Old 03-11-2014, 01:54 PM   #556
Jolly705
Jolly705's Avatar
Oddometer: 2,452
DE is one of my favorite runs as long as it is dry
Originally Posted by wilkinsonk View Post
Best of Luck at Sandy Lane. I had intended to have my bike back together before now, but events have transpired to keep the WR450 in pieces. Maybe Curly Fern, but if not defiantely Delaware!
- Ken
Jolly705 is offline   Reply With Quote
Old 03-11-2014, 11:23 PM   #557
where2next?
Map guy
Oddometer: 218
I have the same bike. few thoughts, Power is insane. I still have the grey wire and the throttle stop in and it wheelies in third gear. More than enough for Baja Sand- maybe too much for Alberta mountain trials.... I have the same tank and it was more than enough for remote baja. the safari tank will cost you in ride-ability on trails. IMHO, I'd rather pack fuel another way when I needed it. These bikes lack a cush drive and are generally not suited to long road miles, small oil capacity, short stroke motor etc... you likely know that already though.
where2next? is offline   Reply With Quote
Old 03-12-2014, 07:39 AM   #558
Jolly705
Jolly705's Avatar
Oddometer: 2,452
I posted this in the other thread but figured I would share, here is my DS/ ADV bike
Just added a FMF and USB/ 12V charger for my GPS (need to test)
Before charger added but with GPS mounted on Touratech
Old 03-12-2014, 04:34 PM   #559
where2next?
Map guy
Oddometer: 218
Ive had this stalling problem before. Where would you suggest re routig the vent hoses to? Im going to do a pre season tear down so it would be a good time to deal with this...
Old 03-13-2014, 08:05 AM   #560
solitary1
Oddometer: 64
i routed mine up past the headstock along with the wiring loom to just behind the trailtech vapor
solitary1 is offline   Reply With Quote
Old 03-17-2014, 08:34 PM   #561
motomike14
Thumper Crusader
motomike14's Avatar
Oddometer: 1,750
The WR has a condition where the front wheel doesn't stay on the ground a whole lot. Oh well.
"The bold adventurer succeeds the best. - Ovid
I drink the koolaid too...just not the orange kind.
motomike14 is offline   Reply With Quote
Old 03-23-2014, 09:29 PM   #562
Farmer Roy
Farmer Roy's Avatar
Oddometer: 377
Australian WR450 long distance dirt riding
WR450 Long Range Desert Weapon
umm G'day
just come back from a 5 day, 3 State, 3300km high speed blast out to Cameron Corner on my WR450
Gunnedah, Narrabri, Pilliga, Walget, Carinda, Bourke, Wanaaring, Tibooburra, the Corner, back along Middle Road to Tibooburra, Broken Hill, Menindee, along the south side of the Darling River to Wilcannia, Tilpa, Louth, Bourke, up to Collerina, Goodooga, Hebel, Dirranbandi, Nindigully, Mungindi, the Watercourse Road to Moree, then back to Gunnedah.
travelled with one other bike, a 650 Transalp
carried everything on bike, fuel, water, swag, food, tools.
sat on 110 - 150 most of the way, big distances 150 on the dirt
bike standard WR with 16 litre Safari ( carried 9l fuel bladder ) & cush sprocket 15 - 45 gearing, and a home made screen upcycled from a plastic 20l chemical drum
carried litre bottle of oil with me, did oil change at Broken Hill
carried clean / oiled airfilter, plus used chux wipes as filter skins
averaged about 17 - 18km/l
Kush sprocket lost all its 'cush' somewhere between Bourke & Wanaaring on Day 1 - 760km, but kept driving metal on metal for the following 2600km of the trip without any issues. I was a bit cautious with it Day 2, but didnt worry about it after that & it got a fair thrashing
luggage was oztrail biker swag, light shoes & fuel bladder strapped onto el cheapo ebay rack at rear
Wolfman E-12 saddlebags, left side carried water, right side toiletries & t shirt / shorts for evening wear
Wolfman tank panniers, left side bike maintainence, oil / airfilter / chain lube etc, right side stove, torch, rum flask etc
Wolfman tank bag carried hat, wallet, wipes, camera, maps etc
Camel back 2 l water, 6 x Back Country Cuisine dehydrated meals, 6 x ziplock bags of rolled oats, dried fruit & milk powder, tea bags, toilet roll, muesli bars
carried a Pit Posse bumbag for tools
Wolfman fender bag on front gaurd with 2 spare tubes
I made the mistake of changing the fuel / ignition mapping back to standard in an effort to improve fuel economy but i dont think it did, & it lost top end power in that high speed sand & powdery conditions. I decided to leave the Power Tuner at home cos I was keeping the packing to a minimum, but next time I think I'll just leave it set on the Aussie Map
Front tyre was the original Bridgestone Gritty E 3 ( something like that ) at 22 psi, it wore well
Rear tyre was a brand new Dunlop 606, 120/90-18 run at a constant 18 psi. Brilliant tyre, gripped well, wore well, with some hot fast running. Instant choice for next rear tyre
No flat tyres
Only mechanical issue apart from the Kush sprocket is the chain slider didnt last & the chain started to chew its way into the swingarm. Found a discarded 20l plastic chemical drum & made a new one out of it, taking some of the drum to make spares. First one didnt work very well, Mark Two made it to Moree, and just slipping a bit more plastic under that one got me back to Gunnedah
Seat was ok untill the last day, when it really started to be an issue. In Moree I sat on the concrete footpath to eat lunch & it was so comfortable, I might replace my seat with a paving stone
when i got home i gave the WR a pat on its headlight & said " good bike "
all in all, an awesome ride on an awesome bike
anyone who says you cant do distance on a WR, or cant 'Adventure' one, well, harden up aye . . . .
love my WR450
Farmer Roy is online now   Reply With Quote
Old 03-23-2014, 11:32 PM   #563
Farmer Roy
Farmer Roy's Avatar
Oddometer: 377
450 Quad bike clutch basket for WR ??
umm, i have heard somewhere that the clutch from a yammie 450 quad bike has some sort of dampener or cushion in it, will fit a WR450 & is an alternative to a cush drive hub
can anyone enlighten me or tell me more?
