Go Back   ADVrider > Riding > Regional forums > Pacific Northwet - Where it's green. And wet.
Old 12-10-2013, 06:27 AM   #1
DC2013 OP
Oddometer: 1
WA State reg again: need both on-road & ORV tags? What about the Discover Pass?
This is mostly a set of questions for tod701.
Ive seen the thread at http://www.advrider.com/forums/showthread.php?t=196982
with many concerned questions and differing opinions. User tod701 was most authoritative, having written many of the laws. Even so, Im still not clear. I'm gonna describe my understanding of the tag and pass requirements, and I'd appreciate authoritative corrections. Anecdotal reports of being cited by DNR or Rangers, or not, are helpful but not authoritative.
Let me take it step by step.
Before getting into it, it's worth remembering that DNR receives funds from the Discover Pass. It is intended to fund state parks. Funds from ORV tabs go directly to ORV facilities.
OK, first: In WA State, You need a street (CYC) registration to ride on the road.
You need an ORV registration to ride on state-managed off-road areas.
Except! Per Tod, vehicles sold from the original manufacturer with street plates are exempt (for now, as of June 2013) from Washington State ORV permit requirements. See RCW46.09.420(6)
http://apps.leg.wa.gov/rcw/default.aspx?cite=46.09.420
So, if you have a dirt bike, used on state land, including but not limited to ORV parks like Tahuya, you need an ORV tab.
If you have a plated bike, and it was originally sold as a dual-purpose bike (examples: Yam WR250R, or KTM 530EXC), then you dont need an ORV tab to ride both road and ORV areas. [But you may need a Disco pass. See below.]
If you have a converted bike, such as a WR250F or CRF450R with a plate, then you need both plate and ORV tab to ride both road and ORV areas. Motorcycles converted for dual use pursuant to RCW46.61.705 must be dual registered. http://apps.leg.wa.gov/rcw/default.aspx?cite=46.61.705
Let me ask about some examples:
1.
Suppose I have an ORV-only registered bike, like a KTM 300SX with ORV tabs. At Tahuya on the ORV trails, I need the ORV tabs, and I don't need a Discover Pass or a CYC registration.
But if I am riding in a non ORV area on state land, like the paved roads leading through Tahuya State Park, then I need a plate and CYC reg, because its a public road. Also I need a Discover Pass. The ORV tabs mean nothing in a non-ORV area.
Question 1. Right?
2.
Suppose I have a dirt bike, like a Yam WR450F, that Ive modified for dual use. It has a horn, flashers, and a WA plate and ORV tabs. At Tahuya on the ORV trails, I need the ORV tabs, and I don't need a Discover Pass.
If I am riding in a non-ORV area on state land, like the paved roads leading through Tahuya State Park, then I need a CYC registration and plate. This example is for a dual-registered bike, so Im good here. I also need a Discover Pass, because it is state land + state road. The ORV tabs mean nothing here.
Question 2. Right?
3.
Suppose I have street-registered dual-sport bike, like a Yam WR250R. I do not have ORV tabs. At Tahuya on the ORV trails, I don't need ORV tabs, because I have a CYC registration on the dual-sport (non-converted) bike. I also dont need a Discover Pass to use the bike on these trails.
But if I am riding the paved roads leading through Tahuya State Park, then I need a CYC registration + plate (which I have in this example) and I also need a Discover Pass.
Question 3. Right?
Q4. What about USFS roads? Do I need CYC+Plate? Do I need an ORV? Discover pass?
In my mind, the Discover Pass is simple:
If you must be street legal to drive/ride where you are at and that is a location where a D-pass is required, then the D-pass is still required regardless of whether or not you have an ORV permit. The Discover Pass implies a use fee for State parks, and ORV tabs dont suffice to meet the obligation. One exception are roads within DNR managed public land, which belong to the county. Discover Passes are not required on county roads. Many ORV trailheads are accessed thru DNR land via county roads. In that case, then no D-pass is required.
I should think of the Discover Pass is just an overlay usage fee, for state parks. It applies to vehicles which must be licensed for the road.
