Old 02-17-2014, 04:44 AM   #40336
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,125
Originally Posted by dazler View Post
Thanks, so it would need the cage? I dont have it as the K&N dont needed it.
Would the No toil filter cage fit just fine in the WRR that you know
Honestly..don't know for sure.....as I have always just used the stock cage. Notoil cage will probably work fine, but I can not confirm personally.
Sent from my SCH-S738C using Tapatalk 2
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is offline   Reply With Quote
Old 02-17-2014, 05:20 AM   #40337
jgino157
Yer' mom!!!
jgino157's Avatar
Oddometer: 455
Originally Posted by zekester63 View Post
Well, I would never want to do this repair road/trail side. It is a REAL booger to get the thing apart, and that's with having "all" the tools I own at my disposal, a clean bench, good lighting, and no environmental factors making it more difficult than it already is.
That's also assuming you can take the tank off and save the gas in something else so you actually have gas to continue your journey in the event you do get things working again.
With that said, I suppose if your pump craps out on you and you do have a spare, and absolutely no help or transport within any reasonable distance, it might be worth attempting. You really don't have much to lose at that point. But even with my "experience" now doing this, I'm just not sure I could do it trail side, with limited tools.
The first report I saw on these, don't remember where, said it was difficult to take apart he pump without breaking anything (plastic tabs and what not). Just curious how delicate you thought it was.
My thoughts are to take this smaller pump on trips. Cheaper and smaller than a full on pump. The pump usually gives you some warning, so my thoughts would be to swap it out at night in the hotel room with a cold beer. But if its "too delicate" it might be worth bringing the full pump.
'06 Wee-Strom
'08 WR250X with X and R setups
'08 KTM 300xc-w - Plated
Colorado 2012
UPAT 2011 2014
jgino157 is offline   Reply With Quote
Old 02-17-2014, 07:40 AM   #40338
JS5Owner
Oddometer: 4
Originally Posted by philp38 View Post
Been researching rear racks for the WR and like the Cyclerack. I had one on a TW200 and liked how well you could load it. My wife also liked it due to the fact she had hand holds while riding as passenger. It looks like it tucks out of the way on the sides (where it mounts). Any pros or cons? I have to admit it looked better on the TW than the WR.
I just put one on my WR and love it... Yes, the bling factor isn't there BUT the functionality factor is way high. I also have a TW and have one on it and a use a T-Bag that I move from one to the other. I'm now looking at mounting a Rotopax on the left side, hanging down along the tire, kinda matching the exhaust on the other side. I've seen pics here and it looks like it belongs there.
2009 Wr250R all black plastic
- Cycleracks
- Garmin 60csx and 205w
JS5Owner is offline   Reply With Quote
Old 02-17-2014, 07:45 AM   #40339
Earth Rider
Oddometer: 3,025
Which model rack are you guys using? They don't seem to have a WR specific one...
Earth Rider is offline   Reply With Quote
Old 02-17-2014, 08:22 AM   #40340
brothermosley
Motorcycle Operator
brothermosley's Avatar
Oddometer: 624
Fork Rebuild
henrymartin, Thanks for the fork rebuild tutorial! Greatly appreciated!
2008 WR250R
brothermosley is offline   Reply With Quote
Old 02-17-2014, 08:25 AM   #40341
zekester63
zekester63's Avatar
Oddometer: 594
Well the plastic itself isn't "delicate" per se - it's actually very thick. But it becomes delicate due to the amount of force required to get the plastic bent up enough to get over the tabs. There are 3 tabs, and it's all so tight-fitted that it's a real challenge getting them all lifted over the tabs so you can slide it apart. A couple times during the process I was pretty much just hoping something wouldn't just go "snap", and my efforts all be in vain.
Again, I don't know if I could do this trailside, or even in a motel room, with just the tools I carry in my tool roll, but I suppose if I did have a spare, I would attempt it before spending the $ on a new unit, and having to wait on it to arrive. Since my original pump still did work, I suppose I'll carry it with me on trips.
