Old 12-14-2013, 10:06 PM   #12661
DanTheMan07
Oddometer: 146
Originally Posted by Just_P_Dirty View Post
I am planing to do this soon and i dont have the service man- what torq specs did u use? what did you mean about freeze it and put back in?
thanks
To remove the steering stem from the lower triple you have to pound it out, if you dont have a press. Its a tight fit putting it back in. So i think he put the stem in the freezer to get it to shrink slightly to make it easier to press, or pound back in the lower triple. Mine took significant persuading to remove and put back in place. Didn't try the freezer thing, it might have helped.
DanTheMan07 is offline   Reply With Quote
Old 12-14-2013, 10:25 PM   #12662
Monterey_BS
On or Off - not sure
Monterey_BS's Avatar
Oddometer: 254
Originally Posted by mezcal View Post
Well the bike ran perfectly, aside from one thing.
The odometer reset itself. I unplugged a few things around the battery so I guess that is the reason. Is this something only a dealer can fix, and will the computer know how many km I do after the reset and from before hand?
Sent from my GT-N8010 using Tapatalk
Happened to me at 878mi. Bad battery in my case. Battery replaced under warranty. Dealer offered to send the unit to KTM to be reset to correct values, but it could take several weeks to get it back. They said they were not authorized to make any changes. My solution was to add 878 to the mileage formula in my cost spreadsheet for the bike.
Bob in Monterey
Monterey_BS is offline   Reply With Quote
Old 12-14-2013, 10:30 PM   #12663
AccelRus MaxiMus
Oddometer: 144
Originally Posted by travelingaustralian View Post
Hi John, Its a Vance and Hines slip on.
Ummm... Me thinks you mean Leo Vince ?
The logo on the pipe looks a lot like this one:
http://www.riderforums.com/zr-7-perf...tml#post535732
BTW - like your work area - looks warm and relaxed !!
AccelRus MaxiMus is offline   Reply With Quote
Old 12-14-2013, 11:05 PM   #12664
travelingaustralian
Globe Trotting
travelingaustralian's Avatar
Oddometer: 98
That would be the one! I have know idea why I said Vance and Hines? Probably because I had one on my other bike?
“There are no foreign lands. It is the traveler only who is foreign.”
"Quad Biking in Antarctica"----->http://advrider.com/forums/showthrea...886240&page=10
travelingaustralian is online now   Reply With Quote
Old 12-15-2013, 12:32 AM   #12665
mezcal
mezcal's Avatar
Oddometer: 469
Bugger sounds like an easy fix isn't going to happen.
Ill call the bike shop tomorrow. Thanks for the reply
2011 Berg 570
mezcal is offline   Reply With Quote
Old 12-15-2013, 12:42 AM   #12666
MeinMotorrad
MeinMotorrad's Avatar
Oddometer: 1,577
After buying my new ktm 690R almost 6 months ago while still living and working down in Antarctica, I had a chance to ride it for the first time. Can anyone suggest a good tuner in the Melbourne area? Bike is running like crap! On the Advanced setting it stalls runs rough and dangerous off idle with the bike stalling and locking up the rear wheel. It has had mapping installed to suit the changed exhaust and air intake.
I see you still have the stock snorkel, this is likely where your idling problems are coming from. Take a look throughout the ECU Thread here: http://advrider.com/forums/showthread.php?t=685657. Quite a few mods to the stock snorkel. What filter are you using?
It's worthwhile getting TuneECU (it's free) and the relevant cables, this will let you see what fault codes are being logged by your ecu. I saw when I was editing the quote that you are using a Mac - TuneECU is windows only so you will have to partition your drive and install a version of windows, this means you need an external HD to back up onto. I'd get Win7 if you can, avoid Win8 at all costs.
When you reinstalled the air box how did you route the throttle cables, under or over the front r/h air box mounting bolt? If you've got bar risers fitted this may have put the cables under strain - there are other here with more knowledge than me on that topic though.
Another thought: when you were following the RR instructions did you undo the throttle cables to thread them through the r/h plastic frame guard? Many here, myself included just cut the guard, more quick and simple. Again, TuneECU will tell you of problems here.
'12 KTM 690 Enduro R
MeinMotorrad is offline   Reply With Quote
Old 12-15-2013, 12:51 AM   #12667
ktmmitch
Oddometer: 706
stalling
We have had problems with slow running with Leo Vince fitted, even after using Tuneboy re mapping.
