Old 12-14-2013, 01:27 PM   #12646
Arzach
never too old...
Arzach's Avatar
Oddometer: 338
Originally Posted by tyrsmkkyle View Post
There has been no specific dates yet, just that they have not been alerted to shipment :(
I put a deposit as well and have no date for delivery .I could not get answer on simple things like what brand Handlebar on the US models .
KTM is not feeding a lot of info to their dealers , it seems .
in the mean time my 950 in the their floor looking for a buyer .
As long as it comes before the race in Odessa (Wa) I am ok
People sail for fun and no one has yet convinced me
that it's more fun to go Slow than it is to go Fast .Dick Newick
Arzach is online now   Reply With Quote
Old 12-14-2013, 03:59 PM   #12647
mezcal
mezcal's Avatar
Oddometer: 469
Originally Posted by MeinMotorrad View Post
You may have water anywhere. I'd take the seat off and check the state of the air filter and take a look in the box for water too. Check the spark plug and lead as well.
Cheers MM they all looked ok but I cleaned the air filter anyway. Seemed ok inside the air box. Started and idled fine and going for a ride today so hopefully its sorted itself out
2011 Berg 570
mezcal is offline   Reply With Quote
Old 12-14-2013, 05:36 PM   #12648
sieg
sieg's Avatar
Oddometer: 2,932
Dealer called me today.......mid-January shipment.
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 12-14-2013, 06:28 PM   #12649
tyrsmkkyle
off the ground.
Oddometer: 250
Sieg beat me to it. Mid jan indeed.
tyrsmkkyle is offline   Reply With Quote
Old 12-14-2013, 06:33 PM   #12650
mezcal
mezcal's Avatar
Oddometer: 469
Well the bike ran perfectly, aside from one thing.
The odometer reset itself. I unplugged a few things around the battery so I guess that is the reason. Is this something only a dealer can fix, and will the computer know how many km I do after the reset and from before hand?
Sent from my GT-N8010 using Tapatalk
2011 Berg 570
Old 12-14-2013, 06:46 PM   #12651
Hoots
Hoots's Avatar
Oddometer: 1,650
It's funny you say that Mezcal, as mine did the same during its trip to Terry ...
Be interested to know if there is a way to reset it ...
Hoots is offline   Reply With Quote
Old 12-14-2013, 06:51 PM   #12652
Just_P_Dirty
Its more fun when Dirty!
Oddometer: 290
Originally Posted by dirty_sanchez View Post
Team- I finally had a spare day to put her through the paces after flipping the fork tube 180 degrees so that the dot is on the opposite side from stock (changed to the 12 o'clock position) to decrease the trail.
As I mentioned earlier, the bike would get headshake from hell at higher speeds at the fork tube position as delivered from the factory.
Start to finish, it took about 2 hours to get the front wheel, fork legs, headlight, top triple off of the bike.
Once you loosen large aluminum nut found under the front fender of the bottom triple it allows access to the fork tube. Gently tap it out, freeze it, and insert it 180 degrees from the stock position. That's it.
Now would be the time to properly grease the headset bearings if you haven't already done so.
Everything was reassembled and torqued to
I am planing to do this soon and i dont have the service man- what torq specs did u use? what did you mean about freeze it and put back in?
thanks
Dirty
Just_P_Dirty is offline   Reply With Quote
Old 12-14-2013, 06:58 PM   #12653
mezcal
mezcal's Avatar
Oddometer: 469
Mine only went back to 000000 km after I unplugged some cables last night. Yesterday it must have been fine as I went out for a 60km loop, this morning when I started it I noticed it was at zero km...
Must have been a coincidence, or did you drive through heavy rain then unplug all the wiring because your bike was coughing and spluttering too :)
Im sure I read somewhere that it can be fixed and the original distance on the odo isn't lost.
2011 Berg 570
Old 12-14-2013, 08:25 PM   #12654
mezcal
mezcal's Avatar
Oddometer: 469
Pirelli MT21 rear isnt handling the rocks as well as the 606 did...
3 other Centre knobs like it too :)
Probably about 500km old
2011 Berg 570
Old 12-14-2013, 08:30 PM   #12655
travelingaustralian
Globe Trotting
travelingaustralian's Avatar
Oddometer: 98
Goes like stink but Stalling off idle. Other wise Love this bike!!
After buying my new ktm 690R almost 6 months ago while still living and working down in Antarctica, I had a chance to ride it for the first time. Can anyone suggest a good tuner in the Melbourne area? Bike is running like crap! On the Advanced setting it stalls runs rough and dangerous off idle with the bike stalling and locking up the rear wheel. It has had mapping installed to suit the changed exhaust and air intake. When I changed the setting to 0 and did the 15 minute idle from cold reset bike run great? I did this because I read others that had done this and there bike ran ok. 0 is for bad fuel? Why does it run so well on this setting? What is it going to do to the bike long term as they say only to run it on one tank?? The bike has had filters cleaned and the tank was drained and new fuel as it has sat for a little while. I have just finish fitting the Rally Raid Tanks turning it from standard to an Adventure bike.
Here are a couple pictures.
“There are no foreign lands. It is the traveler only who is foreign.”
"Quad Biking in Antarctica"----->http://advrider.com/forums/showthrea...886240&page=10
travelingaustralian is online now   Reply With Quote
Old 12-14-2013, 08:36 PM   #12656
Hoots
Hoots's Avatar
Oddometer: 1,650
No, nothing unusual in the riding post surgery ...
I asked the question here at the time, and someone said that this can happen after the battery is disconnected for a long period ...
To be honest, I don't think they went about removing the shock the easy way - i.e. by lifting up the sub-frame - they took it out from above, having removed the airbox and disconnected the battery - I was a bit surprised when I got back and saw all this stuff on the floor ...
After that, the odometer had reset itself ...
Old 12-14-2013, 08:44 PM   #12657
ktmmitch
Oddometer: 710
What silencer is that fitted?
ktmmitch is online now   Reply With Quote
Old 12-14-2013, 08:55 PM   #12658
travelingaustralian
Globe Trotting
Oddometer: 98
Hi John, Its a Vance and Hines slip on.
Old 12-14-2013, 09:12 PM   #12659
mezcal
mezcal's Avatar
Oddometer: 469
Mine was all back together when I got there. Today while washing it I noticed the silencer clamp had moved slightly making me think the wings pipe was removed, other than that I see no evidence of anything being removed.
I also rode mine twice after Terry did the work on Friday, its only today when I started the bike I noticed the odo on zero. Yesterday it was fine.
I keep blowing bloody headlight globes though.. 5 in 2 years!
2011 Berg 570
Old 12-14-2013, 09:24 PM   #12660
Hoots
Hoots's Avatar
Oddometer: 1,650
Strange coincidence ...
I did tell them quietly that that was not the easy way to take the shock out of a 690 - told them about a few web demos ...
I don't know whether any of this is relevant, or just pure chance ...
Two bikes / identical procedure / two reset odometers ...
Although the lag of a day or so in your case is a bit hard to understand ...
Anyway, be good to know if you discover a way to put the kms back on it - unrealistically low kms are always a disincentive for secondhand bike buyers ...
Times are GMT -7.   It's 10:56 AM.
