Old 08-27-2013, 11:29 AM   #226
KrAzyOSUcOwBoY
kRaZy
Oddometer: 126
Thanks all for your replies, its beginning to make sense now.
KrAzyOSUcOwBoY is online now   Reply With Quote
Old 08-27-2013, 12:26 PM   #227
LowPSI
Oddometer: 277
I would leave the final exhaust tip restrictor on. Removing it makes the bike much louder and only adds 1/4 hp at full throttle. Or install a DB killer.
LowPSI is offline   Reply With Quote
Old 08-27-2013, 11:03 PM   #228
jonnyc21
Trials Ninja
jonnyc21's Avatar
Oddometer: 1,064
Question Hmmm...
This is some good info, I need to check if the intake restrictor is still in mine. I got mine from the first owner without lights and don't think he ever did any modifications.
Seeing also that I was in Seattle when I picked it up and now live in Boise it might help it run a bit more like it did down at sea level.
On a side note I have been thinking of adding a headlight back to the bike for the occasional evening trail ride... If I do (still considering it) would this mod let me keep the trials mapping and have lights?
jonnyc21 is offline   Reply With Quote
Old 08-28-2013, 05:29 AM   #229
mud
I just wander.....
mud's Avatar
Oddometer: 1,813
If you use the factory wiring harness (which will also require the switches) it will.
Just pull the pin at the ECU connector and you will be good to go.
2007 Factory Husaberg 380FE
2007 Montesa 4rt
1984 Husqvarna 500AE
mud is offline   Reply With Quote
Old 08-28-2013, 11:09 AM   #230
jonnyc21
Trials Ninja
jonnyc21's Avatar
Oddometer: 1,064
Thanks for the response. Guess I need to figure out if I really want a head light now.
Old 08-28-2013, 02:54 PM   #231
mud
I just wander.....
mud's Avatar
Oddometer: 1,813
You could also just cut the right wire in the wiring loom you put on for the lights.... We can help you with this.
2007 Montesa 4rt
Old 11-17-2013, 11:38 AM   #232
jonnyc21
Trials Ninja
jonnyc21's Avatar
Oddometer: 1,064
Have a Johnson over in a diffrent thread asking this question... Anyone have a picture of the exhaust restrictor of a 4rt? Is it threaded?
Thread link http://advrider.com/forums/showpost....postcount=1889
Old 11-17-2013, 07:26 PM   #233
BucketHead
Would-Be Camel Man
BucketHead's Avatar
Oddometer: 231
No pics, but none of the three are threaded.
BucketHead is offline   Reply With Quote
Old 11-18-2013, 02:14 AM   #234
Thats_a_Five
Oddometer: 56
Rear Brakes
Yes, I had the same thing happen on mine, except I noticed the extra drag before it caught on fire. It was seriously hot though. This was on the second loop of an event right after I got my 4RT this summer.
Fortunately, I was able to back off on the stop bolt allowing pedal to come back up a little higher. The brake pedals sometimes get bent in against the clutch cover so that the pedal does not come up fully leaving the pads in contact with the disc, creating lots of heat.
I see that you ride up at Walker Valley. There are several guys in Puget Sound Trialers club that have 4RT's. You guys ride any PST events?
Originally Posted by turnsleft View Post
Took my new to me 4RT out for a ride this afternoon. Lets see, start on 2nd kick, check; wheelie over a few ruts, easy; climb a hill and hop a rock at the top this is fun. OK, now back tire stops with a screech, WT* see disc brake red and on fire. Didn't see that in the manual. Thought I must have a stick or some such sh*t holding the brake pedal. nope. Rode back to truck and put a bit more slack in the pedal and bled off some fluid. Seemed beter, any one else have this happen to their 4RT?
Thats_a_Five is offline   Reply With Quote
Old 11-21-2013, 09:22 PM   #235
turnsleft
turnsleft's Avatar
Oddometer: 1,540
Wetsiderider[Dan] and BrianJones rode some of the events. Dan sold his[4RT] and Brian seems to work alot.
What has been seen can not be un-seen
turnsleft is offline   Reply With Quote
Old 11-21-2013, 09:57 PM   #236
jonnyc21
Trials Ninja
jonnyc21's Avatar
Oddometer: 1,064
Just a bit before I moved to ID I picked up Higgins 07 4RT and then took it to Straddleline this year... (miss it out there already) I will have to try and make it out for at least 1 event next year if I can...
Old 11-25-2013, 01:56 PM   #237
brianjonesphoto
Single Track Noob
brianjonesphoto's Avatar
Oddometer: 1,564
Hi Captian
I'm still around, but don't have much free time to ride these days between work and baby. I am planning to hit walker tomorrow on the ol' montesa. PM me if anyone's interested.
Brian
Mine: 07 DL650 ABS, 99 DR350SEx, 05 Montesa 4RT Her's: 02 KL250 Super Sherpa
www.PhotoSupportNW.com
brianjonesphoto is offline   Reply With Quote
Old 11-25-2013, 02:13 PM   #238
jonnyc21
Trials Ninja
jonnyc21's Avatar
Oddometer: 1,064
Wish I was in Seattle still would love to ride Walker on my Montesa. Such is life...
Old 12-13-2013, 02:10 PM   #239
jerbelgium
Oddometer: 44
just a short 4RT Repsol '06 question: here is one for sale, but what do I need to look for?
any specific things that makes it a standard or Repsol (besides the stickers)?
what about the '06 model? ok, or should I go for a newer 4RT? what are the main differences with '07,'08,'09 etc?
thanks for your short and fast feedback
jerbelgium is offline   Reply With Quote
Old 12-13-2013, 03:23 PM   #240
johnson
Oddometer: 157
plate near headstock with number
carbon fibre bits (headlight, fork guards, clutch cover guard...)
programable throttle body
johnson is offline   Reply With Quote
Times are GMT -7.   It's 02:47 PM.
