Old 11-04-2013, 05:28 PM   #316
johnson357
Bad Monkey Racing
johnson357's Avatar
Oddometer: 1,283
Have you fit one on a Honda XR650L?
johnson357 is offline   Reply With Quote
Old 11-04-2013, 05:35 PM   #317
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,491
I'll help on this
Marko
08 xr650l ,99 xr650l, 10 HDXR1200X ,84atc200s 85atc200s, 80ct110 ,99xr70, 04xr650l ,
Dumb ass people do dumb ass things
thebigman is offline   Reply With Quote
Old 11-04-2013, 05:43 PM   #318
johnson357
Bad Monkey Racing
johnson357's Avatar
Oddometer: 1,283
Thx bigman, happen to have a pic of the mounts? I would like a little more straight up and down to it is why I ask.
Old 11-04-2013, 06:26 PM   #319
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,491
Sure , here ya go , for a straight up vertical mount , I think all you would need is 2 pieces of flat stock at whatever length to push the fairing out as far as you want , it mounts to the stock mount ,
Or swing the bottom in and put in on the oe bracket that the headlight slides onto , it should go any way you want it with no problems .
Marko
Old 11-04-2013, 06:42 PM   #320
johnson357
Bad Monkey Racing
johnson357's Avatar
Oddometer: 1,283
Thanks a bunch, they should give you a discount on you next one because you've help sell me on one.
Old 11-04-2013, 06:50 PM   #321
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,491
It's all good , Glad I could help .
Marko
Old 11-05-2013, 01:29 AM   #322
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,045
Originally Posted by canadius_maximus View Post
Take a 60 light for wide and a 50 or 30 for high beam? Is that how most folks go for the 690?
Most customers are using a pair of 60s.
Originally Posted by kbuckey View Post
Hmmmmmmmmmmmmmmmmmmmmm, that CRF250 gets me thinking about my KLX 250. Like the Dual Sport Fairing on my DR650. Wonder how one would fit on the KLX. Probably put it lower than on the DR since I ride it more in the dirt. Hmmmm. Don't know if I'd need two 60s in it....
My wallet really has a hard time with your sites, John.
Thanks TBM
Everybody gets a discount "inmate" promotion code get's you 10% off everything at www.advmonster.com
Old 11-05-2013, 07:02 AM   #323
johnson357
Bad Monkey Racing
johnson357's Avatar
Oddometer: 1,283
[QUOTE
Thanks TBM
Everybody gets a discount "inmate" promotion code get's you 10% off everything at www.advmonster.com[/QUOTE]
Shut the Front Door, AWESOME
Now finally I can use the line my wife uses, "It's soooo on sale it would be losing money not to buy it"
Old 11-05-2013, 07:56 AM   #324
tilliejacques
tilliejacques's Avatar
Oddometer: 364
Originally Posted by sanjoh View Post
Boy, it looks like there's no more room in front of the display than with the OEM headlight shroud. Can the fairing be installed more vertically on the 250L? Or is it at the max of adjustability as it is in the pic?
Or maybe you moved the display??
I'd really like to put the gps between the display and the fairing.
cheers
11 Husky TE250
08 Beta Rev3 125
tilliejacques is offline   Reply With Quote
Old 11-05-2013, 09:36 AM   #325
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,045
Female logic is not to be argued with
There is room to mount a gps between the triple and the gauge but it will be a challenge with the brake line.
The gauges are mounted on a custom bracket as far forward as possible. The amount of weight just to hold the gauge on is amazing.
Removed gauge subframe
Removed lower headlight mount
Old 11-06-2013, 04:19 PM   #326
cheeseyboy
Oddometer: 321
With a pair of the m15 led's, is a relay necessary? How bright would these be for occasional street use? And is the rotary dimmer weatherproof? Thanks.
cheeseyboy is online now   Reply With Quote
Old 11-10-2013, 07:41 PM   #327
whtoyotek
whtoyotek's Avatar
Oddometer: 24
Mounted on my DR650 .........AWESOME PRODUCT!!!!!!
I finally got around to submitting pics of the fairing and lights on my DR650. All I can say is wow,it's like I strapped the sun to the front of my bike. I purchased the fairing and two model 60 flood lamps with one strap kit for fork mounting since I do not have the stock forks on my bike. I intend on using this bike for travelling and one thing that has always bothered me on all of my bikes has been poor lighting when I've been away from home and this thing definitely rocks in that department. So far the wind protection has definitely been adequate. I didn't want a huge windshield strapped to my bike so this is definitely a great compromise.
One of the things I wasn't clear on when purchasing was how the dimmer was adjustable. They provide a remote that allows you to change the brightness of the low beam to your liking by hitting a couple of buttons. You can also turn it fully off which helped me out of a jam when my battery went low the other day.
So far no one has flashed me so I must have it adjusted fairly well.
I will submit pics in a little bit as I'm having an issue with photobucket right at the moment. It will be tonight.
Again thanks for the great product I hope to take many adventures with it
whtoyotek screwed with this post 11-11-2013 at 04:53 AM Reason: adding pictures
whtoyotek is offline   Reply With Quote
Old 11-11-2013, 04:56 AM   #328
whtoyotek
whtoyotek's Avatar
Oddometer: 24
pics
Old 11-11-2013, 04:48 PM   #329
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,045
Looks great
Old 11-16-2013, 04:05 PM   #330
Dell_dude
Dell_dude's Avatar
Oddometer: 199
Has anyone fashioned any kind of ABS or aluminum dash to work with these yet?
Seems like it would be the perfect place for mounting switches or GPS type items.
DeLorme inReach SE tracker
Dell_dude is offline   Reply With Quote
Times are GMT -7.   It's 05:47 AM.
