Old 04-14-2014, 01:29 AM   #3466
atarijedi
Oddometer: 156
Originally Posted by RuggedExposure View Post
This is much more important than knowing your mpg.
If you're searching for the best speed for mpg use a stop watch to time how long it takes to use a specific amount of fuel (.1 or .2 gallons). Most likely your best mpg will be between 2750 and 3000 rpm.
Having an OBD2 connector is great for more than just reading your MPG. Diagnostic codes from the ECU alone is worth it. May no longer need to find a dealer with a MOSS.
atarijedi is offline   Reply With Quote
Old 04-17-2014, 09:22 AM   #3467
RuggedExposure
Now with more rugged
RuggedExposure's Avatar
Oddometer: 1,242
It can read codes, but will it be able to reset them?
The fear and dread of you will fall on all the beasts of the earth
RE Fotowerks
Border Road 100 Border Road Rally Raid
'13 Husky Terra 650, '08 Kawasaki Meanstreak 1600, '95 DR350S
RuggedExposure is offline   Reply With Quote
Old 04-19-2014, 11:53 AM   #3468
pasomonte
Oddometer: 88
Going to the dealer with an under-powered Terra any tips?
I'm headed tomorrow to my dealer (Big D, Woodland Park, CO)for a MOSS session, oil change and check up @ 4K mostly off-road miles. MY bike has always been under-powered compared to my BMW Sertao. If the Beemer puts out 50 ponies the Terra could not be greater than 44 IMHO. I had it on the MOSS at 600 miles,which didn't change anything. The bike feels like it has a potato up the tailpipe and will stall unexpectedly, especially in the first 1/2 hour. It runs much better warm than cold, but overheats rather easily at temps above 90F. I have never checked the air filter. I ride alone and don't encounter much dust. If the air box assembly/design is faulty and has dirt in it, shouldn't that be a warranty issue?
I have a fairly loud metallic clunk in my front end. I and a friend spent two hours trying to diagnose and couldn't find anything askew although we both agree it feels and sounds like a lose head bearing. I also have a slightly scary head shake at 70 MPH. We tightened the head bearing nut about 1/4 turn but no improvement. The action is very smooth.
My question: Can any of you think of any culprits that would make my Terra so hesitant? Any tips on what to ask the dealers mechanic to do or check out? Any clues on the clunk? Mahalo
pasomonte is offline   Reply With Quote
Old 04-20-2014, 02:46 AM   #3469
Nev..
wannabe advrider
Nev..'s Avatar
Oddometer: 248
Is the clunk when the steering turns or when the suspension compresses and then releases? I think every TR650 has a metalic clunk when the front suspension changes direction.
If the bike feels underpowered, might be worth checking the doodah on the throttlebody which controls the throttle cable action is the 43kw version not the 35kw version. The part is stamped with 35kw or 43kw.
'12 DL1000 V-Strom
'13 TR650 Terra
Nev.. is offline   Reply With Quote
Old 04-20-2014, 07:32 AM   #3470
RidingDonkeys
Purveyor of Awesome
RidingDonkeys's Avatar
Location: NC, DC, and various other places around the world
Oddometer: 8,481
That's the only thing I can think of. I've ridden both bikes back to back and the TR has always felt stronger. Could it be that they let a restricted version in to the US?
Sit Stay Ride: The Story of America's Sidecar Dogs
Watch the trailer, spread the word:
www.sidecardogs.com
More info at www.sidecardogs.com
Clinging to sanity, one motorcycle at a time.
RidingDonkeys is offline   Reply With Quote
Old 04-24-2014, 10:24 PM   #3471
pasomonte
Oddometer: 88
still at the dealer
Thanks guys, I took it to the Dealer but they couldn't connect to the MOSS server. Some folks at Husky cafe also thought maybe I had accidentally gotten a power limited model or cable stop. I'll have the tech check that out also. I did not have much dust in my air box, as observed with an inspection camera. There are, I believe, two sounds in the suspension. If I just push the forks down with the FRT brake closed I hear a higher pitched click/clunk type sound. If I drop off into a pot hole I feel a definite metallic clunk.
www.sidecardogs.com
Old 04-30-2014, 10:59 AM   #3472
Whitey1
"Whitebread"
Whitey1's Avatar
Oddometer: 10,129
Add me to the list....
..of cool kids! I just bought mine yesterday @Motohio in Columbus.
Whitey1 is offline   Reply With Quote
Old 04-30-2014, 01:35 PM   #3473
NextAdventre
Oddometer: 33
Enjoy. It's a great bike. Let the darkling begin
NextAdventre is offline   Reply With Quote
Old 04-30-2014, 07:18 PM   #3474
hansi
Teurer Abenteurer
hansi's Avatar
Oddometer: 302
Why would you make it dark ?
2013 Husqvarna TR 650 Terra
Never let your love run cold
hansi is offline   Reply With Quote
Old 04-30-2014, 07:46 PM   #3475
RidingDonkeys
Purveyor of Awesome
Oddometer: 8,481
Well, now that I think about it, I did just that. A whole lot of plasti-dip made my white parts black.
www.sidecardogs.com
Old 05-01-2014, 05:31 AM   #3476
Delnari
Tom
Delnari's Avatar
Oddometer: 84
Drop my TR650 two weekends ago to avoid hitting an ATV with a trailer attached doing a U-Turn on a single width road . Was in medium speed turn in the mountains when there they were right in middle of a blind spot. Ended up with a big swollen ankle and bruise knee as the my leg was trapped under the sliding bike.
10 days later and back riding again, still swollen ankle but about 80% mobile again. The repairs including new red side plus TR650 sticker, headlight shroud, front fender, and right Touratech hand guard. Total cost was under $400 with the Touratech part being the most expensive piece. Halls Cycle hooked me up quickly and the bike was back to new again in 8 days after ordering the parts.
Really appreciate how cheap it is to replace plastic on our bikes. A lot better had it been a BMW version.
Delnari is offline   Reply With Quote
Old 05-02-2014, 08:37 AM   #3477
William42
William42's Avatar
Oddometer: 2,614
Good to hear you are back riding.
Hall's is a good dealer.
Mud is evil
William42 is offline   Reply With Quote
Old 05-02-2014, 08:48 AM   #3478
Aquatic
Aquatic's Avatar
Oddometer: 1,570
Case Saver
You Husky guys might be interested as it will fit the Terra and Strada
http://advrider.com/forums/showpost....83&postcount=2
Aquatic is offline   Reply With Quote
Old 05-02-2014, 08:55 AM   #3479
Rustycage
Oddometer: 3,917
What is a good price for one of these sweeties?
Rustycage is offline   Reply With Quote
Old 05-02-2014, 09:08 AM   #3480
Aquatic
Aquatic's Avatar
Oddometer: 1,570
TBA - Still minor details to cost up
$95 - $100 Aussie excl shipping
Times are GMT -7.   It's 03:08 PM.
