Old 11-27-2013, 02:33 PM   #1
SculptD OP
Smells like tech
Oddometer: 472
My first gearbox...
Okay, flame if you must. I am completing my first gearbox overhaul. Didn't send it to a guru. Hey, a guys got to do his first one sometime, right?
Things seem good. Shims in, cover on. Everything rotates with just the right feel of not-too-tight, not-too-loose. But in running through the gears, while I can get them all, I am also getting false neutrals, and here and there it takes an extra click-clunk to get into gear.
Is this just a fact of life when hand rotating and shifting? Or, what do I need to go back and adjust? Gurus! I need your help after all!
Side note: I used two methods for shim measurement, the typical machined plate and calipers route, and the mold-a-gauge from Cycle Works. I believe solder is a flawed method. Details to follow...
R75/5 SWB, Aprilia Falco. Both compulsively modified. And an R100s is on the way.
SculptD is offline   Reply With Quote
Times are GMT -7.   It's 06:13 PM.