Old 03-24-2014, 03:59 AM   #564
KGSloan
Oddometer: 113
you are correct - you must also buy the drive gear for the quad (the gear pitch is different than the bike), the part is around $50 - the clutch basket is around $250. I just did this on my 2004 WR450 478cc, YZ Cams, dual sport.
http://partstream.arinet.com/Image?a...Fari-main.html
#1 and #4 in the above diagram and it all bolts right up. this is how Yamaha addressed the transmission shock issue with the added traction in the quad.
yamaha part #
5TG-16111-00-00 PRIMARY DRIVE GEAR
5D3-16150-00-00 PRIMARY DRIVEN GEAR COMP. aka "clutch basket"
KGSloan screwed with this post 03-24-2014 at 04:36 AM
KGSloan is offline   Reply With Quote
Old 03-24-2014, 06:02 AM   #565
Jolly705
Jolly705's Avatar
Oddometer: 2,452
I think we need proof that this trip actually took place with some photos
Old 03-24-2014, 07:39 AM   #566
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 8,693
Yamaha WR450F Adventure Bike
umm G'day
No flat tyres
love my WR450
Which edition of the Kush sprocket fragged? The latest? I tried to order a 45 and they were sold out last week. Saw a report of one that lasted 4000 miles so I thought I would give it a go. Now your report of it failing in 800 kilometers. Jeez.
RTB V- The Texas ADV Rally- Hurry before we fuck this up!
http://www.rollthebonesrally.com/
"If you can't fix it with a hammer you can damn sure teach it a lesson".
slowoldguy is offline   Reply With Quote
Old 03-24-2014, 01:24 PM   #567
MTDuke
MTDuke's Avatar
Oddometer: 369
Good stuff....
Thanks for those two links, good stuff.
I installed the 16l Safari on my 12 wr450f recently. Install was as described in link, easy enough. Although I could not get my fuel pump to seal. The tank itself where pump mates up was not level....even after sanding I had gas leaks. Used some super duper gas tank sealer to remount and left it for a week before putting gas in it. Sealed up nicely and I'm a couple of day rides in without leaks. I have read a number of problems such as mine so be aware.
The info on range is great. I mounted this tank for a 10 day baja dirt trip next month and do not have the riding time until then to get range nailed. Riding position has been fine for me and don't really notice its there. When full, no feeling of extra weight etc.. Of course I am not an extremely aggressive rider so others may have a different experience.
Originally Posted by BygDaddee View Post
Read both links in section 9 of this and see what it doesn't tell you.
http://advrider.com/forums/showpost....&postcount=565
Ride Reports
50 Red Bulls and a Pig on a Rocket
MTDuke is offline   Reply With Quote
Old 03-24-2014, 04:32 PM   #568
Farmer Roy
Farmer Roy's Avatar
Oddometer: 377
dunno which generation Kush mine was, I think it was the latest but maybe there is an update. Havent spoken to them yet.
My sprocket did approx 1000km around home before the trip, it was about 700km into the trip the rubbers failed, so it probably did say 1600km ? I was hoping for at least 5000km. I think the high speed dirt riding over corrugations ( washboard ) and the pulsing effect contibuted to the failure, but thats exactly the situation where i want the dampening for the transmission
will report back when i speak to Mr Kush
cheers
Old 03-24-2014, 04:34 PM   #569
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 8,693
Please do report back. And ask him about availability too if you could.
Old 03-24-2014, 04:56 PM   #570
eRRmmm
Oddometer: 576
yamaha part #
This works for the steel framed motors (thinking of doing it to my 2005 WRF), but did they change the quad engine when they changed the WRF engine in 2007?
If not, the old clutch etc may may well fit the newer engine but the primary drive ratio is different, something to be aware of. If you're running 15:45 on a late model WR, I think you'd need to change to 16:45 with the early primary drive gears, that's if it would fit of course.
Edit: Just checked part numbers at Motosport.com and the 2005 YFZ450 and 2013 YFZ450 quads have the same part numbers for primary driven gear and primary drive gear (same as KGSloan's 2004 part numbers listed above).
Edit again: It looks like there are two models of YFZ450 in the later years, a YFZ450D and a YFZ450R. The YFZ450R appears to have the same primary drive ratio as the later model WRF's (primary drive gear is same part number), while the YFZ450D has the same as the early WRF's.
I'm going to follow this up, as I'd like both the YFZ clutch hub, and the primary drive ratio from the later model WR's...
eRRmmm screwed with this post 03-24-2014 at 05:29 PM
eRRmmm is offline   Reply With Quote
Times are GMT -7.   It's 12:09 AM.
