Old 10-13-2013, 03:50 PM   #1
JustinP OP
JustinP's Avatar
Oddometer: 1,700
LEDRider - New Quad Cree XM-L LR4 LED Flood Lights
Update: 12/8/14: LR35/LR40 light announcement and pre-order deal for ADV members! -Click here for details-
Update: 12/3/14:
Price drop on our LR5 5000 Lumen light - click here to get over 10,000 lumens for less than $200 for ADV members!
Update 12/2/13: As a special thanks to the ADVRider community, we've bumped our permanent discount to 15%. Coupon code is ADV15 - thanks for your business :)
Howdy ADVRider folks :)
We're happy to offer our new LR4 LED Floods to the ADVrider community with a 15% discount.
LR4 features listed below:
Heavy Duty Mounting Hardware Included
4x Cree XML U2 LEDs
Custom Engineered Mirrored Reflector for a Focused Beam
3500+ Lumens (See notes below-1)
2.4 Amps (See notes below-2)
12-36 Volts DC Input
IPX7 Waterproof
100% Aluminum Housing
Thermal Protection
Shatter proof, Scratch Resistant Ultra Clear PMMA lens
CE Certified
54mm/74mm/18mm (Diameter/Length/Mounting Standoff)
Compatible with all PWM 12v LED Dimmers (Skene Etc)
Full details on our new site: LEDRider.com (Work in progress :))
Notes:
1. We use true OTF Lumens measurements. We've tested these side by side with quad cree XM-L T6/U2 lights from two other vendors with higher advertised Lumens, and could see no difference in performance.
2. We tested the amp draw of these lights on a Yamaha FJR running at 14.1 Volts, and had a consistent reading of 1.8 amps.
Heavy duty mounting hardware is included at no cost. These lights are well built, with an extremely solid feel; and amazing performance.
Side View:
Front View:
Front view mounted on Super Tenere
Mounted on FJR with WynPro brackets:
Rear:
Another Side Shot:
Any questions, please post or PM. Special coupon code for ADVRider Forum members is "ADV15" - you can order using the store URL above. Special pricing is $85 each right now, plus another 15% off for ADVRider members.
Thanks for looking!
FAST: 2004 non-ABS "Silver Bullet" FJR - FASTER: 2008 Touring/Endurance Hayabusa - SLOW: 1997 R1100GS
Quality LED Lighting - ADV Discount inside:) - LEDRider LED motorcycle lights
JustinP screwed with this post 12-08-2014 at 11:43 PM
JustinP is online now   Reply With Quote
Old 10-13-2013, 04:12 PM   #2
Olas
the darkness
Olas's Avatar
Oddometer: 3,972
Just bought a pair of these from Justin. I was very impressed with the feel and quality look of these lights right off the bat. The mount they come with is beefier than what I've seen on other brands. As a bonus, you cannot beat the price either.
I'll get around to installing them this week hopefully, will report back.
Rebuild threads:
'92 XT600, '87 XR250R
Lighten up, Francis.
Olas is offline   Reply With Quote
Old 10-14-2013, 11:21 PM   #3
JustinP OP
JustinP's Avatar
Oddometer: 1,700
Thanks for your business! Looking forward to seeing your install :)
Old 10-21-2013, 04:01 PM   #4
JustinP OP
JustinP's Avatar
Oddometer: 1,700
FYI Folks - We're back in stock on the LR4's. Had a few inmates waiting to order, but were out of stock on the LR4's
Here's some shot's I was able to grab the other night. Bike is on center stand. The fence is @150 feet from bike. Farthest tree in the background is between 400-500 feet. Crappy camera, non scientific 3 foot per pace measuring, for comparative purposes only. Still working on getting some more "professional" photos. The limited exposure on my camera just doesn't capture enough light for an accurate representation.
Stock FJR Low Beam (55 watt halogen)
Stock FJR High Beam (65 watt halogen)
FJR Low Beam + 2 LR4 Floods
Remember to use ADV10 coupon code for 10% off
Old 11-05-2013, 11:00 AM   #5
JustinP OP
JustinP's Avatar
Oddometer: 1,700
Here's some pictures showing the real world performance of a pair of LR4 Quad Cree XM-L U2 flood lights at 1000 feet. Compared to similar quad Cree XML lights, the LR4 has less light scatter and close in glare, and more range. The reflector design throws a beam like that of a high end flood flashlight; tight beam in the middle for range, with a secondary flood beam for a wide field of view.
Bike was in turnout on right side of road on center stand. Camera was on tripod on the left side of road. 1st tree is at 750 feet, second tree is at 1000 feet. Bike GPS was reset at the farthest tree out and ridden back and turned around where we took the pictures: https://lh5.googleusercontent.com/-c...102_235944.jpg
Note: you can click on the pictures on drop box to zoom in to full size.
