Old 02-17-2014, 08:19 AM   #1
No False Enthusiasm OP
a quiet adventurer
No False Enthusiasm's Avatar
Oddometer: 4,753
Key won't turn...
My 2006 Wee has just over 50,000 miles, and it has provided reliable fun.
New problem just developed as the key seems to not unlock the mechanism.
It started binding occasionally so I applied a bit of dry powdered graphite to the key hole. Seemed to improve the situation, but it still balked at times.
Problem has returned....
Any ideas short of ignition lock replacement. Those are a bit expensive.
Thanks,
NFE
No False Enthusiasm is online now   Reply With Quote
Old 02-17-2014, 08:35 AM   #2
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,716
There has to be a way to pull the lock barrel out and clean inspect the parts.Don't know about your bike but most of them have a little hole somewhere...push a pin in there with key in the lock and everything comes out without little springs or tabs flying out.
Graphite...not the best lube for that. And that's according to the very good local locksmith. I asked him if Teflon Dry lube was acceptable and he said go for it.
Have tools, will travel!
Old 02-17-2014, 08:37 AM   #3
a quiet adventurer
Oddometer: 4,753
Thanks for your prompt reply...
I'll spend sometime today following up on your suggestion.
NFE
Old 02-17-2014, 08:49 AM   #4
sieg
sieg's Avatar
Oddometer: 2,855
Is the key worn?
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 02-17-2014, 08:49 AM   #5
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,716
NFE
You can post a pic of the whole switch if you can....on bikes like mine you can remove the "electrical component" part of the switch and also clean/lube that. Just did my bike after following someone else's electrical gremlins. Fiddly but feasable and they even gave me a sticky thread on that over there for the next guy eventually facing problems. Most of the problem with mine was with the steering lock mechanism and no way to see or clean that unless I took the "electrical component" out first.
Steering lock mechanism....lubed with Castrol Chain lube. I think that's acceptable, sure nice and smooth now.
I was getting worried that I wouldn't be able to unlock my steering and that wouldn't be good considering how easy it could be to power on my bike and steal it, I keep the steering locked.
Old 02-17-2014, 09:06 AM   #6
a quiet adventurer
Oddometer: 4,753
I'd bet the key is well worn... my spare key is in a bag at the bottom of a ravine in Colorado. Luckily, me and the bike did not follow...
My problem is with the center mounted switch as opposed to the steering lock.
After working on it, I'll post my outcomes.
NFE
Old 02-17-2014, 11:45 AM   #7
wos
Oddometer: 1,697
flush it out with wd40, use a lot, let it sit for a bit then hit it again. This will get the gum out of the switch and let the tumblers move. But wd40 will gum it up so you have to get it out.
If you use canned air and a rag you will get most out. careful of the eyeballs. The use a contact cleaner or rubbing alcohol to finish cleaning it.
Let it dry then liberally add dry graphite lube. then cycle the key a lot to get the graphite all over.
All my suzukis (x4) have needed cleaning on a fairly regular basis.
wos is offline   Reply With Quote
Old 02-17-2014, 12:30 PM   #8
GH41
Oddometer: 822
As posted above... Do NOT use graphite... Dupont chain lube (Dry lube with teflon) GH
GH41 is offline   Reply With Quote
Old 02-17-2014, 01:04 PM   #9
sieg
sieg's Avatar
Oddometer: 2,855
Hmmmmm.......... my switches rarely ever need cleaning..............maybe 'cause I don't put graphite in them.
Old 02-18-2014, 04:37 PM   #10
a quiet adventurer
Oddometer: 4,753
Thanks to all for their input...
I used the WD-40 splash with the compressed air follow-up. Worked great...
Spent the afternoon riding through the southern end of the county, rousing flocks of Snow Geese with thousands lifting at the same time. What a sight...
This small town does not have one place that has Teflon lub on the shelf.
Next time I go to the big city, I'll have to go to a big box and find some.
Always good to know that a deep bench exists at AdV. Lots of talent available to help with our large and small challenges.
Thanks,
NFE
Old 02-19-2014, 12:39 AM   #11
Pajss
Oddometer: 77
Most all locksmiths will recommend "Triflow" and nothing else.
Kary
2000 Cagiva GC
Pajss is offline   Reply With Quote
Old 02-19-2014, 02:16 AM   #12
Bob_M
Bob_M's Avatar
Oddometer: 161
triflow
Been using Triflow for 20+ years and it works great. You do not need a lot. I use electronics spray cleaner available at Radio Shack or auto parts stores. It evaporates fast and leaves no residue.
Park the bike in the nice hot Texas sunshine then a few air blasts as suggested above. Lube the key and give it the old in and out a few times. Works great.
Bob
1996 Gas Gas JTR270, 2001 Ducati ST4
1977 Honda 750F2, 1970 Honda QA50
Bob_M is offline   Reply With Quote
Times are GMT -7.   It's 04:35 PM.
