Old 03-24-2014, 01:36 AM   #8521
prossett
prossett's Avatar
Oddometer: 17
Originally Posted by singletrak View Post
What crash bars did you get? Hepro Pro or Light? Any issues with the install?And lastly where did you get them from?
Singletrak
From Holan.pl - I got the "light" version, came with excellent packing, installation was straightforward and fit perfectly. You will need some muscle to align the two bars where the bolts go through,,but then that tension is useful in keeping everything tight.
2004 KTM 640 Adventure in the UAE - writing out of weekenduae.com
prossett is offline   Reply With Quote
Old 03-24-2014, 09:31 AM   #8522
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,548
hey prosset, where did you order there headlight grill from? My Touratech plastic is getting pretty dull by now.
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is online now   Reply With Quote
Old 03-24-2014, 09:46 AM   #8523
prossett
prossett's Avatar
Oddometer: 17
Same place: www.holan.pl
I looked at the more modern plastic cover, but I decided to go old skool with the metal grille and really happy I did 8) It looks like the old Dakar machines!
Old 03-24-2014, 10:41 AM   #8524
wvrocks
wvrocks's Avatar
Oddometer: 622
I like mine a lot too. I think they look way nicer than the plastic ones. I got lucky and found one here used. Wish the previous owner would have had one on, low beam lens was busted when I bought it.
Never underestimate the power of stupid people in large groups.
wvrocks is offline   Reply With Quote
Old 03-24-2014, 05:50 PM   #8525
singletrak
singletrak's Avatar
Oddometer: 73
When using a standard KTM 21" front wheel (EXC,XC,XC-W..) does your speedometer still work? I am trying to figure where the pick-up is located on the wheel or rotor. I see the sensor located on the fork leg.
Singletrak
singletrak is offline   Reply With Quote
Old 03-24-2014, 06:18 PM   #8526
michael1968
michael1968's Avatar
Oddometer: 833
Singletrak
The magnet is located on the brake rotor on the EXC, there's a hole for in the rotor and it's retained by a circlip. The sensor is on the brake caliper.
Cheers,
Michael
michael1968 is online now   Reply With Quote
Old 03-24-2014, 07:56 PM   #8527
BajaRat
BajaRat's Avatar
Oddometer: 587
Copper Canyon - Had just driven up to the rim from Batopilas
'Charlie' owns the night....
BajaRat is offline   Reply With Quote
Old 03-24-2014, 08:26 PM   #8528
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,764
Singletrak
My 2002 adv reads the rotor bolts.
Old 03-25-2014, 06:15 PM   #8529
Goomicoo
Rubber Cow
Goomicoo's Avatar
Oddometer: 590
Originally Posted by michael1968 View Post
I'd start with the simple stuff first, check your fuses, switch and then connections to your turn signals before worrying about anything else. If it's not them your relay (flasher) may be busted.
We have a winner, it was the relay. Thanks
Started with a Honda 400/4, then a RD400, then...
R65, R1100S, R1100RT, R1150R X 2 , R1150GS, R1150GSA, R90/6, R60/5, R80/7 X 2, R60/2, R50/2, R69s X 3, KTM 625 smc, 525 exc, LC4 640, Duke II,
640 Adv.
Goomicoo is offline   Reply With Quote
Old 03-30-2014, 10:04 AM   #8530
prossett
prossett's Avatar
Oddometer: 17
After testing in the sand dunes - in which the bike was totally at home! - and the resulting video:
http://youtu.be/0TYRjt1pDQM
I've bought a T15 front sprocket to see how that interacts with the stock 42 rear, and if it makes the bike snappier in the sand.
Old 03-30-2014, 12:36 PM   #8531
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,991
When I had my 640A I used to toggle back and forth between a 15 and a 17 along with the 42 rear. I found it perfect for poking around on double track or the 17 on the road.
By flipping the axle spacer around no chain tension adjustment was needed.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is online now   Reply With Quote
Old 03-30-2014, 02:44 PM   #8532
dnrobertson
Big Bike, Slow Rider
Oddometer: 838
A FCR carb would make it snappier in the sand.
David
2005 KTM 640A
2008 Wee-Strom
dnrobertson is offline   Reply With Quote
Old 03-30-2014, 04:28 PM   #8533
mcguyver
mcguyver's Avatar
Oddometer: 1,287
Great Vid mate. I will be visiting Dubai for a few days in June. Is there somewhere that hires bikes and gear, so I could get out in the dunes?
mcguyver is offline   Reply With Quote
Old 03-30-2014, 11:26 PM   #8534
prossett
prossett's Avatar
Oddometer: 17
Thanks guys 8)
Might be hard to rent a motocross bike, but ask here http://www.eaglerider.com/dubai/
Old 04-01-2014, 05:22 PM   #8535
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,548
thank you sir
Beerthief
Times are GMT -7.   It's 05:09 PM.
