Old 11-13-2013, 05:54 AM   #21001
LittleRedToyota
Yinzer
LittleRedToyota's Avatar
Oddometer: 2,338
Originally Posted by Tropic-Of-Canada View Post
The first number is the width, the second is some kind of ratio of the first for the height, I think...
the ratio is height of the sidewall as a percentage of the width.
so, a 90/90 tire is 90mm wide and has an 81mm tall sidewall. (90% of 90mm is 81mm).
a 80/100 tire is 80mm wide and has an 80mm sidewall. (100% of 80mm is 80mm).
LittleRedToyota is online now   Reply With Quote
Old 11-13-2013, 07:10 AM   #21002
PhiSig1071
What's ******width?
PhiSig1071's Avatar
Oddometer: 2,551
Originally Posted by 955616846 View Post
The zerks are an E feature not found on the S or SM. Even then they're not found on the E main pivot, so it still becomes necessary to disassemble the swing arm for maintenance.
Gotcha.
Originally Posted by Pezz_gs View Post
PhiSig
They are a direct bolt on replacement, but they are deeper than stock. I havent fitted them as yet, but they will be installed soon
I have been told they are much stronger than the stockers and unsure if a brace is necessary. . . . I will post pics as it comes together.
I will be running the 17LT safari tank too.
Sounds good, I'll check back when you've got them installed and see what the consensus is on a guard.
Which one of you FF's was it?...FOUNDER!
Entia non sunt multiplicanda praeter necessitatem
PhiSig1071 is online now   Reply With Quote
Old 11-13-2013, 08:01 AM   #21003
The Recycled Teenager
The Recycled Teenager's Avatar
Oddometer: 532
Originally Posted by focallength View Post
Are you doing the bearings, or just lubing it? If its just lube you dont need to pull it, jus mallet out the swing arm bolt. If your doing the linkage an impact wrench is all you need to loosen the bolts. As far as the bearings, I just pay a shop $10-20 to prees them out/in. its not complex, a breaker bar will loosen the linkage, but you have to retorque them along with the swing arm bolt.
When I pull the bolt, I use a dowel and a mallet to smack the bolt out, slather it up and smack it back in. if you dont have a trained monkey to hold the swing arm in line it requires some finagling, but its doable solo.
At this point I am hoping just to re-grease everything and check for wear, I have 5,000 kilometres on the clock and thought it should be looked at.
Its an 09 but did not see the road till 2011, I got a deal on it as the dealer wanted a quick sale at the time.
I have the tools but in case I need to change any bearings I remember seeing some home brewed tools for removal etc so hence the request on the group.
A good time to keep your mouth shut is when your in deep water
2009 DRZ400S 2000 BMW 1150GS 1976 TY 175 2010 Beta EVO 250
KLR 650-sold
1977 BMW R100-sold
The Recycled Teenager is offline   Reply With Quote
Old 11-13-2013, 09:43 AM   #21004
Oddometer: 532
Regarding the reinstall perhaps a wooden dowel at the other end as you put the bolt back in, it would knock out the dowel as it works its way through but all should be in a alignment then perhaps
KLR 650-sold
1977 BMW R100-sold
Old 11-13-2013, 12:33 PM   #21005
markjenn
Oddometer: 10,483
Originally Posted by dmage View Post
This is probably a dumb question, but is there an issue running 90/90 21 front instead of the 80/100-21?
You've gotten a couple of answers about what the numbers mean, but not sure you have an answer to your question. The 80/100 is stock fitment and a bit of an odd size - its available, but not common. 90/90 is very common with a much wider selection of rubber. Folks run the 90/90 all the time and I haven't heard of any problems. Practically speaking, it's just a very slightly wider tire with essentially the same sidewall height.