Do you have anyone near with a different silencer to try?
ktmmitch is online now   Reply With Quote
Old 12-15-2013, 12:53 AM   #12668
travelingaustralian
Globe Trotting
Oddometer: 98
MeinMotorrad,
Thanks for the info. The bike is running a K&N filter with the top of the air box drilled to allow extra air into it. I want to change this and fit the open filter box. I ran the cables above the air box r/h mount. I've inverted the throttle body 180deg because I have fitted the bar rasers this gave the extra cable required. I did the same as you and cut the plastic cover to remover it.
Old 12-15-2013, 06:49 AM   #12669
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 3,025
The stem on your bike sounded pretty darned tight. Mine was pretty snug but far from needing to chock it up in the bearing press in order to press it out from the lower triple.
Knowing a better order of removal now that I've done the job I'd get the wheel, forks, fender, bars/clamp off of the bike, loosen but don't remove the large nut on the under side of the lower triple. Remove the pinch bolt and the large steering stem nut and wiggle the top clamp off....while holding the lower triple...... Note the orientation and order the large O-Ring and the dust cup on the top are situated.
The lower triple and stem combo will drop out.
Once I remove the nut on the bottom of the clamp I was fully expecting I'd have to rig up a way to chock the clamp in my arbor press to press the stem out of the lower clamp. Just to see if it would work, I took a dead blow hammer and tapped on the triple to see if the stem would work itself free. It did after a dozen easy taps.
I froze the stem with a cold propellent-driven lubricant which shrunk it just enough it allowed me to fit the stem into place by hand.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is offline   Reply With Quote
Old 12-15-2013, 06:49 AM   #12670
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,199
This looks like an issue with the smaller instrument cluster. I haven't heard of any of the larger units with Tach have the issue.
When I first bought my '09 I tore the bike down leaving the cables unplugged for 2 weeks. Had the same thing happen. It was goofy since it ONLY zeroed the ODO not the tripmeters.
Being as I just bought the bike I had that odo reading written down. It came in kinda handy for me as I run a logbook in the tankbag. All my work started at 0.
Tom-2006 950 Adventure "Big Orange", 2009 690R "Ginger"
My2Wheels
dad2bike is offline   Reply With Quote
Old 12-15-2013, 06:56 AM   #12671
MeinMotorrad
Oddometer: 1,577
390 Duke SM
I know it's off topic but the 390 Duke SM has been spotted which I know will be of interest given the 690 Enduro grew out of the SM.
A lighter, smaller, cheaper endure in the future?
Old 12-15-2013, 06:59 AM   #12672
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,695
They showed the 390/200/125 RC (rocket) at the auto shows this fall. The rumor is that they will make a 390/200/125 sm and enduro in the coming years. Fingers crossed.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 12-15-2013, 07:31 AM   #12673
sdd04
Location: The Ozarks....SW MO, NW AR-great place to play!
Oddometer: 872
Dirty
Are you still happy with the swap-any negatives?
sdd04 is offline   Reply With Quote
Old 12-15-2013, 07:57 AM   #12674
Arzach
never too old...
Arzach's Avatar
Oddometer: 338
Originally Posted by sieg View Post
Dealer called me today.......mid-January shipment.
Then I guess it is time to order rally kit and other goodies
People sail for fun and no one has yet convinced me
that it's more fun to go Slow than it is to go Fast .Dick Newick
Arzach is offline   Reply With Quote
Old 12-15-2013, 09:49 AM   #12675
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,005
Originally Posted by cyborg View Post
That's essentially what I did too (and told Uller about), but started from a full SC seat, a bit of a spendy way to do it. The "log" shape foam just didn't suit me. Renazco is just finishing up mine right now. The SC seat pan is really nice, thicker plastic that seems like black PE and a little flexible, should last a long time.
Welcome back Crank!
Thanks Cliff! So been daydreaming again, which always gets me in trouble... I'm getting my 690 ready for an endurance ice race in January and I was looking at improving the steering a bit. Anyone messed with the geometry at all, or moved the radiator? I have a brand new set of fluiddyne radiators for a 450 RFS bike (longer and thicker). Might also make it easier to add another fan, like the dirt tricks unit. Thoughts?
Just say'IN
crankshaft is offline   Reply With Quote
Times are GMT -7.   It's 06:35 AM.
