Old 02-15-2014, 11:20 AM   #1
Guano11 OP
Am I Trending?
Guano11's Avatar
Oddometer: 1,398
Ceiling Light Fixtures w/ Switched Outlet: Do They Exist?
I'm unable to find a ceiling light fixture similar to the one pictured below, but has a pull chain controlling the outlet, NOT the bulb receptable itself.
Does such a fixture exist? And if so, where can I get 'em?
Background (if you care....): I acquired a 4-tube T8 flourescent light for the garage. Problem is, it's not switched and I don't want them to come on every time I go into the garage. I want to be able to switch them independently of the ceiling light bulbs and fire up the T8's only when I'm going to spend some time on a project.
Checked my local hardware hangouts and a bit on the 'net, but no luck.
Am hoping the experts here might have some vectors or advice.
Guano11
Time flies like an arrow.
Fruit flies like a banana.
Guano11 is offline   Reply With Quote
Old 02-15-2014, 01:11 PM   #2
broncobowsher
broncobowsher's Avatar
Oddometer: 1,706
I don't think it would be that hard to rewire that outlet/light fixture. Open it up, move 2 wires, done.
broncobowsher is offline   Reply With Quote
Old 02-15-2014, 01:38 PM   #3
Donkey Hotey
De Jo Momma
Donkey Hotey's Avatar
Oddometer: 12,106
Install a screw-in outlet converter to take the place of the bulb. Plug the fixture into the new plug. Done.
Donkey Hotey is offline   Reply With Quote
Old 02-15-2014, 01:56 PM   #4
CrazyTed
CrazyTed's Avatar
Oddometer: 63
Adding pull chain type switches to that type of fluorescent lights is really, really easy. Drill a hole, cut a wire, wire the switch, put it back together.
CrazyTed
Virginia Beach, VA
08 Triumph Rocket III
2010 Husaberg FX450 for sale
CrazyTed is offline   Reply With Quote
Old 02-15-2014, 02:14 PM   #5
rapidoxidationman
Easily trainable
rapidoxidationman's Avatar
Oddometer: 8,742
Why not just install a switched outlet in its own duplex box in the ceiling?
Patrick:
I know I'm feeling badly when I have no interest in speeding
rapidoxidationman is offline   Reply With Quote
Old 02-15-2014, 02:32 PM   #6
trailer Rails
trailer Rails's Avatar
Oddometer: 4,171
X2, those fixture are all open and easily modified. Plus they cost about $1.99
trailer Rails is offline   Reply With Quote
Old 02-15-2014, 02:33 PM   #7
trailer Rails
Oddometer: 4,171
This is probably the better way, just go to the ceiling fan repair area of the home store and buy a switch. If you are using stranded wire, make sure to put a bit of solder on the end so that it will slide into the switch properly.
Old 02-15-2014, 06:32 PM   #8
Guano11 OP
Am I Trending?
Guano11's Avatar
Oddometer: 1,398
That's what I'm gonna do. Wasn't quite that easy in that I had to extend the internal hot wires to reach the switch location.
These cost about $5 at Mom & Pop's:
Good tip.
Hmm, hadn't thought of that; turns out everything's hard wired internally, no "wires" to move:
Guano11
Guano11 screwed with this post 02-15-2014 at 06:42 PM
Old 02-15-2014, 06:43 PM   #9
Guano11 OP
Am I Trending?
Guano11's Avatar
Oddometer: 1,398
Agree Donkey's solution is the easiest, but a bit too KLRish for me....
I will eventually have 3 or 4 of these T8 fixtures; prefer not to wire it like my parent's basement!
Appreciate the tips, fellas!
Guano11
Old 02-15-2014, 06:56 PM   #10
Donkey Hotey
De Jo Momma
Oddometer: 12,106
Hey, I'm not hurt. I didn't know if you thought a flashlight might electrocute you or you lived in a rental or whatever (it's certainly the fastest, cheapest solution). Yeah, the chain switch is an easy addition if you're comfortable doing wiring.
I've got six, twin-tube, 8-foot fixtures and a four footer in a three car garage. It's ALMOST enough.
Times are GMT -7.   It's 10:14 PM.
