Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 02-06-2014, 10:34 PM   #19306
henryII
henryII's Avatar
Oddometer: 371
Originally Posted by TerryK View Post
Not the best title, I have the flashers / lighting kit that New Bonnie sell but wondering if anyone have improved the lighting performance of the flashers. Here in Australia with our all year round sun they are hard to see. The globe is a 12v 24w & is dull compaired to the OEM & they have a 12v 21w globe.
The flashers from new bonnie have the globe at right angles & no reflector, has anyone polished the inside of the housing or added foil to reflect the light
This is the style of light
A friend put a led bulp in his. Big improvement.
Sent from my SM-N9005 using Tapatalk
________________________________________
[/URL]
henryII is offline   Reply With Quote
Old 02-06-2014, 11:02 PM   #19307
TerryK
Ulysses
Oddometer: 1,659
was thinking about that but was unsure if it would work as the globe is side on, might give it a try
cheers Terry
Triumph Scrambler Blue & White
Triumph Thruxton Red
Yamaha TT-R250
Check out my Youtube channel http://www.youtube.com/user/KaneTerry?feature=mhee
TerryK is online now   Reply With Quote
Old 02-06-2014, 11:11 PM   #19308
henryII
henryII's Avatar
Oddometer: 371
cheers Terry
You can also change the lighthouse with a led version. I did that with My old lucas style on the thruxton.
http://jokermachine.com/products/caf...-assembly.html
[/URL]
Old 02-07-2014, 10:29 AM   #19309
gseur
gseur's Avatar
Oddometer: 271
Originally Posted by Shining View Post
On this web store, for example, yon can see three order options (bonneville, thruxton, scrambler)
http://www.britishracer.com/index.ph...roducts_id=908
Never, never, never order something on this website. All reviews are catastrophic.
There aren't strangers, only friends you haven't ever met.
"You wouldn't understand, it's a Scrambler thing..." :TStorm
gseur is offline   Reply With Quote
Old 02-07-2014, 04:07 PM   #19310
TerryK
Ulysses
Oddometer: 1,659
What slow delivery or non delivery ?
Yamaha TT-R250
Old 02-07-2014, 11:36 PM   #19311
henryII
henryII's Avatar
Oddometer: 371
Well I hope he do deliver, because I have a order placed at his shop :-)
[/URL]
Old 02-08-2014, 12:00 AM   #19312
gseur
gseur's Avatar
Oddometer: 271
Seems that delivery starts when you send your plaint to PayPal.
Old 02-08-2014, 03:27 AM   #19313
TerryK
Ulysses
Oddometer: 1,659
God help anyone that does not use Paypal then, cheers for the heads up
Terry
Yamaha TT-R250
Old 02-08-2014, 10:01 AM   #19314
Mastodon
Mother F'n Dinosaur
Mastodon's Avatar
Oddometer: 661
Originally Posted by IRideASlowBike View Post
I run Gerbings heated jacket liner and Powerlet glove liners at full power no problem. Total is something like 110 watts. I turn the heat down in the city or at lower speeds though just in case.
I forgot I ordered the Gerbings. Just came in yesterday and gave it a try. At first I was questioning if I was even feeling the heat from it, and after about 30 minutes I stopped to investigate. Pulling the heat controller out of my liner pocket, I saw it had the flashing red and green lights, so I reset it. A moment or two later, I started feeling some heat. And then nothing. Looked at controller again, saw the same lights, and reset it again. Stayed on for the ride home, but I was a little disappointed. Maybe I was cold from earlier, or it didn't put out as much heat as I expected, or 37 degrees is too cold? Thoughts?
On the bright side, my new Montana is mounted and works!
Mastodon is offline   Reply With Quote
Old 02-08-2014, 12:39 PM   #19315
devo2002
-Devo
devo2002's Avatar
Oddometer: 3,819
hanguards go a long way in keeping your hands warmer. Either way, 37 degrees isn't too cold for gerbings on high, something may be wrong.
2014 DL650 Vstrom
devo2002 screwed with this post 02-08-2014 at 12:49 PM
devo2002 is offline   Reply With Quote
Old 02-08-2014, 01:07 PM   #19316
RMAK
The Magnanimous
RMAK's Avatar
Oddometer: 331
Well, a seat of the pants report is lots more speed and torque throughout the power band. I have been doing a lot of lightening of the bike as well and I've conservatively dropped 18 pounds or so. It's really a hell of a fun bike to ride now.
Statistics I got are questionable for this reason. Carlos at TPUSA set the flatside carbs for the way I had the bike's upgrades. TPUSA supplied the BB kit and cams. Since I changed from stock pipes with Norm Hyde toga cans to a low Zard, I took it into my local Triumph dealer for a dyno tune.
They called and said I shouldn't be running this type of carb on the street and they had to "detune" the carb to make it run right. They gave the hp rating as 70. Talking to Carlos and a few of my other Triumph buddies confirmed that the dealer was clueless. The bike actually ran slower after the tune up. Everyone who's opinion I trust says the hp and torque should be higher with the work I've done.
I am definitely getting a pieman ignition upgrade in the future. Right now I have my eye on a super light battery and some light fiberglass fenders from PJ's in the UK. I mention this because taking off excess weight makes a big difference too.
I had dreams of a new head with larger valves, but that's another whoppingly expensive upgrade. I may just call it done and enjoy the bike.
Originally Posted by danketchpel View Post
Can you elaborate on the power characteristics with that 904/813 setup? Did you do any head work or remap the timing also?
I am planning to build a 270 crank EFI engine using the 813 cams and possibly the 904 kit with some head work.
I'd like to hear all you can say about your setup.
RMAK is offline   Reply With Quote
Old 02-08-2014, 02:14 PM   #19317
B02S4
Aye
B02S4's Avatar
Oddometer: 1,035
Originally Posted by RMAK View Post
... They gave the hp rating as 70...
Need to see the run data for that number to even be comparable to anything. FWIW, 70 hp (DJ-SAE) can be achieved on a stock head/stock piston 865/270 with CVK carbs.
B02S4 is offline   Reply With Quote
Old 02-08-2014, 04:58 PM   #19318
Bugchewer
Bugchewer's Avatar
Location: WNY hills of Wyoming County, maple syrup & cheese!
Oddometer: 500
has anyone tried the 110/80/17's for the front tire? I want to try the Full Bores but I wondered how the wider front with lower profile handled.
It seems humans would rather die than change or admit that they are mistaken - Richard Rohr
Bugchewer is offline   Reply With Quote
Old 02-08-2014, 04:58 PM   #19319
IRideASlowBike
Oddometer: 1,786
37 is definitely not too cold. With the temperatures we've been having here this winter, I've been riding in 0 Fahrenheit and have stayed warm. I start to feel the heat from the Gerbings jacket liner after about 5-10 seconds. Same with glove liners, although I recently switched to Powerlet glove liners and like them more than my old Gerbings glove liners, which wore through at the fingertips.
I'd check if you have everything hooked up correctly, and if you do, send it to Gerbings for a warranty repair or replacement.
You're wearing it under a regular riding jacket, right? It works best when separated from your skin by one thin layer.
IRideASlowBike is offline   Reply With Quote
Old 02-08-2014, 05:45 PM   #19320
grebmrof
Oddometer: 188
When I was riding this past spring in 36-38f weather the handguards on my Scrambler were pretty ineffective. Heated grips or gloves would be the way to go...I ended up putting my gloved hands into some triple digit rain mitts from Aerostich - that did the trick, hands warmed up quickly. Running a heated vest also helped this situation...
grebmrof is offline   Reply With Quote
Times are GMT -7.   It's 02:53 AM.