First shot is stock FJR (H4) low beams with +80 Halogens:
https://www.dropbox.com/s/6u9bfo4i5q9ohd6/1low.jpg
This is stock FJR (H4) highbeams, +80% halogens:
https://www.dropbox.com/s/kkdv8k420lwq46d/2high.jpg
This is low beams plus 2 LR4 floods:
https://www.dropbox.com/s/55exx1h6o4fhgc9/3LR4.jpg
In other news, WynPro has designed let brackets for the Gen2 FJR, more info here: http://ledrider.com/lr4-light-bracke...-the-gen2-fjr/
LR4 installed on FJR with WynPro Brackets:
We are also working on developing a quality, low cost, rotary dimmer that can be used with our LED lights (and just about any other LED that does not have it's own built in dimming circuitry). We opted for the rotary design as it's simple, and does not require the use of a RF dongle that can be lost or have a dead battery. There will be a high beam over-ride on the dimmed setting. At first it will be available in a single 7 amp channel. Once we are happy with the results, we'll expand to a dual channel as well, with independent over-rides, to control multiple lights with there own settings (for example, you could set your left light to 0% with low beams, and your right to 20% - or control multiple sets of lights). We'll post up more details as they become available.
As always, coupon code ADV10 is good for 10% off for inmates :)
Old 11-06-2013, 06:28 AM   #6
Chuck35
Chuck35's Avatar
Oddometer: 33
I installed a pair of LR4's and mini's on my FJR this weekend. They are managed by a Skene controller. These things are awesome! You could land aircraft with them. Justin was great to deal with and even shipped before he was paid when my money ended up in a Paypal loop.
Caution advised when aiming and setting up power levels. These things can be hazardous to other drivers.
2008 Yamaha FJR1300
Chuck35 is offline   Reply With Quote
Old 11-09-2013, 03:34 PM   #7
zgfiredude
Oddometer: 818
Any progress on the dimmer?
'06 950S Adv, DRZ440E, KLX440R, DRZ250, & F650GS
zgfiredude is offline   Reply With Quote
Old 11-09-2013, 04:34 PM   #8
JustinP OP
JustinP's Avatar
Oddometer: 1,700
It's moving along. I should have prototypes within two weeks. Once I sign off on the design, will be another week or two for the first shipment to come.
Old 11-29-2013, 04:57 PM   #9
Olas
the darkness
Olas's Avatar
Oddometer: 3,972
It took me a while to get to them, but I finally did the install. It was a very simple process. I am powering them through a relay that uses the high beam as its 12V switched power source. Luckily the V-strom has plenty of room for extra wiring, so you can barely it's there.
First impression is that they are super bright, even during the day. I still need to try them out in the dark, and get them aimed correctly.
Low beam on:
High beam:
Rebuild threads:
Old 11-29-2013, 07:59 PM   #10
JustinP OP
JustinP's Avatar
Oddometer: 1,700
Thanks for the install pics. I think you may find them too bright at night mounted low on your forks and move them up higher, due to the road glare.
Old 12-02-2013, 04:28 PM   #11
JustinP OP
JustinP's Avatar
Oddometer: 1,700
Happy and Safe Holidays from LEDRider to the ADVrider community :). To show our appreciation we have some good news and some holiday specials .
First, the good news: We've bumped our permanent ADV discount code to 15% for the ADVRider community! Use ADV15 when ordering any product from our site.
Holiday Special: Holiday special is wrapped up :)
JustinP screwed with this post 12-10-2013 at 09:37 AM
Old 12-09-2013, 06:50 PM   #12
JustinP OP
JustinP's Avatar
Oddometer: 1,700
Folks - pulling the plug on this sale tomorrow. Last chance to get in on this amazing pricing. :)
Old 12-09-2013, 09:13 PM   #13
ttime4four
ttime4four's Avatar
Oddometer: 239
Thanks for the discount - order just placed.
'14 KTM 690 Enduro R
'06 Husaberg FE450e (Oregon Plated)
ttime4four is offline   Reply With Quote
Old 12-10-2013, 09:38 AM   #14
JustinP OP
JustinP's Avatar
Oddometer: 1,700
Thanks for your business. :)
Apparently everyone else waited till the last day too, I'm going to have a busy day .
Old 12-10-2013, 11:13 AM   #15
speedbird
Oddometer: 7
Ordered just now to take advantage of the holiday special. Thank you. Cheers.
speedbird is offline   Reply With Quote
Times are GMT -7.   It's 12:40 PM.
