Old 03-23-2014, 03:55 PM   #22351
luni
Non-artic explorer
luni's Avatar
Oddometer: 1,091
Your bike is better than a stock 2014. The only difference is the different dashboard, electronic cruise control, and electronic suspension. Dashboard is a moot point, it's aesthetic unless is plugs into the electric widgets. You already have cruise control. Electronic adjustable suspension isn't better than a well sorted aftermarket suspension if it gives you another component to fail in the middle of nowhere and is still undersprung.
Put down the parts catalog and go riding.
Honestly I looked at the new 2014s and they had all the shiny gadgets that I was drooling over when the 1190 came out and all the features I wish my 2012 had. Then I seriously looked at the differences between me well farkled 2012 and then new 2014 and the only noteworthy difference was electronic cruise control and like that I was over it.
Save yourself a few thousands bucks and just make a new tool tube or get one of those stupid gremlin bells.
Originally Posted by true grip View Post
I got a feeling the KTM would be like a hot girlfriend so fun to be with just not trust worthy.
luni is offline   Reply With Quote
Old 03-23-2014, 04:09 PM   #22352
avc8130
Oddometer: 1,600
+1k!
ac
avc8130 is offline   Reply With Quote
Old 03-23-2014, 04:29 PM   #22353
Sckill
Sckill's Avatar
Oddometer: 242
I encountered a weird downshifting issue on my s10 today. I went out for a long ride and about 120 miles in, the bike had trouble shifting from 2nd to 1st. No trouble going from 2nd to 3rd, 4th, etc. Only from 2nd to 1st. Riding in 2nd, I would pull the clutch lever all the way, press down on the shifter, and the lever would go down, but the transmission would not shift into 1st. I tried re-engaging the clutch, even giving it some gas, and then try downshifting again, but nothing.
Weird thing is that the problem was inconsistent. One stop light it wouldn't work. 2 minutes later at the next light everything shifts fine. 4 minutes later at the next light again no downshift.
For reference, I only have 1650 miles on my s10, of which I put on the last 700 miles. I didn't abuse the bike at all and mileage is really low for transmission failure.
From a quick search online I saw comments on oil and the shift pivot bolt. Modern oil is modern oil is modern oil, but who knows what the PO put in so I changed that out with a Bosch 3300 filter and Rotella T6. I would prefer an oem filter, but it's Sunday so I'm stuck with whatever is available from the local auto supply store. I haven't taken the s10 off-road yet so the shift pivot bolt was clean, but I wiped it off and relubed anyway.
Took the bike out for a 15 minute shakedown and the problem seems to be resolved and shifting is a bit smoother. If it comes up again, I'm taking it to the dealer and using the extended warranty.
Current: 2012 Yamaha Super Tenere, 2007 Honda CBR600RR
Past: 2006 Honda 919, 2004 Honda 919, 2007 Honda 919, 2008 Suzuki SV650S
Sckill is offline   Reply With Quote
Old 03-23-2014, 04:33 PM   #22354
SPX
Oddometer: 264
FWIW, I have experienced similar to this when oil got old. Do you know for certain that the six hundred mile service, with an oil change, was done?
SPX is offline   Reply With Quote
Old 03-23-2014, 05:28 PM   #22355
ec90t
Oddometer: 232
My first few outings on my new 2013 had me scratching my head about downshifting. I realized that at times, I hadn't allowed the shifter to completely reset (I was still pushing down on it slightly) before attempting to downshift again.
The cure, adjusted the shifter height and all was good.
ec90t is offline   Reply With Quote
Old 03-23-2014, 05:55 PM   #22356
Sckill
Sckill's Avatar
Oddometer: 242
The PO said he did the 600 mile service himself, but I didn't ask if he changed the oil so I'm not certain. Even so, 1650 miles is well below the 4k mile mark for changing oil.
Don't think it's my foot since I usually ride with the ball of my foot on the peg. A couple of times when I couldn't get it to shift, I lifted my foot off the shifter and kicked it down a bit harder. Still no luck then.
Maybe it has more to do with the shifter not completely returning to the neutral position. That's probably why some people reported success when they cleaned the shift pivot bolt.
Old 03-23-2014, 06:28 PM   #22357
SPX
Oddometer: 264
The first oil change is due at 600 miles. That is the one that I'm curious about.
Old 03-23-2014, 07:25 PM   #22358
GrahamD
GrahamD's Avatar
Oddometer: 5,400
That's usually what the problem is. I have never heard of anything more serious.
"It's better to ride a boring bike than push an interesting one" ... Canuman
"I just may as well admit that my other bikes are toast. I don't ride them. Plain and simple. I didn't want this. It wasn't the plan." - snakebitten
GrahamD is offline   Reply With Quote
Old 03-23-2014, 07:27 PM   #22359
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,243
Originally Posted by Thagua View Post
With USD$4000 I can upgrade my Hyper Tenere to the future ... lol
Cheers,
Roberto
Take your wife on a nice trip instead.
pluric is offline   Reply With Quote
Old 03-23-2014, 07:36 PM   #22360
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,468
That's about the same conclusion I arrived at. I also heard from an informal source the some reviewers weren't that crazy about the new electronic suspension, they said (off the record) that even the older style BMW ESA worked better.
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
twinrider is offline   Reply With Quote
Old 03-23-2014, 07:51 PM   #22361
snakebitten
Small Town Hick
Oddometer: 980
I was skeptical of those "wild claims" of fuel range no matter how easy you are on the throttle. Until it was revealed they were Colorado miles. That's entirely believable. I was stunned at the mileage I was getting there.
However, for you folks that actually live at those elevations, man you pay a huge performance price for those extended miles.
However, considering the playground, it's worth it. :)
XT1200Z BIGGEST Dirt Bike in the world
500 EXC Dirtiest Street Bike in the world
snakebitten is offline   Reply With Quote
Old 03-23-2014, 09:30 PM   #22362
dickensheets
smprparatus
Oddometer: 289
Left California (sea level) with 35/32PSI in the tires.
3 days later sitting in a hotel in Durango (7000ft) going over the bike. Found 55PSI in both tires, cold!
Never paid attention to this type of thing before. It was riding very rough. Let a bunch of air out and it was normal again.
I will watch it now doing extreme elevation changes.
Ryan
dickensheets is offline   Reply With Quote
Old 03-24-2014, 12:53 AM   #22363
GrahamD
GrahamD's Avatar
Oddometer: 5,400
Are you sure it's not just your gauge. How does a tire go up in pressure by reducing the outside pressure?
Makes no sense.
Old 03-24-2014, 04:49 AM   #22364
GSteve
GSteve's Avatar
Oddometer: 1,302
Makes no sense.
Here's the explanation. The relatively small volume of motorcycle tires the effect is more dramatic than car or truck tires.
http://www.tirerack.com/tires/tirete...jsp?techid=167
Steve
Little Rock, AR
GSteve is online now   Reply With Quote
Old 03-24-2014, 05:30 AM   #22365
srelegante
srelegante
Oddometer: 238
Tiger owners
I would be interested in input from someone that got off a 955i Tiger, onto a ST.
Drop me a PM if you like.
SE
Enjoy the brotherhood!
srelegante is offline   Reply With Quote
Times are GMT -7.   It's 09:04 PM.
