Old 10-29-2013, 07:41 AM   #11056
sbrownn
SlowMo
Oddometer: 457
They are there.
Originally Posted by TowPro View Post
I asked my salesmen if it had ride height sensors so the bike is level depending on how much load, and he said no.
here is why I asked:
Manual, page 65.
Dynamic EAS Electronic Suspension Adjustment
- with dynamic ESA
Adjustment Options
Using the electronic suspension adjustment, dynamic ESA you can conveniently adjust your motorcycle to the load.
Using leveling sensors, dynamic ESA detects movements of the running gear and responds to them by adjusting the damper valves.
(this says Damper Valves, not Spring rate)
Now on page 67, under section about Adjusting Chassis (that starts on page 66).
At very low temperatures, unload the motorcycles before increasing the spring preload, and have the passenger dismount if necessary.
This makes me think there is no ride height sensors, and it sounds more like a "pre set" spring load change.
You can see the sensors on the bike. My guess would be is that they provide feedback for the on the go damper adjustment and perhaps they balance the spring pre-load front to back as well.
sbrownn screwed with this post 10-29-2013 at 07:50 AM
sbrownn is offline   Reply With Quote
Old 10-29-2013, 09:08 AM   #11057
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
Yes, there are sensors, but not for preload just for dynamic damping.
'13 R1200 GSW
EJ_92606 is offline   Reply With Quote
Old 10-29-2013, 12:58 PM   #11058
sbrownn
SlowMo
Oddometer: 457
Makes sense.
Yes, that is probably true.
Old 11-13-2013, 05:16 PM   #11059
duffs
I have a beard
duffs's Avatar
Oddometer: 1,207
Sorry chaps I’ve been away...
Preload is set by changing the height of the spring perch and does so by a motor and not the damper. This is the first I've heard that it measures the rider weight as part of the adjustment...I was also told to unweight the bike when adjusting preload so as not to over stress the motors.
Originally Posted by oalvarez View Post
Preload is a function of the spring height/rate.....i don't know preload to be a by-product of damping/fluids. what your tech is describing sounds more like damping (compression and rebound, fluid being pushed thru valves/orifices), and not preload (the spring actually being manipulated lower/higher by force, and in the case of BMW, by a motor...whether that still controls a collar or pushes something else, i'm not sure).
You’re both right - the preload adjuster is separate from the damper, using a motor/pump to increase/decrease the spring compression hydraulically and steplessly. I should have differentiated this clearly, as my previous description excluded this distinction. You can see the individual chambers and how the components slide against each other in the cutaway below.
Ironically my bike is going in on Monday to have the preload system checked/potentially replaced as it intermittently refuses to change settings. After riding in solo mode, if I stop the bike (to wait for someone, for example), then restart it and change to 2-up mode, the indicator flashes indefinitely with no change to the preload. This happens probably 1 in 3 times... a bit annoyed, but at least my dealership has been helpful/understanding and have involved HQ engineers in Munich.
Ride reports: Europe 2014 | Alps 2013 | Fryslân 2012
2012 F 800 GS Trophy 2014 R 1200 GS TE
Blog: Gelände Straßetastic! Facebook Tumblr
Ride reports, photos, tips, experiences, general twaddle
duffs is offline   Reply With Quote
Old 11-14-2013, 10:12 AM   #11060
ShaftEd
ShaftEd's Avatar
Oddometer: 3,358
Iv'e got to admit, the while I find the GSW Dynamic ESA to work very good overall, the limit of only 3 options for preload is frustrating. Unless you weigh the ideal 175lbs, the icon settings are way off. Fully geared up, I'm about 230lbs. Put the preload in solo(one helmet) and it is very soft (no cases on the bike). Too soft. Handles pretty bad. So, I have to set icons to solo with luggage, which is a bit too much preload, but a lot better than the one helmet icon only. Is this BMW's way of telling me to go in a diet, and what if you're a lightweight and only way 140lbs? If we could tailor the icon settings to match rider weight, or the bike could do it itself. It has travel sensors, it could add preload when it realized that sag is too much. Maybe the aftermarket will help us out someday with custom springs.
ShaftEd is offline   Reply With Quote
Old 11-14-2013, 12:14 PM   #11061
TowPro
Lets ride
Oddometer: 3,241
[QUOTE=ShaftEd;22778116]Is this BMW's way of telling me to go in a diet, and what if you're a lightweight and only way 140lbs?.[/QUOTE
I was sort of thinking the same thing (but never got around to playing with this feature yet). How does the bike know how much the rider weighs? Now if they adapted those sensors on there to be level sensors, that would be great.
