Garmin Montana
Discussion in 'Mapping & Navigation' started by AugustFalcon, May 18, 2011.
  1. ER70S-2
    ER70S-2 Long timer
    Sep 30, 2009
    17,156
    SE Denver-ish
    Fred:
    I was calling off topic on ME. Sorry bout the confusion. :shog
    Thanks for the info ever body. :beer
    Ordered, only 6971 in stock. :D
  2. USAIR
    USAIR picking and riding
    May 4, 2008
    1,927
    Northern Kentucky
    I never was good on picking up on this internet sh$t.
    No problem it's all good.
    I get so much help from everyone I just like to jump in when I can.
    Fred
  3. ER70S-2
    ER70S-2 Long timer
    Sep 30, 2009
    17,156
    SE Denver-ish
    I'm good, you're good. :beer
  4. PBrad
    PBrad Paul
    Sep 19, 2013
    204
    Boston, MA
    Is it possible to turn off the notification that the unit is switching to battery power? I'd like to just leave it on. The notification keeps popping up when I drop below 2500 rpm since my stator can't quite handle the power (from other things).
    Sent from my SAMSUNG-SGH-I317 using Tapatalk
  5. DRTBYK
    DRTBYK All Things GPS
    Mar 26, 2003
    8,953
    +47.352263, -121.941609
    No. Run the Montana on internal batteries.
  6. PBrad
    PBrad Paul
    Sep 19, 2013
    204
    Boston, MA
    How long should I expect the internal battery to last on full screen brightness?
    I think I'll just figure something out to prevent the voltage from sagging to the unit. It can't be drawing more than a few watts, shouldn't be hard, just a little time consuming.
  7. DRTBYK
    Mar 26, 2003
    8,953
    You probably won't get more than 2-3hrs with the backlight set to 100%. But, if you're riding during the day, I can't imagine you would need 100% backlight - but then I don't know your riding conditions.
    You're probably heading in the right direction to fix your bikes issues.
  8. PBrad
    PBrad Paul
    Sep 19, 2013
    204
    Boston, MA
    I ride a lot under heavy cover in the woods, so I'm not sure how much I'll see the device in those conditions, especially when it's cloudy outside. I'd also like to minimize my interaction with the device as I don't have a lot of opportunities to take my hands off the bars. I'm riding tomorrow so I'll see how it goes though. I'll probably just leave it powered to the bike unless it gets particularly annoying.
  9. TowPro
    TowPro Single Track Geezer
    Aug 21, 2009
    5,111
    Cow fields of Central Florida
    You could always switch the mount over to run on a larger rechargeable battery.
    Sent from my DROID RAZR HD using Tapatalk
  10. DRRambler
    DRRambler AKA Albertastrom
    Jul 12, 2007
    868
    Vancouver Island
    Hey all,
    I'm having trouble with my 650. a bunch of moisture got into the screen and now the backlight doesn't work at all. I have tried putting it in a bag of rice overnight with no success. I don't want to take it apart with consulting the group wisdom here. It still works but I just can't see it most of the time.
    Of course it craps out in the middle of Bolivia when I need it the most too.
  11. WhicheverAnyWayCan
    WhicheverAnyWayCan Deaf Biker
    Dec 25, 2011
    1,907
    Seven Springs NC
    Hmm.. If I remember correctly, you rode through Mexico hurricane? And what other elements have your 650 went through? I am interested to know what type of expose the 650 went through when you travel south because I am planning similar trip next year.. It would be helpful to know what may cause it to happen. Thanks!
  12. DRTBYK
    Mar 26, 2003
    8,953
    The Montana is not difficult to disassemble if you are comfortable with very small cables and a proper disassembly/assembly order process. But, once you have the unit apart there will be very little you can do if there is a short or burned out component (most likely scenario if the Backlight has failed). If the Montana is working and you rely upon it, I'd leave it alone. In the event you decide to disassemble here is a link to a very good pictorial processes by Hodakaguy...
    I don't believe weather (maybe Hail) will cause damage to the IPX7 seals. Physical damage is more likely: dropping or pushing to hard on the display surface the usual causes.
  13. burmbuster
    burmbuster Long timer
    Oct 16, 2007
    1,958
    South East USA
    Well my Zumo 50 died but after reading this thread I'm not so sure I am ready to dive in to another problematic GPS. Decisions decisions
  14. Rocky TFS
    Rocky TFS Been here awhile
    Apr 16, 2012
    921
    Hailey, Idaho
    You read this WHOLE thread?:rofl
  15. burmbuster
    Oct 16, 2007
    1,958
    South East USA
    I read just about every 25th page. Quite a bit of info and this is probably one of the more helpful threads on the site. I just don't know if I want to deal with the frustration. The Zumo has been good but I would love to have topo and there are others that are better for trails and two track.
  16. junkyardroad
    junkyardroad Been here awhile
    Jan 15, 2009
    318
    Colorado
    First experience with Montana 650 is that ounce for ounce an extra screwdriver or pliers would be more useful. I have not successfully loaded a single map in 8 hours ( never past 12%), have to reinstall the software to download on my HP every time I try( dozens of times), a MacBook Pro is slightly better, but still no map.
    I was unable to get Garmin's software to recognize the s/n, then it finally did without any prompt. I ended up buying City twice since there was no recognition of the transaction being complete.
    No amount of resetting allows it to show 3 gb of memory, no idea why I can't erase the partial 2008 topo that went in early in the effort.
    The list goes on and on.
  17. Emmbeedee
    Emmbeedee Procrastinators
    Mar 19, 2008
    11,564
    Near Ottawa, ON, Canada
    Sounds to me like your real problem is a slow internet connection. The map download from Garmin's server to your computer is generally slow, sometimes taking a few hours to complete and far more if your net connection is slow.
    Re: freeing space on the GPS. Just connect in mass storage mode and remove the old map. Are you using Map source to load maps?
  18. junkyardroad
    Jan 15, 2009
    318
    Colorado
    It loaded after 12 hours. Sorry about the rant, this was so frustrating. Never heard of mass storage mode, how do I do that?
  19. Emmbeedee
    Mar 19, 2008
    11,564
    Glad to hear you're making progress. Rather than explaining it all over again, I should just point out this site with all the information you're likely to need: http://garminmontanagpsr.wikispaces.com/
  20. PBrad
    PBrad Paul
    Sep 19, 2013
    204
    Boston, MA
    So I had my first outing with the Montana this weekend. Saturday, I had it on the dirtbike for 5-6 hours, and sunday a quick 2 hour hike with the dog. I had the back-light off, but despite the heavy cloud cover, rain, and being in the woods a lot, it was way easier to see than I thought. My phone, at the highest brightness, doesn't even compare, and it would have been dead long before the end of the day.
    My only issue is the draw rate of the map. I have it set to fast, but its still really slow. I have about a gig of satellite imagery loaded to the devices uSD card, as well as 24k topo maps on the uSD card (class 10 32 gig). When riding, I was trying to drag around the map to find places to drop pins to navigate to, but it was painfully slow. I'm looking for land marks that can only be found using the satellite imagery. Would moving the satellite images to the devices onboard memory help? FWIW I also had about 25 tracks loaded on the map in that area (they were on the devices built in memory)
    P
