Old 12-11-2013, 09:48 AM   #1
x1valin1x OP
tommy
x1valin1x's Avatar
Oddometer: 88
HELP Dirty Throttle body- Ktm 990 adv r
Hi all-
My friend has a Ktm adventure 990 R and we are in the process of doing some needed maintenance on it. Valves,sparkplugs, fluids etc. the list goes on . I had a question about something that came up. So we took off the airbox, his rear throttle body is all dirty/ oil residue in there. In my 990 when I did maintenance the bodies were both dry and clean. He also told me that the rear spark plug was very wet. Also occasionally his bike would smoke a little bit and backfire. I was thinking his bodies need to be synched? Anyone else have some input?
www.ThomasLiggett.com
07 990 Adv fun. 2010 Husaberg 390fe
1981 cb650 sentimental
x1valin1x is offline   Reply With Quote
Old 12-11-2013, 10:57 AM   #2
bajamcguide
Oddometer: 78
could be tight valves not sealing. how many miles since last valve check?
bajamcguide is offline   Reply With Quote
Old 12-12-2013, 09:38 AM   #3
x1valin1x OP
tommy
x1valin1x's Avatar
Oddometer: 88
23,000 haha I'm not so sure he has ever done them.
Old 12-12-2013, 12:12 PM   #4
Bullskin
Bullskin's Avatar
Oddometer: 65
My rear throttle body (on a 2010) has always had an oily residue at least as long as I can remember. Probably saw it at the first valve check. My bike has 36,000 miles and my valves have never required adjusting. I have never really worried about the oil residue. The bike has always performed flawlessly.
Bullskin is offline   Reply With Quote
Old 12-12-2013, 01:09 PM   #5
Newbusa
Newbusa's Avatar
Oddometer: 605
My 2010R has oil residue on rear throttle body as well and valves in spec.Does not seem to burn oil between changes,I just cleaned it up and re-installed. If it ain't broke don't fix it
2010 990R Adventurer.
2007 Tuono 1000R
Newbusa is offline   Reply With Quote
Old 12-12-2013, 01:35 PM   #6
Themastermike
Passin gas
Themastermike's Avatar
Oddometer: 744
2009R rear throttle body soiled, front clean as a whistle. Figured the fog from the oil breather would dump down the front inlet but doesn't appear to be doing so.
I doubt if it its any thing with tight valves. Just checked mine and all were in spec.
Mine does pop some in town. Runs good on the throttle. Will monitor.
Sent by telepathy
BBF 03-09-13 "It is cool. I was playing dakar racer It truly was a gr8 day of riding you bitch"
Themastermike is online now   Reply With Quote
Old 12-12-2013, 03:32 PM   #7
soupbone
soupbone's Avatar
Oddometer: 139
dirty throttle body
2010R rear throttle body was dirty too. just looked at valves at 12k. all in spec. i figured it was the case breather. runs great with Wings no pop or backfire. still that dang snatchy throttle tho.
soupbone is online now   Reply With Quote
Old 12-12-2013, 05:25 PM   #8
Newbusa
Newbusa's Avatar
Oddometer: 605
I have the Akro pipes and a remap and mine does not have a snatchy throttle.
Remap was done on the Dyno by ECunleashed.
2007 Tuono 1000R
Old 12-15-2013, 08:17 PM   #9
x1valin1x OP
tommy
x1valin1x's Avatar
Oddometer: 88
Measurements taken today
Hi all just an update. Measurements were taken today of gaps and shims and everything was pretty close to being in spec. . Will keep everyone in the loop if we find out anything.
Old 01-13-2014, 12:19 AM   #10
two trackin fool
two trackin fool's Avatar
Oddometer: 1,268
2010
All original
12,500 miles ~ Rear Throttle body dirty . Occasional Pop or miss in left pipe at idle . I haven't made it to the valve covers yet .
My throttle seems to have mellowed OR I am just use to it
Stay Patient and Trust your Journey
two trackin fool screwed with this post 01-13-2014 at 12:25 AM
two trackin fool is offline   Reply With Quote
Old 01-13-2014, 09:05 AM   #11
Katoom72
Katoom72's Avatar
Oddometer: 864
Originally Posted by two trackin fool View Post
2010
All original
i had terrible idle pop out of one pipe on my 950. Turned out to be the carb sync. When i synced them and over did it a bit the other cylinder started to pop badly. When in synced it correctly both cylinders ran perfect on idle.
Sent from my MB526 using Tapatalk
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is offline   Reply With Quote
Old 01-13-2014, 09:49 PM   #12
two trackin fool
Oddometer: 1,268
Is that something I can do with the injection ?
Or do I need to have the dealer do it with the PCM ?
Old 01-13-2014, 10:09 PM   #13
Sumi
Sumi's Avatar
Oddometer: 1,796
You can get an idea about it in this thread:
http://www.advrider.com/forums/showthread.php?t=841503
But IMO first check for vac leaks going on anywere near that throttle body (ports on the intake, rubber boots, TB proper seating), then I'd check the valve clearances (you are into that anyways, aren't you?) And if everything seems to be fine check the TB sync.
If I recall correctly the rear flow sensor*? (is that what it's called?) is also hooked up to that intake (at the vac port), so it can measure intake air flow or whatever - so any leak in this system could also lead to misfiring/backfiring into the TB. So check the connecting hose for any cracks. Don't know how to check though whether the sensor is working correctly - maybe swap it with the front sensor, and see if the problem shifts to the front cylinder?
*Edit: Looked it up in the fische: 61041085100 PRESSURE SENSOR.
I belive the guys who adjust the TB with TuneECU, rely on the values of these sensors, so if you also have a plugin type flow meter / other syncing tool, you can quite rule out if the problem lays somewhere in here. Also to get the job done properly, if you are really willing to dig into the deep, finding out what's going on, adjusting the sync and the TPS, you'd probably need TuneECU (and lots of free time:)). That said, it can be anything different, like the TB not providing enough fuel/shutting off all the fuel on closed throttle because of a failing TPS, or misinformation from one of the sensors (o2, pressure).. I believe it's quite hard to diagnose, so if the simple things don't solve the problem, maybe living with it is easier and cheaper than fixing it trial-by-error.
Sumi screwed with this post 01-13-2014 at 10:39 PM
Old 01-13-2014, 10:18 PM   #14
two trackin fool
Oddometer: 1,268
Yes I am . Throttle body's off today . Porbley won't get back on it till Wed . Thanks ! I will get that done & see how she runs . I'm not easy on her so I would be surprised if the valves spec out good .
Old 01-14-2014, 05:30 AM   #15
Katoom72
Katoom72's Avatar
Oddometer: 864
Yes you can sync the throttle bodies.
But like Sumi said, first make sure there are no leaks of any kind. This is crucial as the sync is pointless when you have airleaks.
Syncing is like putting the cherry on top, the rest of the cake has to be perfect to make it work.
Now:
Before:
Times are GMT -7.   It's 10:00 AM.
