Old 12-19-2013, 10:42 AM   #18931
mitchn06
mitchn06's Avatar
Oddometer: 548
[QUOTE=Johann XR650R;23024572]
Originally Posted by mitchn06 View Post
Yip, cleaned carb twice.
Idle screw is ok, she cold starts easily. the trick is after one minute she dies. then i cannot get her re-started.
I guess what you are saying is that she is behaving as if you leaving the choke on then after she heats up she will splutter and die?
I will lower her idling a little tomorrow. to see if that is the issue.
Main 175
Pilot 65S
Hot cam stage 1
aftermarket insert for stock pipe.
Fully uncorked
900m above sea-level
30 degrees C today.
New valves but Valve clearance checked twice and they are in speck.
Thanx for the advice.
pilot is too low. if you have a 68s, put it in, might even need the 70s with the hotter cam in it.
2000 Honda XR650R (Under the Knife) LINK
mitchn06 is online now   Reply With Quote
Old 12-19-2013, 10:52 AM   #18932
Johann XR650R
Older, slower wiser
Oddometer: 22
[QUOTE=mitchn06;23024599]
Cool Thanx for quick reply,
I played around with Jetting today.
I had a half cutout air box( just top triangle) closed it off today and then put 65 back in. she started easier with 65 than 68.
The trick is that today was a "cold" day here it normally goes upto 35-40 degrees C here and then the 68 would be too rich.... i think?
Um so it seams the issue is the same even though i have swopped pilot jets.
PS needle is on forth clip.
fuel screw 2 turns out.
I will tweak the settings a little tomorrow and let you know how she runs.
thanx again for the advice,
Johann XR650R is offline   Reply With Quote
Old 12-19-2013, 04:48 PM   #18933
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,607
Originally Posted by jm-2008 View Post
Here you go -
Make sure the pilot jet is installed screwed all the way in per the instruction above.
Jayrod1318 is offline   Reply With Quote
Old 12-19-2013, 07:42 PM   #18934
1bigrn
Oddometer: 183
XR650R High rise bars. How high?
When I stand up for extended periods I find I have to bend over too far. As a result, Im looking at adding some hi-rise bars to my XR such as ATV bars with a 4.5" rise and perhaps a handlebar riser.
How high can I go before the cables need replacing?
Whats the highest other people are running?
1bigrn is offline   Reply With Quote
Old 12-19-2013, 07:44 PM   #18935
mitchn06
mitchn06's Avatar
Oddometer: 548
I run rox risers 2", they help, but I still need to go higher. I'm 6'4.
Old 12-19-2013, 07:44 PM   #18936
cognugget
cognugget's Avatar
Oddometer: 243
Pastrana fmx with big bar adapters are the tallest you can go without cable extensions. I run these. They are a bit narrow and have almost no pullback. Still a bit crammed but good enough.
Sent from my SCH-I545 using Tapatalk
Plated XR650R
cognugget is offline   Reply With Quote
Old 12-19-2013, 11:56 PM   #18937
jm-2008
jm-2008's Avatar
Oddometer: 501
[QUOTE=Johann XR650R;23024295][QUOTE=mitchn06;22675718]I remember one time after I had the carb completely apart and struggled hardcore to start it. Ended up being idle screw being turned out way too far, even thigh it seemed right. Started at half throttle, the. I knew it was way off. That's all I got for you.
Good day Mitch.
I got the pig started! yeaha. but she then idles for a short while then dies. Could it be that the float level is off? its really freaky. Today i changed back to stock tank. then tried it again. Same story. started on second kick, idles for a about 1min then died. Now i cannot get her started! aarrrggghhh not sure what else to check.
is she maybe running too lean and this then heats her up? not sure 1min would not overheat her....
Mine will run for quite some time with the taps turned off - certainly more than a minute
Put a rag under the carby, take the float bowl cap off (inspect for foreign matter while it's off) and turn on the taps fuel should flow out freely.
If not find out why
If it does its doubtfull a float level issue
JM-2008
jm-2008 is offline   Reply With Quote
Old 12-20-2013, 01:17 AM   #18938
creedyflyr
creedyflyr's Avatar
Oddometer: 228
Rod's Pig
creedyflyr is offline   Reply With Quote
Old 12-20-2013, 02:38 AM   #18939
Johann XR650R
Older, slower wiser
Oddometer: 22
[QUOTE=jm-2008;23029513][QUOTE=Johann XR650R;23024295]
Good day Mitch.
If not find out why
JM-2008
Cool thanx JM
I took carb off again today, checked for obvious airbox boot leaks. cleaned out all breather pipes, cleaned out jets and float needle seat.
I just had lunch, will start her afterwards, it feels like school final exams waiting for report card hoping that you passed. the proof will be a happy leg. i.e. she starts easily.
PS re-checked valve clearances again. was in spec.
Thank you all for advice will let you know shortly ( JM and Mitch) and the rest.
Johann
Old 12-20-2013, 02:44 AM   #18940
Johann XR650R
Older, slower wiser
Oddometer: 22
[QUOTE=creedyflyr;23029633]
Good job.
Well done she looks impressive!
Old 12-20-2013, 02:53 AM   #18941
Johann XR650R
Older, slower wiser
Oddometer: 22
I use Rox raisers the ones that pivot. If you just use std raisers it cramps the cockpit as the bars moves closer to you. you need something that will raise it and move it away from you.
rox-speed-fx-pivoting-handlebar-risers ( need to turn throttle so that the cables enter at the bottum instead of the top, to ensure stock cables reach.
See if can get the dealer to give you a trail run before buying it.
johann
Old 12-20-2013, 03:33 AM   #18942
Johann XR650R
Older, slower wiser
Oddometer: 22
[QUOTE=Johann XR650R;23029741][QUOTE=jm-2008;23029513]
Cool thanx JM
Johann
YOOOYAAA! it worked she starts!
not sure what it was. it may have been the idle screw set to low. or it may have been a clogged breather hose! she runs! seemingly with no hick-ups! and restarts!
I cannot remember when i prayed so much for something to work!
Thank you all for advice!
Hope you all have a good week-end and post many riding pics. and trip reports on monday!
Johann XR650R! WOT!
Old 12-20-2013, 05:35 AM   #18943
mitchn06
mitchn06's Avatar
Oddometer: 548
[QUOTE=Johann XR650R;23029842][QUOTE=Johann XR650R;23029741]
Johann XR650R! WOT!
Awesome. I knew you'd get it! Now get out there and ride!!
Old 12-20-2013, 07:29 AM   #18944
Bench Racer
Oddometer: 80
Originally Posted by cognugget View Post
I have gotten as much as 44 all street mpg.. and as low as 12mpg in the dunes
I run under 2000ft elevation.
175 main
68s pilot
Upgraded needle on 3rd clip
44mpg street
No bog
I would drilling holes in the side panel help? I really don't want to but if helps then I'll do it.
Bench Racer is offline   Reply With Quote
Old 12-20-2013, 07:33 AM   #18945
cognugget
cognugget's Avatar
Oddometer: 243
I don't believe that it's beneficial on a stock motor.
Plated XR650R
Times are GMT -7.   It's 09:38 AM.