If I transport bikes to an ORV park with a truck, I will certainly need a Discover pass for the truck, regardless as to the registration status of the bikes.
A dual-registered vehicle needs a D-pass anywhere within a D-pass area where the vehicle must also be street legal.
Examples:
State Park roads.
WDFW roads **if you are required to be street legal to use them.
DNR roads **if you are required to be street legal to use them.
Question 5: Is all of this correct?
I'd appreciate clear answers.
I know this has probably been discussed many times, but I'm still not clear.
Thanks.
DC2013 is offline   Reply With Quote
Old 12-10-2013, 06:45 AM   #2
lamotovita
Ageing Adventurer
lamotovita's Avatar
Oddometer: 1,591
Before I would spend any time worrying about all those questions I would just buy all the permits. That's what the state wants anyway.
Beaten paths are for beaten men.
lamotovita is offline   Reply With Quote
Old 12-10-2013, 07:46 AM   #3
layzrider
Layzrider
layzrider's Avatar
Oddometer: 202
National Forests registration requirements
If you have a Washington plated bike, no ORV tag is required or Disc Pass is required in Washington for National Forests. You do need an Oregon orv tag to ride off road on public lands in Oregon.
If you have a Washington non-plated bike, a Washington orv tag is required to ride on public lands in Wa. An Ore orv tag is not OK for a WA bike in WA.
layzrider is offline   Reply With Quote
Old 12-10-2013, 08:53 AM   #4
tod701
tod701's Avatar
Oddometer: 1,032
In Washington State, if you have valid street plates then an ORV permit is not required.
1 (part 1). Yes
1 (part 2). Yes and no. As of September 2013 pursuant to RCW79A.80.080(2)(c) you no longer need a D-pass to drive on DNR or WDFW managed roads.
2 (part 1). ORV tabs are not required, but if you dont have them a D-pass is required.
2 (part 2) See question 1 (part 2)
3 (part 1) If you dont have an ORV permit, then you will need a D-pass.
3. (part 2) See question 1 (part 2)
4 (part 1) To ride on many USFS roads a street plate is required. On some it is not. That determination is up to each forest district to define. If a plate is not required, then an ORV permit is. The D-pass requirements do not apply to federal land.
4 (part 2) Correct - A dual-registered vehicle needs a D-pass anywhere within a D-pass area where the vehicle must also be street legal.
Hope that helps.
Tod
NMA, WOHVA, BRC, AMA, NRA
tod701 is offline   Reply With Quote
Old 12-10-2013, 09:50 AM   #5
Maxacceleration
Awol
Maxacceleration's Avatar
Oddometer: 2,223
This is the most complicated bunch of bs ever. I have never had a ranger or leo that could explain what the hell is going on.
This is all hoops for (minimal) revenue, which IMO we do not see go back into the trails (for maintenance) such as in Oregon.
It is an early step to land closure when the g men (state or fed) say we are not complying so therefore....
There should be ONLY two reg's needed total. One for state land and one for federal land. ONLY, et al. Covering hiking, camping, equestrian, motorized, bicycles and so on.
There should be no favoritism or breaks for any one land user over another.
This is a typical and classic showing of overcomplicated failure of our city, county, state and federal governments to do anything sensible.
Jeezus.
Do I detect some lawyer speak with the OP? Looks like someone is trying to work out a ticket... Nice first post.
Maxacceleration is offline   Reply With Quote
Old 12-10-2013, 10:31 AM   #6
HH
Hurricane Harry
HH's Avatar
Oddometer: 1,611
Jeezus.
HH is offline   Reply With Quote
Old 12-10-2013, 07:22 PM   #7
peterman
cop magnet
peterman's Avatar
Oddometer: 13,886
So,,,
If I wanna ride my bike across Warshington, maybe stay inna motel for a shower one night, then ride on to British Columbia to visit SweetSixty and her home made pies,,how many permits will I be required to show?
Guess!,,,
,,Stop!,,
OH!,,
peterman
___________________________
"Your God, your rules,,YOU go burn in hell!" LLV
peterman is offline   Reply With Quote
Times are GMT -7.   It's 05:08 AM.
