Old 11-26-2013, 10:50 AM   #151
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
Originally Posted by USAIR View Post
Liked the way you framed the BMW symbol in there too.
That was a total fluke. But I'll take credit for it anyway.
Emmbeedee is online now   Reply With Quote
Old 11-26-2013, 11:11 AM   #152
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
Nice of Garmin to add "Remote" capability to the ancient Oregon 550 so it can be used with the VIRB.
Old 11-26-2013, 11:18 AM   #153
Hellfish
Oddometer: 36
Dashboards
Can you mix and match the dashboards? In other words, can you choose altitude, speed and temperature for motorcycle rides then use cadence, heart rate and speed while mountain biking? Being able to make custom dashboard profiles would be great but it seems like they are preset.
Hellfish is offline   Reply With Quote
Old 11-26-2013, 12:26 PM   #154
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
Not really sure what you're asking here. Are you saying one movie with different activity types in the same movie?
Each video you work on in VIRB Edit has only one Dashboard style. The video can be a composite of multiple videos but it still only has one possible Dashboard. There are ways around this, of course: make multiple movies with appropriate Dashboards, export them, then create another movie by combining them in some other program.
Old 11-27-2013, 06:49 AM   #155
THRASHED
Moving on Up
THRASHED's Avatar
Oddometer: 345
So my Virb Elite showed up yesterday. I got home late, installed the memory card and the battery and plugged it in. The charge light showed Green so I turned it on. I saw that it was a setup screen and just turned it off because I was tired. This morning I picked up the camera and turned it on. I get the Garmin logo on the screen, then it just starts this long "beep" tone. It will not stop until I pull the battery. I thought, even though the light is green, that it may have been a low battery but when I plug it into my USB to charge it, the camera turns on and starts beeping.
I will call Garmin first thing when they open but I thought I'd try here on the off chance that you are awake and are obsessive about reading this thread.
THRASHED is offline   Reply With Quote
Old 11-27-2013, 07:24 AM   #156
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
Maybe you should try the factory reset procedure?
To perform a master reset:
Ensure the device is powered off
Press and hold Down
Press and immediately release Power
Wait for the message "Erase all user data?"
Release Down
Select Yes
The device should now be reset to default factory settings, all user data should be removed, and the device should function as expected.
Old 11-27-2013, 07:53 AM   #157
THRASHED
Moving on Up
THRASHED's Avatar
Oddometer: 345
Thanks for the info, but it doesn't work. I hold down, press and release power and the Garmin logo comes on the screen but nothing else. When I release the down button the beep starts. Also, as it is starting up the green light will flash Orange for a split second. Here's what I was about to post:
UPDATE:
Just got off the phone with Garmin. They've never heard of this issue...go figure. They are sending me a shipping label for an exchange. What really sucks is I spend $30 for next-day shipping to get it yesterday in time for this weekend when my kids will be riding dirt bikes for the first time. I have two other possibilities: One, if it is the battery I can use the one from my Montana (I can live without it this weekend) and Two, maybe Bass Pro Shops got some in stock and I can stop by on the way out of town and swap it out.
I did manage to get it plugged in, while holding down the MODE key and it's not beeping. My thought is that it's possible (though not probable) that the battery is completely dead. I will let it charge for a while even though the charge light is green and see what happens.
I'm not sure the guy at Garmin really understood how disappointed I am with this situation.
Old 11-27-2013, 08:50 AM   #158
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
That would be the next thing to try - your Montana battery.
I can understand how disappointed you are.
Old 11-27-2013, 09:30 AM   #159
Hellfish
Oddometer: 36
I would just like to know if the dashboards are customizable. It looks like you choose from several preset ones when it comes to the info displayed. For example, I might want to display oddball information like temperature and cadence on the same dashboard.
Old 11-27-2013, 10:14 AM   #160
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
It doesn't look like you can change what information goes into whatever field is in the Dashboards at the moment. You can change the colours, but that's about it. I would imagine Garmin's going to be making more changes to VIRB Edit in the future. It's fairly basic right now.
I wouldn't even mind buying a "Plus" version of VE with more capabilities, if that became available.
Old 11-27-2013, 11:25 AM   #161
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
UPDATE:
Interesting... Sounds like many others have already had similar issues with their new VIRB's.
Amusing quote from above linked article:
Garmin VIRB Quirks:
Here's an interesting fact: the file system in our VIRB has folders listed as "GoPro". The "version.txt" file has an entry that reads "Hero3-Black Edition".
Could the video engine have been developed for Garmin by GoPro?
Note that just under the "DCIM" folder that holds the video files, a folder named "100GOPRO" is automatically created to store the video files.
atlas cached screwed with this post 11-27-2013 at 11:38 AM
atlas cached is offline   Reply With Quote
Old 11-27-2013, 11:46 AM   #162
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
Snow day today...
Old 11-27-2013, 03:18 PM   #163
Mastery
Mr. Funny Man
Mastery's Avatar
Oddometer: 1,257
So it does seem to work.
Thank you for the detailed write-up on this feature, much appreciated.
I'm about ready to just flip a coin on either this or the Ghost. Maybe I'll just get one of each and make my own determination. Just need to find some good sales over the next two days, and I'll probably go ahead and do a side-by-side for my own needs.
Mastery is online now   Reply With Quote
Old 11-27-2013, 08:58 PM   #164
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
Not sure how you get 'many others have had similar issues' from that review?
I don't see any folders or references to GoPro in any files on my card.
Sent from my Nexus 7 using Tapatalk
Old 11-28-2013, 12:04 AM   #165
RexBuck
Oddometer: 1,033
I'm torn between these two also. Leaning to the Ghost (or Ghost S if it is being shipped soon) as it records in .mov format, already has a remote that doesn't seem to have a lot of problems and the twisty lens thing.
I might lean a bit more to the Garmin if I was using one of the GPS units that could link up with the camera. My Zumo has some features not offered in the handhelds and I not prepared to forgo those. For me, the internal GPS in the camera isn't something I would use.
Thanks to EmBeeDee for all the reviews and videos on this camera. Sure makes it clear what it is about.
www.rexbuck.com - RexBuck's Latin America
Information on travelling in Latin America.
Includes links to ride reports to Mexico and to South America
RexBuck is online now   Reply With Quote
Times are GMT -7.   It's 04:56 PM.
