Old 11-28-2013, 07:22 AM   #166
Jon_PDX
Oddometer: 1,114
Originally Posted by THRASHED View Post
So my Virb Elite showed up yesterday. I got home late, installed the memory card and the battery and plugged it in. The charge light showed Green so I turned it on. I saw that it was a setup screen and just turned it off because I was tired. This morning I picked up the camera and turned it on. I get the Garmin logo on the screen, then it just starts this long "beep" tone. It will not stop until I pull the battery.
That's really strange….and of course a real bummer.
It makes me wonder if you had gone through the setup if it would have continued to work. I doubt it would have made a difference but I've seen stranger things happen before.
Hopefully the replacement will be perfect and you'll be enjoying the new camera for a long time.
Jon…
Bikeless at this time
Past Bikes.....Check with my Wife.....I've lost count :-)
Jon_PDX is offline   Reply With Quote
Old 11-28-2013, 07:24 AM   #167
Jon_PDX
Oddometer: 1,114
Originally Posted by Emmbeedee View Post
Snow day today...
Frank Zappa….perfect choice
Jon…
Old 11-28-2013, 07:26 AM   #168
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
I wondered that as well. The first thing you need to do when you start it is let it see the skies to find the gps signal which gives it time and location information. But it would be a pretty catastrophic failure if aborting that process killed the unit.
Old 11-28-2013, 08:56 AM   #169
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
FZ: the perfect choice for all occasions.
Old 11-28-2013, 09:15 AM   #170
USAIR
picking and riding
USAIR's Avatar
Oddometer: 1,570
Mine showed up yesterday...too many family things going on now will play with it later.
But here's a photo.......(bad photo)
The ball between the micro card adapter and the Virb.
This is an item I added it makes the Virb compatible with Ram Mounts.
All I did id turn the screen on and then charged it up.
Right off the bat I noticed the screen is not back lit....I think I knew that.
It was very hard to see the screen.
Not I just got the thing so it might not matter.
I got to use the thing before I really can comment.
I think I will chase the wife around with it later........after a few bourbon balls
Fred
2013 WR250R 2007 Wee
www.riverbendphotos.com
YouTube feed
Wallpaper for Montana GPSr
Beware of the Wallnut
USAIR is offline   Reply With Quote
Old 11-28-2013, 10:49 AM   #171
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
Glad to hear there will be more than me commenting on it soon!
Old 11-28-2013, 02:29 PM   #172
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
A couple of Winter pics from the VIRB.
Old 11-28-2013, 03:49 PM   #173
arraflipper
Oddometer: 460
Ordered one
It is your fault showing all the great things you can do with a VIRB. Looked on GPS City and they had an Elite camera with a bundle of things on sale. Not sure what I need but to much is always better than not enough, right.
arraflipper is offline   Reply With Quote
Old 11-28-2013, 04:53 PM   #174
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
Go ahead. Blame me.
But you're right - too much is often better. I always kick myself after ordering, thinking I should have got a few more items...
Old 11-28-2013, 06:25 PM   #175
Jon_PDX
Oddometer: 1,114
WOW…. you sure went from Spring to Winter quick. Our first snow down here is usually gone in less than 1/2 a day.
On the other hand, folks here freak out and they close the schools if it's only 1" of snow so maybe it's good that our first snow does not last long
Jon…
Old 11-28-2013, 07:21 PM   #176
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
Yes, we were socked in by about 12" of snow overnight on Tuesday. No worries, it'll all be gone by next March.
Old 12-01-2013, 11:34 AM   #177
kave
Gravel rules
kave's Avatar
Oddometer: 506
Garmin Virb Edit, the software that you use with the camera can also be used with any mp4 file. If you have the time correct in the camera and you record the ride with a GPS you can have the same experience as with a Virb.
The below video was shot handheld with an iPhone and I used my bicycle GPS:
KTM 690 Enduro, sold
KTM 950SE 2006, sold
BMW R1200GS 2004, sold
kave is offline   Reply With Quote
Old 12-01-2013, 07:21 PM   #178
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
I knew that but maybe others here didn't. Thanks for bringing it up.
Old 12-01-2013, 07:41 PM   #179
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
I was experimenting with the Time Lapse Video setting on the VIRB and when I brought those videos into VIRB Edit I had no idea what to do with them since they seemed to play so fast as to be useless. Then I remembered the slowdown setting in VE, so after slowing the videos down to 12.5% speed, they started to be useful.
Here's an example. Dreary day but better than nothing...
Old 12-01-2013, 08:07 PM   #180
Dominic49
Oddometer: 28
Test drive with the fancy christmas present I got early.
Dominic49 is offline   Reply With Quote
Times are GMT -7.   It's 11:59 AM.
