Old 12-29-2013, 09:08 AM   #1
Wyocrawler OP
Wyocrawler's Avatar
Oddometer: 74
DIY panniers for my uly.
I wanted a set of panniers for my new to me 06 xb12x. Being that I am kinda cheap, I couldn't bring myself to pay for the commercially available panniers and racks. After a lot of research I decided to go DIY.
My beast.
Ride it like you almost lost it in the divorce!
Wyocrawler is online now   Reply With Quote
Old 12-29-2013, 09:30 AM   #2
CollinsB
CollinsB's Avatar
Oddometer: 988
Are you referring to the tank bag, or did you fab up panniers, but yet to post pictures?
Brian
BMW 1200GS ADV, KTM 625SXC, KTM 950SE
Yamaha R1, Kawasaki BF V750
CollinsB is offline   Reply With Quote
Old 12-29-2013, 10:03 AM   #3
Wyocrawler OP
Wyocrawler's Avatar
Oddometer: 74
Sorry got interrupted. So I started with some 1/2 inch pipe.
I fabed the hoops using store bought bends and used some scape I had around for the mounting brackets. Once I had those in I made the supports that go behind the passenger pegs and the rear mounts. Finish welded and painted it
Old 12-29-2013, 10:11 AM   #4
Wyocrawler OP
Wyocrawler's Avatar
Oddometer: 74
I was originally going to use 30mm ammo cans for panniers, but a buddy of mine had a bunch of scrape aluminum and offered to make a set. We took the measurements off the 41 litter zenga panniers and away he went.
They turned out pretty nice. Next was the mounting hardware. I used so polyurethane tie rod bushings, fender washes, 1/4 inch bolts and bar stock.
Got the mounts done last night. I am going to start finishing the boxes this week.
Old 12-29-2013, 01:40 PM   #5
Nikolya
Rider
Nikolya's Avatar
Oddometer: 94
It looks amazing!
2010 Moto Guzzi Stelvio
2013 Suzuki V-Strom 650
IBA# 45281
Nikolya is offline   Reply With Quote
Old 12-29-2013, 02:18 PM   #6
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,373
If I may make a suggestion, put the heads on the inside of bottom bolts, or it's gonna hurt your knuckles when you rummage around.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 12-29-2013, 06:23 PM   #7
Wyocrawler OP
Wyocrawler's Avatar
Oddometer: 74
Very true twin. I'm going to get shorter bolts as well.
Old 12-29-2013, 10:07 PM   #8
p0diabl0
Oddometer: 557
Why not just turn the bolts around so that the head is on the inside? And make them button head hex bolts while you're at it - that's what I run on my cases anyways.
Ninja 650R Tourer/Commuter, TW200 Playbike
p0diabl0 is offline   Reply With Quote
Old 12-29-2013, 10:39 PM   #9
paul56
Usually gruntled
Oddometer: 123
Very nice job. Don't try splitting traffic with those, though
paul56 is offline   Reply With Quote
Old 12-29-2013, 10:41 PM   #10
Wyocrawler OP
Wyocrawler's Avatar
Oddometer: 74
Do these panniers make my ass look big? 😜
Old 12-30-2013, 09:46 AM   #11
K7TNT
K7TNT's Avatar
Oddometer: 227
in a good way!
K7TNT is offline   Reply With Quote
Old 12-30-2013, 10:12 AM   #12
CollinsB
CollinsB's Avatar
Oddometer: 988
Look great so far.... nice work!
Brian
Old 12-30-2013, 10:49 AM   #13
woodnbow
woodnbow's Avatar
Oddometer: 1,529
Do these panniers make my ass look big? ��
No idea how big your ass nor that of your pillion is but the panniers should have a slimming affect...
You do know Harley still sells the frames right? Ooops, just re-read your OP.. Ok, this is cheaper, I think you can get the HD frames for $180 from the MoCo. Not 1/2" tube tho', you'll be able to carry pig iron camp stoves on those things!
woodnbow is offline   Reply With Quote
Old 12-30-2013, 11:14 AM   #14
Wyocrawler OP
Wyocrawler's Avatar
Oddometer: 74
I saw the oem harley ones. Honestly I just figured I could do it myself, plus I enjoy it. Gives me something todo after the kids go to bed. The bonus is I'm in the whole project about 100 bucks. The racks cost about $30 for the steel and probably $10 for paint and consumables. I do have the advantage of having a lot of fab tools or accesses to what I need, but a person could do the same with minimal tools.
Old 01-08-2014, 04:19 PM   #15
Wyocrawler OP
Wyocrawler's Avatar
Oddometer: 74
So basically done. When it warms up I'm going to clear coat them.
Times are GMT -7.   It's 05:53 PM.
