Old 11-08-2013, 08:20 AM   #16
motobene
Motoing for 44 years
Oddometer: 1,177
Originally Posted by DerViking View Post
Motobene
MY gasser switch was destroyed. I tied the wires together and put a wire nut on them. Is it likely still defaulting to Cloudy? Or would completing the circuit lock it in Sunny? That was my intention.
Sorry. Didn't see this until now.
Closing the circuit wires your ignition makes for the sunny setting, so the advance curve at higher rpms is steeper. You'll likely not notice much at top, and the lower rpm feel should be the same. To default to the cloudy setting undo the wires and run an open circuit.
motobene screwed with this post 11-09-2013 at 07:28 AM
motobene is offline   Reply With Quote
Old 11-08-2013, 06:03 PM   #17
DerViking
Shred
Oddometer: 326
Thanks! That is what I thought. Before I smashed the switch, I could not tell a difference between the settings. On steep redrock I could almost convince myself it made a difference, but???
ATGATT: When you fall off your motorcycle, you will be wearing what you were when you got on your motorcycle. Dress accordingly.
DerViking is offline   Reply With Quote
Times are GMT -7.   It's 04:15 PM.
