Old 11-12-2013, 06:30 AM   #6661
trussman
Oddometer: 19
I don't see why you should have any problem. I have ridden mine further at a time at higher speeds with no issues except my butt numb.
Sent from my PC36100 using Tapatalk 2
trussman is offline   Reply With Quote
Old 11-12-2013, 08:27 AM   #6662
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,330
Originally Posted by Cfk View Post
Ok,bike at the dealers mechanic,will be repaired under warranty,they will also change my sprocket to 13t,free of charge,(I have supplied sprocket).not bad outcome overall,except I'm without a bike for 3 days....
I do have a question to fellow riders.
I'm going away for Xmas to pretty awesome area with endless trails...wich is 400 km away.im thinking about riding my bike,( behind a car with my family in it).is it too much for that little bike to handle 400 km 100km/h.?
My bike only done 250 km so far.
Cheers
P.s. Providing my ass can handle 400 km...
Your bike will handle it fine. 400km/258m isn't that terrible. Your butt is the real question on how it will hold up!
If your bike is brand new with only 250km so far, then change the oil before you go since you'll probably go past the first recommended oil change on that trip. 400km + 400km + miles you ride on the trail.
BlueLghtning - Follow me on my SPOT Messenger
Mine: KTM 650 ADV (Katuki), 09 DL650, 08 Husky TE610, 08 WR250R
Hers: 07 Ninja 650R, 13 CRF250L
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning is offline   Reply With Quote
Old 11-12-2013, 02:27 PM   #6663
SAPB
SAPB's Avatar
Oddometer: 1,615
Searching ADV local stuff...
But, came across this, not local, but pretty nice riding. Not my vid, no idea who these folks are...........Snow here this morning, bummer. Longish vid, but worth a look.
http://www.youtube.com/watch?v=mxDBgys2p24#t=332
C14 - CRF250L, always cleaned while it's raining
CRF250L Service Manual http://www.hondampe.com.au/docs/owni...F250L13_OM.pdf
SAPB is offline   Reply With Quote
Old 11-12-2013, 02:58 PM   #6664
Cfk
Oddometer: 83
Thanx for reply.I will do first service before we go away,will try clock 1000 km,shouldn't be a problem.
Got b&b bash plate on it and honda cargo rack,13t sprocket and deciding on alloy bars and hand guards... Too many options out there.
B&b bashplate looks sick.highly recommended.
Cheers
Cfk is offline   Reply With Quote
Old 11-13-2013, 07:13 AM   #6665
Auto-X Fil
Oddometer: 684
Cheers
Nope, only one choice: http://www.highwaydirtbikes.com/HDB_...=handguards_00
They will sell you ProTaper bars already tapped and with inserts installed.
Reasons to get HBD's setup:
1) The handguards mount to the triple clamp, so they are far less likely to bend your bars, and won't rotate.
2) The handguards mount to a tapped and threaded hole in the bar end, instead of using an expander plug. This makes for a much stronger connection that again, won't spin.
3) The mirrors!!!
Auto-X Fil is offline   Reply With Quote
Old 11-13-2013, 08:53 AM   #6666
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,263
Talking The LRP does Baja!
Having an unexpected break in my current work on tour we decided to go to Baja and ride some of the Baja 1000 course during the pre-running. About 1400 miles in about 4 days with lots of dust, rocks, tequila and tacos.
The little Honda that could performed great, ran strong even with questionable brown Mexican gasoline, had no issues with the terrain or long highway miles to get there and back with the new windscreen making those long days mo' better for Nancy. Couple of things got bent but nothing we couldn't just bend back on the trail.
Go LRP (and Nancy) !
Lost Rider is offline   Reply With Quote
Old 11-13-2013, 09:02 AM   #6667
wolftrax
wolftrax's Avatar
Oddometer: 463
OK Lost, love the pix. Nice to see the LRP in action. Is the screen a DIY?
2014 Honda CRF250L
2013 Husky TR 650
1990 KLR650
wolftrax is offline   Reply With Quote
Old 11-13-2013, 09:29 AM   #6668
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,263
Yes, I made the screen(s) from a .177" Kydex ABS sheet purchased on Amazon using the oven, a heat gun and a dremel.
Heated the sheet in the over @ 275 till it was pliable, formed it into the OEM headlight mask, bolted it on then shaped the top with a heat gun, trimming as I went with the dremel. Kind of used the same shape on the top as found on the BMW G650GS screen.... Hello Kitty!
No wind on the chest, helmet in clean air... somehow it worked out perfectly.
Old 11-13-2013, 09:35 AM   #6669
Vspec
Vspec's Avatar
Oddometer: 161
Why no HDB mirrors on the LRP?
Vspec is online now   Reply With Quote
Old 11-13-2013, 09:45 AM   #6670
SAPB
SAPB's Avatar
Oddometer: 1,615
Originally Posted by Lost Rider View Post
Got to be racking up the mileage on the LRP, do the 2nd valve check yet?
Old 11-13-2013, 09:46 AM   #6671
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,263
Because Nancy forgot to fold them in on a ride and broke them, HDB never responded to me when inquiring about buying new ones... and you can't just order the mirrors by themselves off their website.
But the most important reason is she has poor eyesight and never could see well with the HDB mirrors, the much larger Double Take mirrors in the more "standard" position gives her much more confidence of seeing what's going on around her on the street.
While deciding/waiting on what to do about new mirrors I put the OEM ones back on, she said " I can see again!"
I knew that Double Take was the way to go for her, riding on dirt with the OEM mirrors is just asking to break things.
I personally love the HDB mirrors on my bike, but I have excellent eyesight.
SAPB:
No we haven't, I just changed the oil/air filter again and tightened up a few loose bolts. My injury earlier this year has kept the miles down on both our bikes, hopefully this winter we'll get some more seat time, for now it's time to work and Baja was just a short adventure to hold us until I get home again after xmas.
Lost Rider screwed with this post 11-13-2013 at 09:51 AM
Old 11-13-2013, 10:15 AM   #6672
Kray
Kray's Avatar
Oddometer: 959
Leg #1 of the TransAm Trail is scheduled for this weekend on the LRP
Current: '15 WR250R Build Thread
Previous: '14 CB500X | '14 CRF250L
Kray is offline   Reply With Quote
Old 11-13-2013, 10:35 AM   #6673
SAPB
SAPB's Avatar
Oddometer: 1,615
You doing the whole TAT? I researched it, some sections in CO, I believe, are only passable for short periods of time. Keep us posted.
http://www.transamtrail.com/
Old 11-13-2013, 11:13 AM   #6674
Kray
Kray's Avatar
Oddometer: 959
SAPB, no, unfortunately time/money simply wont allow for the entire journey. A friend and myself will be knocking out sections over the coming months/years.
I'll be documenting each section as we accomplish them. We are fortunate enough to live 1.5 hours from the starting point in TN. I currently have a virtually stock CRF250L and he'll be riding a slightly modified DRZ400. With only my backpacking and dirt bike skills to help me along, we've scheduled Leg #1 for November 16, 2013 - this coming Saturday.
Old 11-13-2013, 11:37 AM   #6675
SAPB
SAPB's Avatar
Oddometer: 1,615
[QUOTE=Kray;22770728]SAPB, no, unfortunately time/money simply wont allow for the entire journey. A friend and myself will be knocking out sections over the coming months/years.
Well, you certainly picked the right ride for it. A few years back, my daughter and I rode our bikes from here, to Albuquerque. That was nice, but what you are doing will be way better, I'm jealous. Ride safe!
Times are GMT -7.   It's 11:05 AM.
