Old 02-17-2014, 07:31 AM   #1
gqelements OP
gqelements's Avatar
Oddometer: 179
Aluminum Wrench Sets?
Has anyone have any first hand experience with aluminum wrenches?
After being super impressed by the weight (or lack) of Motion Pro's tire lever set, i'm considering replacing my bike tool-kit wrenches with an aluminium set and curious if anyone has had any experience to share (positive or negative).
One thing that does concern me is whether these will bend from extended use...
http://www.kmart.com/urban-gorilla-t...p-00924056000P
Thanks in advance for the feedback!
gqelements is offline   Reply With Quote
Old 02-17-2014, 07:42 AM   #2
SloMo228
World Class Cheapass
Oddometer: 1,798
Interesting, I've never seen aluminum wrenches before, though I haven't actually searched for them, either. I'd assume the faces of the jaws would deform pretty easily, but maybe that's not the case with these. I'd think that a wrench with steel "jaws" bonded to an aluminum handle would be a good compromise, if anyone makes such a thing.
--------------------------- Steve----------------------------------------
'96 DR350SE
SloMo228 is offline   Reply With Quote
Old 02-17-2014, 07:52 AM   #3
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,118
Those are for aluminum hose end fittings, AN fittings.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 02-17-2014, 07:57 AM   #4
gqelements OP
gqelements's Avatar
Oddometer: 179
Anorak, I'm familiar with the purpose, but curious if they would work for general bike wrenching applications, with intent to shave weight from the road toolkit... Any experience with their durability?
Sent from Windows Phone, using Tapatalk.
Old 02-17-2014, 08:12 AM   #5
vfxdog
Oddometer: 617
Aluminum wrenches will not be capable of dealing with normal steel fasteners, but if you hunt around you will find suppliers of titanium wrenches that will do the job perfectly; tire levers too.
vfxdog is offline   Reply With Quote
Old 02-17-2014, 08:18 AM   #6
gmiguy
You rode a what to where?
Oddometer: 1,311
My experiences with aluminum drive tools generally is that the problem is wear on the surface that contact the fastener rather than bending or other failure of the tool body.
Aluminum in contact with steel nuts and bolts will wear away. This may not be an issue on trailside emergency tools, but should be considered for a tool that sees regular use.
Also, due to the fundamental material properties an aluminum tool will be lighter than a steel tool of equal strength but it will also be bulkier. This may be an issue working in tight spaces.
Some steel wrenches are forged with nice thin bodies and not a lot of excess material. I'd check the cost and weight of some finely made steel wrenches vs these aluminum ones before purchasing anything.
My expectation is that the aluminum wrenches are not worth the cost and functional issues vs steel.
gmiguy is offline   Reply With Quote
Old 02-17-2014, 08:24 AM   #7
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 4,286
The sizes are all in inches, for example the #-4 AN fitting wrench size is 9/16.
Of course you could always go with one of these :
http://www.jegs.com/i/JEGS/555/80625...FdTm7AodsVkArA
I wouldn't, but you seem inclined, so go for it!
"I couldn't wait for success, so I went ahead without it."
Strong Bad is offline   Reply With Quote
Old 02-17-2014, 11:14 AM   #8
KustomizingKid
Oddometer: 678
http://carbonlitetools.com
2000 Xr650r!
KustomizingKid is offline   Reply With Quote
Old 02-17-2014, 12:35 PM   #9
GH41
Oddometer: 822
Originally Posted by KustomizingKid View Post
Those look good but the problem is it is only 5 boxed end wrenches. The rest of your tools still weigh the same thing. Juice not worth the squeeze to me. GH
GH41 is offline   Reply With Quote
Old 02-17-2014, 12:41 PM   #10
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
http://www.motionpro.com/motorcycle/partno/08-0478/
Old 02-17-2014, 12:41 PM   #11
gmiguy
Oddometer: 1,311
They also recommend that you wear gloves whenever you use them to prevent picking up carbon fiber splinters. No thanks.
Based on that, I'd be hesitant to use them around electronics. The last think I want to bring near a PCB is a tool that sheds very fine conductive splinters.
Old 02-17-2014, 02:22 PM   #12
gqelements OP
gqelements's Avatar
Oddometer: 179
Originally Posted by concours View Post
This is likely what i should be looking at. Great tip, thanks!
Thanks for the info and the responses.
Old 02-17-2014, 03:37 PM   #13
MotoDaveL
MotoDaveL's Avatar
Oddometer: 420
those look sweet, guaranteed I would loose one after its first use on the trail.
MotoDaveL is offline   Reply With Quote
Old 02-18-2014, 09:53 PM   #14
gots_a_sol
gots_a_sol's Avatar
Oddometer: 475
I have a set of the Motion Pro Ti wrenches. Super light, but I would like them more if they had some more material around the ends to beef them up a bit.
06 Husky TE610
09 Husky WR165 - VCHSS #79L
gots_a_sol is offline   Reply With Quote
Old 02-18-2014, 10:09 PM   #15
Bayner
Oddometer: 1,599
A friend has a set of these. They're pretty darn light and still functional. Cheaper than Titanium as well.
http://www.levelchrome.com/Asahi-LSX...Set_p_296.html
Bayner is offline   Reply With Quote
Times are GMT -7.   It's 12:11 AM.
