Old 02-16-2014, 10:23 PM   #1141
ArcticaMT6
ArcticaMT6's Avatar
Oddometer: 376
Threw together a quick drawer utensil organizer out of some leftover red oak I had already planed down to 3/8" and 1/4".
ArcticaMT6 is offline   Reply With Quote
Old 02-17-2014, 06:40 AM   #1142
D.T.
Up in this MF'er!
D.T.'s Avatar
Oddometer: 10,670
Cool2
2 post lift FTW!
Man I wan't one of those.
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 02-17-2014, 08:24 AM   #1143
mcma111
mcma111's Avatar
Oddometer: 11,884
Originally Posted by D.T. View Post
2 post lift FTW!
Now you just need the building to put it in.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-17-2014, 05:48 PM   #1144
Import
Import's Avatar
Oddometer: 317
Final drive oil change....prop shaft lube...... Easy money...
Import is offline   Reply With Quote
Old 02-17-2014, 07:09 PM   #1145
ArcticaMT6
ArcticaMT6's Avatar
Oddometer: 376
Nothing much, just an oil change and coolant flush. After that I cleaned the tablesaw top down to just the cast iron. It was pretty nasty before.
Old 02-17-2014, 07:11 PM   #1146
kiwi_outdoors
kiwi_outdoors's Avatar
Oddometer: 107
lights under the workbench
well, 2 days ago, actually
http://www.southbayriders.com/forums/threads/137911/
and a WD40 spray for the chain on my WeeStrom
kiwi_outdoors is offline   Reply With Quote
Old 02-17-2014, 08:48 PM   #1147
Sun Ray
Polyglottic Moran
Sun Ray's Avatar
Oddometer: 967
On my FJR1300, new spark plugs, oil change, final gear oil change and greased splines on shaft, mounted and balanced rear tire. My first time, because I hate giving my money to the stealership.
"The true delight is in the finding out rather than in the knowing." --Isaac Asimov
http://advrider.com/forums/showthread.php?t=936940
Sun Ray is offline   Reply With Quote
Old 02-17-2014, 08:56 PM   #1148
steveWFL
steveWFL's Avatar
Oddometer: 1,344
I took pics of my bike tonight in my garage
stator upgraded, converted to DC rectifier (for heated gear, auxiliary night lighting, fan, etc), radiator thermostat and OEM fan, 6.3 gal acerbis tank, Spot Satellite Locator Gen3, Promoto billet kickstand, "stevewfl" tugger strap, Scott's damper/billet submount, ironman sprockets - 14/49 gear ratio, KTM hardparts skidplate, wired (heated gear, tire pump, USB, GPS, Android), SeatConcepts seat, HDB handguards, mirrors, billet topmount bar with RAM and electrical switches, TM KTM chainguard, grips, headlight upgrade, Giant Loop luggage. I also opened it up and checked valve lash clearances. These silver Excel rims are the "spare" set.
Teressa is trying to turn me into a KTM fan-boi! Some of the Valentine's Day gifts
My usual outtake, the light upfront is ProFoto brand, there is another light hidden behind the bike firing into the wall for the bright contrast in the shots
Its a lame garage that looks like this usually
KTM EXC - in 530 flavor
'10 Concours14 with >85,000 miles and ticking'
'99 ZX9R Ninja - rolling retro style
'99 ZX9R - because I like the other one so much
'08 ZZR600 minty
steveWFL is offline   Reply With Quote
Old 02-17-2014, 09:52 PM   #1149
JimVonBaden OP
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 51,618
Originally Posted by JimVonBaden View Post
In my work sheds I did complete service on 12 MSF motorcycles, plus changed 11 clutch/brake levers, 3 tires, two clutch cables and various minor fixes. Busy 8 hours.
A friend caught a couple photos for me:
JimVonBaden is online now   Reply With Quote
Old 02-18-2014, 06:00 PM   #1150
SilkMoneyLove
SilkMoneyLove's Avatar
Oddometer: 2,034
Just a backrest. I went with a tall one to make the passenger comfy. Fortunately 4 bolts and the tall part comes off.
From this
To this
SilkMoneyLove is offline   Reply With Quote
Old 02-18-2014, 06:01 PM   #1151
MotoDaveL
MotoDaveL's Avatar
Oddometer: 365
rust and general de-nastification of a KLX250 header and muffler. VHT Paint to follow.
MotoDaveL is online now   Reply With Quote
Old 02-18-2014, 06:08 PM   #1152
aterry1067
aterry1067's Avatar
Oddometer: 273
Wired in a 12vt outlet on the wee. Spent over an hour deciding on what would be the best ground. Ran wires for a set of led's. Figured out how I want to wire in my fuse block. Looked for a good accy wire for the relay, and failed. Continue tomorrow.
aterry1067 is offline   Reply With Quote
Old 02-18-2014, 06:54 PM   #1153
D.T.
Up in this MF'er!
D.T.'s Avatar
Oddometer: 10,670
Shoveled a bit of snow, washed off the truck. Brought the Vstrom out and washed it also. Got up to 42 deg F outside today!
Bought a thumb warmer for the sled at fleet farm. Not sure how to stick it to the throttle so I used Ultra Black silicone. 24 hr drying time we will see how it sticks. May have to use small zip ties...
Old 02-18-2014, 07:45 PM   #1154
k-moe
Oddometer: 2,588
Try the hot lead to your horn. It will be on a keyed circuit, and only gets intermittant use.
k-moe is offline   Reply With Quote
Old 02-18-2014, 08:56 PM   #1155
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,373
Took project Stinger off the saw horses and onto the motorcycle jack. Then put the front wheel on and the carbs.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Times are GMT -7.   It's 07:30 AM.
