2014, 08:44 AM   #1978
modette
RMAR
modette's Avatar
Oddometer: 4,398
Actually as long as you FOLLOW the K&N directions you will have no issues. Got to use the K&N grease to seal around the air filter unit. Also spray some tacky filter stuff on it vs just the K&N oil. No dust is getting in. I bet a LOT of people skip the grease around the filter to seal it into the air box.
Follow directions people.
Edited to say: It's why I said use the tacky stuff and don't just use the K&N oil. I think there might be enough room to put a foam filter on top of the K&N I'll tinker when I put the kiddo to nap time and see if so I'll take a picture.
Member of AMA, COHVCO, and RMAR
On the Board of Directors for RMAR: Director of Promotions
Our site: Rocky Mountain Adventure Riders
modette screwed with this post 03-27-2014 at 12:13 PM
modette is offline   Reply With Quote
Old 03-27-2014, 10:09 AM   #1979
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 5,979
K&Ns suck for dusty riding, when clean they pass dust period. All you have to do is look at Baja racers, the people running the K&N are running an oiled foam prefilter around it and often a filter skin. Unfortunately on bikes it's hard to layer the filtration. K&Ns actually don't start filtering well till they get dirty, the design relies on trapped dirt particles to help filter out other dirt. When they are clean (and oiled) fine dust particles will pass right through them. The size that gets through is very fine so it's not like it's going to toast you motor but most off-road applications don't rely on the K&N alone. When oild foam doesn't pass anything why install a filter that doesn't stop everything.
I run one on my sand rail because it's makes a good base to support the 2 other filters layered over it.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is online now   Reply With Quote
Old 03-27-2014, 01:25 PM   #1980
luckychucky
luckychucky's Avatar
Oddometer: 1,182
Cool sand rail pic! I put a solar panel for charging my Tusk battery pack. I'll let you know in a year or two how it's doing
luckychucky is offline   Reply With Quote
Times are GMT -7.   It's 11:46 AM.