2015 KTM 690 Enduro R
2014 R1200GS - My Naked Street Touring Bike
2000 KTM LC4 640 E - currently up for adoption with 3200 miles
TowPro is online now   Reply With Quote
Old 11-14-2013, 08:12 PM   #11062
oalvarez
Resident Raggamuffin
oalvarez's Avatar
Oddometer: 2,623
That's just it.....it doesn't, but that's where sag measurements come into play. If one truly wants the best performance from their bike's suspension then a "one spring fits all" (variable rate springs help) system won't really allow for such. That's why there are oem and/or aftermarket springs that best suit different rider weights. Of course, some riders may be entirely happy with the oem ride and available preload adjustments, others may not know any better, and some manufacturers may not even allow for different springs, so all of this may be for naught.
2015 BMW r nine T | 2012 Vespa 300 Super
past: Ducatis, Aprilias, Moto Guzzis, a Husky, KTM 1290 SDR, and some BMWs as well
oalvarez screwed with this post 11-14-2013 at 08:41 PM
oalvarez is offline   Reply With Quote
Old 11-14-2013, 08:27 PM   #11063
iride4u
iride4u's Avatar
Oddometer: 321
[QUOTE=oalvarez;22782426]
This is the reason that I installed a set of Wilbers on my GTL and will do the same on the GSW.
2013 R1200GS LC red
2012 K1600GTL blue
iride4u is offline   Reply With Quote
Old 11-14-2013, 08:43 PM   #11064
oalvarez
oalvarez's Avatar
Oddometer: 2,623
I did the same but used Ohlins on an old GS of mine.......the best riding GS, ever.
Wait, you just gave me an idea....
Old 11-14-2013, 08:56 PM   #11065
mefly2
mefly2's Avatar
Oddometer: 1,228
It seems like it would not be an impossibility for BMW to allow input of the riders "ready to ride weight" and then utilize the idiot icons ... if not directly by the rider (more convenient) at least by the dealer / computer connection.
----------------> jer-
30+ years with RTs...then to F/GS; now *Finally*
the BMW: R1200GSW, factory low seat & lower crash bars;
Touratech: Upper Crash Bars, big foot, pannier rack, ZegaPro panniers;
Fuzeblock, Rigid Dually D2 + yellow covers; Wunderlich bar risers w/ Q-adjust
mefly2 is offline   Reply With Quote
Old 11-15-2013, 09:51 AM   #11066
ShaftEd
ShaftEd's Avatar
Oddometer: 3,358
Wilbers makes replacement springs for the HP4 Dynamic suspension, so maybe they will make springs for the GS. Hell, the front shock on the GSW doesn't even have any preload adjustment at all. Seems pretty weird to me.
I am hearing some rumors of Wilbers making complete Dynamic replacement shocks for the GS(haven't found them on the interweb yet), and Touratech just debuted Dynamic shocks at the ECIMA 2013 show for the GSW. These may be options down the road, as it stands now, I spent way to much $ to also add in $3k-$4k in aftermarket shocks. Besides the stock stuff works very good. I'd just like to be able to ge a proper sag setting for me, and me with luggage. Oh well, my Dr. told me to go on a diet anyway.
Old 11-15-2013, 09:52 AM   #11067
ShaftEd
ShaftEd's Avatar
Oddometer: 3,358
Not a bad idea, dealer sets rider weight on computer at time of purchase. Then preload icons work correctly.
Old 11-15-2013, 10:15 AM   #11068
snakebitten
Small Town Hick
Oddometer: 980
The All New 2013 LIQUID COOLED R1200GS threadfest
Punching in your rider weight would be cool. But, alas, it still requires the correct spring to get proper static preload.
No way around that.
I suspect the buyers that weigh between 165-190lbs geared up will find themselves right in the bullseye for the OEM springs. Thus. The ESA settings will work well for them across the solo-luggage-2-up scenario.
Anybody lighter or heavier will not match up well with the pre-programmed settings of the ESA system. Just physics.
I'm betting that if not now, sooner or later somebody is going to make aftermarket springs for the ESA shocks?
And is it really true there is no preload adjustment on the front? That seems implausible.
XT1200Z BIGGEST Dirt Bike in the world
500 EXC Dirtiest Street Bike in the world
snakebitten is offline   Reply With Quote
Old 11-15-2013, 11:02 AM   #11069
ShaftEd
ShaftEd's Avatar
Oddometer: 3,358
Yep, the standard GSW(without ESA), or the Dynamic ESA optioned GSW, front shocks have no preload adjustment.
Old 11-15-2013, 11:22 AM   #11070
snakebitten
Small Town Hick
Oddometer: 980
That's hard to get my head around.
It would seem you could get the front and rear out of "balance". Where they would\could work against each other.
Do the after market shocks up front supply pre-load?
Times are GMT -7.   It's 04:24 AM.