'08 WR250X/R - The Roxy Report The Southeast Utah 1000
'13 V-Strom 650
zekester63 is offline   Reply With Quote
Old 02-17-2014, 08:26 AM   #40342
zekester63
zekester63's Avatar
Oddometer: 594
+1. Great pictures and explanation of the process!
'13 V-Strom 650
Old 02-17-2014, 08:31 AM   #40343
henrymartin
Mr. Tourguide
henrymartin's Avatar
Oddometer: 3,657
No problem guys! Anything else, let me know.
I plan to do the same for the Britannia Lynx install.
Sorry that the pics are too big. I always copy pics from my blog without issues, but the last few post here too large. I tried resizing in "edit post" and it bounces back to the large size again. Something must have changed with ADV site itself.
Anyway, if the post is too large, I can just delete it and leave a link to the blog post.
henrymartin is offline   Reply With Quote
Old 02-17-2014, 08:43 AM   #40344
AdvNener
Oddometer: 42
Thanks for the detailed report !
One question, once there:
Loosen the fork caps on the bike. Once you remove the forks, remove the fork caps completely and turn the forks upside down. When all the oil drains, take out the springs and the little rod in the damper, move damper rod up and down a few times to drain rest of the oil, and set the forks on a bench.
If I were just going to change fork oil... could i just stop here and jump to:
Standing the fork vertically, fill it to the top of inner tube with your fork oil. You have to remove the spring guide and the rod inside the damper for this procedure)
My bike sees very few dust, no sand or mud, so i guess i should change oil someday but that's all...
AdvNener is offline   Reply With Quote
Old 02-17-2014, 10:21 AM   #40345
henrymartin
Mr. Tourguide
Oddometer: 3,657
I think that would work. Just unscrew the cap, remove the spring and the little rod inside the damper, turn it upside down, pump it a few times, and when all the fluid has drained out, move on to the filling part. Nice and easy.
Just make sure the oil reaches the top of the inner tube. Otherwise you will get false reading level. It's always better to remove excess than not have enough.
There are small holes in the inner tube that let the oil seep between the inner/outer tubes.
Old 02-17-2014, 02:54 PM   #40346
dazler
Oddometer: 178
would this one fit the WRR?
http://notoil.shptron.com/p/wr-250-450-2003-2012-3?pp=8
I got that link from No toil when I asked them for a filter for extreme dusty condition for the WRR
WR250X/R
http://www.webbikeworld.com/Motorcyc...-standards.htm
Motorcycle Clothing Safety Standards
dazler is offline   Reply With Quote
Old 02-17-2014, 03:21 PM   #40347
Reeksy
high state of hiatus
Reeksy's Avatar
Oddometer: 1,084
That's what I did ... left them upside down overnight.
Then when filling I cut down a spray bottle to the correct length to remove oil to the correct level.
Reeksy is offline   Reply With Quote
Old 02-17-2014, 04:05 PM   #40348
YZEtc
Feel lucky?
YZEtc's Avatar
Oddometer: 172
Negatory.
That's for a WR-250F or WR-450F from 2003 and on.
YZEtc is offline   Reply With Quote
Old 02-17-2014, 04:52 PM   #40349
johnno
johnno
Oddometer: 52
Air filter for dusty conditions
dazler, i am planning an outback ride for april & may, extremely dusty so i've replaced the K&N with a unifilter foam unit & plan to use filter socks. will also carry the original foam filter preoiled as a quick replacement backup.
johnno is offline   Reply With Quote
Old 02-17-2014, 04:53 PM   #40350
HardWorkingDog
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,743
As noted, not the right part. Like I said before, I'm using the Yamaha OEM air filter--very well made, fits perfectly--with NoToil filter oil and it is holding up very well. I have 2 that I rotate.
Here's a good buy, less than $19 (#8 on the parts list):
http://www.motosport.com/dirtbike/oe...PORT%29/INTAKE
"Coffee first..."
Next Trip: Divide & Conquer...
"it's a dog's life.............and I love it"
HardWorkingDog is offline   Reply With Quote
Times are GMT -7.   It's 02:22 AM.
