Old 03-23-2014, 09:31 PM   #4171
DingDangKid
El Lechero
DingDangKid's Avatar
Oddometer: 2,670
I dig the blue front fender, im might need to replace my scuffed up black one.
2006 Tdub
2006 Wee
DingDangKid is offline   Reply With Quote
Old 03-23-2014, 09:33 PM   #4172
DingDangKid
El Lechero
Oddometer: 2,670
http://www.ebay.com/itm/like/370608817176?lpid=82
$80 for shipping?!?!?!
2006 Tdub
2006 Wee
Old 03-24-2014, 04:35 AM   #4173
Paebr332
Oddometer: 1,176
My '91 has started puking oil when I ride. Not sure yet from where it is leaking.
Paebr332 is offline   Reply With Quote
Old 03-24-2014, 05:16 AM   #4174
Hoot Gibson
Oddometer: 296
Originally Posted by DingDangKid View Post
I know it's overseas, but damn....you would think a local/area dealer could find you one.....for a lot less bucks
Hoot Gibson is offline   Reply With Quote
Old 03-24-2014, 06:06 AM   #4175
wayno
wayno's Avatar
Oddometer: 6,796
Originally Posted by Hoot Gibson View Post
Took this one on the new T~Dubs Maiden Ride near my house at the County Fairgrounds...downloaded the photo to my pictures file...then hit copy and on the LINK{in this case I used the link and not the photo button} button provided on the thread post, I hit Paste...and this is how it came out.
RIDE SAFE
wayno is offline   Reply With Quote
Old 03-24-2014, 06:19 AM   #4176
wayno
wayno's Avatar
Oddometer: 6,796
Originally Posted by wayno View Post
As far as i know Vacuum chamber did not have the small spring that set on top of needle and originally pilot was clogged.
When I put it back together no smoke but would not run or start unless 3/4 throttle and no choke. so it in apart again ready for a soak but have to wait on small spring and other parts.
Ok, put the carb back together and bike idled sweet as can be but when you give it throttle it is dead...does not die but there is nothing there and takes forever to rev up esp on the road and in third gear.
It actually ran better except for the long warm up when there was no small spring and Pilot jet clogged.
There is no difference in 1/2 throttle and full unless you want to wait then you can fell it surging and gaining rpm.
Will Sea-Foam/colonic it and ride again and still no worky
New Carb
RIDE SAFE
Old 03-24-2014, 07:30 AM   #4177
billmags
Scoot Jockey
billmags's Avatar
Oddometer: 339
Don't forget to add some sacrificial oil before looking. Good luck.
Bill
DL1000
ZRX1200
TW200
billmags is offline   Reply With Quote
Old 03-24-2014, 08:48 AM   #4178
PAULIBIKER
Oddometer: 301
Anyone close to Iowa looking to sell? If so, PM me.........
THANKS Paul
PAULIBIKER is offline   Reply With Quote
Old 03-24-2014, 10:39 AM   #4179
DingDangKid
El Lechero
Oddometer: 2,670
Don't worry I'm not going to buy it. It just happens to be first google result.
2006 Tdub
2006 Wee
Old 03-24-2014, 11:42 AM   #4180
Wadester
Rides a dirty bike
Wadester's Avatar
Oddometer: 2,070
Here's a search for you:
http://www.bikefinds.com/yamaha-tw200-for-sale
Two roads diverged in a wood, and / I took the one less traveled by, and / now where the hell am I?
This isn't a "you're doing it wrong" topic. (Originally Posted by Human Ills, 7/1/14)
Wadester is offline   Reply With Quote
Old 03-24-2014, 02:41 PM   #4181
DingDangKid
El Lechero
Oddometer: 2,670
I'm good on the TW, already got one and it's enough for me lol. I just like the blue fender and headlight mask. Even though I don't have a stock headlight anymore lol
2006 Tdub
2006 Wee
Old 03-24-2014, 02:48 PM   #4182
Tinker1980
Tinker1980's Avatar
Oddometer: 1,558
I'm kicking around the idea of financing something inexpensive, to try and give my non-existent credit a boost. The TW200 has caught my eye for some time, and it appears Yamaha still makes them, and they are really pretty cheap.
So my questions are these -
How does this bike do on the road? The fat tires might make it handle funny - "1960's Ford truck with posi and no power steering" funny. What kind of top speed can I expect out of it?
I have a DR650 that flatly refuses to overheat. Can I expect the same thing with the TW200?
Every motorcycle seems to have it's issues - the KLR and the doohickey, the first gen EX500 and the flywheel, the DR650 and the neutral switch... What goofy little issues does the TW have?
Last, and this is a weird one - I have a Yamaha raptor 350 with an awesome engine and a chassis that has seen better days. Has anyone swapped the 350cc six speed engine into a TW?
Tinker1980 is offline   Reply With Quote
Old 03-24-2014, 04:09 PM   #4183
DingDangKid
El Lechero
Oddometer: 2,670
My TW tops out at 72mph because of crappy aerodynamics. I've hit it on both flat ground and going down hill but couldn't push it 1mph faster.
On hard roads it's perty agile thanks to its rather short wheel base and gearing. I think it would be an awesome urban assault bike, but I live in the sticks so can't vouch for that aspect. It seems to handle like any other thumper I've ridden on the open road. It's just slow, very slow.
I don't know the exact year ranges but the problems were very limited. A couple model years (93-95ish?) has had cdi problems and then 05-07(I think) had bad base gaskets. They are both easy fixes. My 06 has a leaky base gasket and a little silicone can solve that.
There was a BW350 I don't know how related they are to the TW though.
2006 Tdub
2006 Wee
Old 03-24-2014, 04:46 PM   #4184
NJ-Brett
Brett
Oddometer: 6,589
Its ok on the street, its not helped by the stock front tire, which is a poor tire under any situation.
Its not a good as a dr650 or some other plated bore bikes, it can use some oil and run hot if run hard at higher rpm's, but it does not seem to have a weak spot.
The TW is really good at going through swamps and sand, and up hills, in the snow, all at a moderate pace.
Look at a dr200, a crf250 and an xt250 also, they make better street bikes I think.
NJ-Brett is offline   Reply With Quote
Old 03-24-2014, 06:13 PM   #4185
wayno
wayno's Avatar
Oddometer: 6,796
And my feet touch the ground!
RIDE SAFE
Times are GMT -7.   It's 12:55 AM.