- Mark
Old 11-13-2013, 05:26 PM   #21006
blackjackdavey
blackjackdavey's Avatar
Oddometer: 272
is there a thread or does anyone have a good list of good lights options?
riding at night is impossible with the stock light, can't see anything past the fender, especially since i put the fender bag on as well
i read some mixed reviews about Acerbis Cyclops Headlight. some cheaper ones are probably no better than stock, what else is the good option?
thanks!
advriding.tumblr.com
blackjackdavey is offline   Reply With Quote
Old 11-13-2013, 06:56 PM   #21007
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 4,030
thanks!
http://www.bajadesigns.com/products/...orcycle-lights
DR-Z440E 00 - DR650SE 02.
Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY".
DR650SEDDY is offline   Reply With Quote
Old 11-13-2013, 11:56 PM   #21008
peteandheidi
Oddometer: 403
The best bet is to use a leak down tester at various pressures and piston positions.
What other position then TDC would be beneficial to use???
peteandheidi is offline   Reply With Quote
Old 11-14-2013, 12:43 AM   #21009
dmage
dmage
dmage's Avatar
Oddometer: 44
Thanks for the replies on the tyre sizes. Looks like it will be the 90 90 -21 in the garage
dmage is offline   Reply With Quote
Old 11-14-2013, 05:33 AM   #21010
oldenuf
Oddometer: 494
rim width
A tire profile is made for a specific rim width. The rim measurements are stamped on the rims. This tire information is usually available at the tire manufacture web site and from many retailers. There is a range of sizes for each width. The DRZ seems to do handle OK with a variety of tires and sizes that I have tried, and some even say it's OK with sizes not made for the rim width.
oldenuf is offline   Reply With Quote
Old 11-14-2013, 06:38 AM   #21011
George 99
George 99's Avatar
Oddometer: 786
thanks!
A little pricey but ya get what ya pay for: ADVMonster, Sanjo, has a nice set up. He's a vendor on this site. I have his fairing and lights on my 400.
George
Sometimes in Kingman, Arizona
George 99 is offline   Reply With Quote
Old 11-14-2013, 07:01 AM   #21012
Starchamp
Rebel Scum
Starchamp's Avatar
Oddometer: 1,100
thanks!
Yes, you do get what you pay for, but that doesn't mean you have to over-pay for something you don't really need. The TrailTech X2 comes in Halogen or HID flavors (or a mix, if you prefer), and is virtually plug and play on the DRZ (and an order of magnitude brighter). Then there are plenty of LED auxilliary lights that you can add if you want to keep the stock headlight (for DOT inspection purposes, for instance). For example, the Vision X Solstice series are very effective, relatively inexpensive, and don't put a huge strain on the electrical system.
Starchamp is offline   Reply With Quote
Old 11-14-2013, 10:12 AM   #21013
Plane Dr
Plane Dr's Avatar
Oddometer: 878
I went with a DDM HID kit in the stock housing (when I used it) the current lights I use are 2 from Sanjo, also have 2 from him on the GS. Pretty good so far and quite reasonable for LED's.
01/09 DRZ470SSW more bits than necesary
2005 R1200 GS AKA The Mothership
2003 Z1000 Nuclear Pumpkin (gone)
86 RG500WW (gone)
Bikes are like women. What you think you want, and what you want, change after the first ride.
Plane Dr is offline   Reply With Quote
Old 11-14-2013, 10:26 AM   #21014
Mtn Man
Mtn Man's Avatar
Oddometer: 210
Looking for lowering pegs for a DRZ ... Ideas??
Yes I know about ground clearance and those matters but I need a little lower peg.
Can't win a horse race yelling whoa!!
DR 650
GS Adventure
DRZ 400
Harley Road Glide
Mtn Man is offline   Reply With Quote
Old 11-14-2013, 12:21 PM   #21015
Starchamp
Rebel Scum
Starchamp's Avatar
Oddometer: 1,100
I don't think you can get there from here, without some custom fab. I went with a taller seat and bars to get the ergos right.
Times are GMT -7.   It's 03:50 PM.
