Old 11-05-2013, 08:35 AM   #961
DiabloADV
Semi-Occasional
Oddometer: 2,255
What was the first points-ignition bike to lose the headlight circuit board? I'd really like to wire this without that monstrosity.
1974 R90/6 w/1050 kit. Motor only. Seeking a frame.
1970 R60/5
'91 Bill Holland Steel w/Dura Ace
'01 Z3 3.0 Coupe. The Clownshoe.
DiabloADV is offline   Reply With Quote
Old 11-05-2013, 08:45 AM   #962
Airhead Wrangler OP
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,468
No need to get a harness from a points ignition bike. All the ignition stuff on the electronic ignition bikes is on a separate subharness, if I remember right.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 11-05-2013, 09:01 AM   #963
DiabloADV
Semi-Occasional
Oddometer: 2,255
I have a 1980 R65 main harness (my bike is '74 90/6)...I could adapt that, I guess? My whole front electric routing is modified anyway...nothing stock forward of the tank.
1970 R60/5
DiabloADV screwed with this post 11-05-2013 at 09:07 AM
Old 02-14-2014, 04:04 PM   #964
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,668
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 02-14-2014, 04:24 PM   #965
Airhead Wrangler OP
Adios Mexico
Oddometer: 6,468
Originally Posted by One Less Harley View Post
Still going... Work is sort of on hold. Waiting out the shitty weather. Also, waiting for a paycheck, but nobody seems to give those out unless you work for them. I've had a few months off and got bored and finally started looking for work about 3 weeks ago. There's not that much left to do. Just need to make a front cover for the alternator / ignition, clean up and waterproof my wiring, and make a luggage rack.
Old 04-11-2014, 12:59 AM   #966
b0mb3r
Old Git
b0mb3r's Avatar
Oddometer: 1,840
and ????
White pig
b0mb3r is offline   Reply With Quote
Old 04-11-2014, 11:18 PM   #967
Garthe
ROCKS ARE YOUR FRIENDS...
Garthe's Avatar
Oddometer: 4,360
Taking apart the GS...six months till the frame gets shipped...
Hope all is well Spencer.
Garthe is offline   Reply With Quote
Old 04-12-2014, 01:44 PM   #968
Airhead Wrangler OP
Adios Mexico
Oddometer: 6,468
Originally Posted by b0mb3r View Post
and ????
Still kicking. Unfortunately, I just got a job and start on Monday. My life of leisure is coming to an end for now. The upside is that I got rid of my landlord's car which was taking up half my garage and finally got myself setup well in there. Another trip out to Fubar's shop in the next couple of weeks to make a front cover and she'll be ready for travel. Since it's been nice and dry here the last few days I went on a long ride yesterday afternoon without a front cover. The poor girl had been sitting for a couple of weeks without running. Either my winter mix gas goes bad faster or the mikunis clog up a little more quickly than bings. It was a lengthy cold start for some reason. Gotta check on that.
That's exciting. I'm glad my bike is in rideable condition, but now I'm onto the fine tuning / second-guessing phase trying to get everything right. The 4860 forks continue to be a bitch for stiction. I need to find someone with a KTM wheel and spacers to try them to eliminate that as a possibility. Prutser is tempting me with DRZ forks as well. The rear shock needs to be revalved as the fast compression circuit is way too stiff even when backed all the way out. Slow is just right though. The rear fender needs to be remounted in a better orientation - just doesn't look right as-is. Maybe some taller handlebar risers also. No matter how many items you check off, the list never really gets any shorter.
Airhead Wrangler screwed with this post 04-12-2014 at 01:53 PM
Old 04-12-2014, 02:46 PM   #969
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,154
DRZ!
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 04-12-2014, 04:15 PM   #970
Ras Thurlo
Desert Lion
Ras Thurlo's Avatar
Oddometer: 633
Originally Posted by Stagehand View Post
DRZ!
Ras Thurlo is offline   Reply With Quote
Old 04-19-2014, 11:51 AM   #971
Ras Thurlo
Desert Lion
Ras Thurlo's Avatar
Oddometer: 633
how much work did you do on your 4860s?
At some stage you had mentioned the stiction problem before, but I seem to remember on forks that you had not really overhauled
Old 04-19-2014, 07:46 PM   #972
Airhead Wrangler OP
Adios Mexico
Oddometer: 6,468
I've since given them a complete overhaul. New bushings, seals, wipers, and oil. No discernible difference afterward. The internals were in great shape with no visible wear of any kind. There's definitely some kind of misalignment going on somewhere. I'm guessing the wheel spacers are the culprits. I already replaced the axle and checked it for straightness in v-blocks with dial indicator, I need to check that the axle clamps are nice and smooth inside, then maybe swap in somebody's ktm wheel just to eliminate that possibility also.
Airhead Wrangler screwed with this post 04-19-2014 at 10:40 PM
Old 04-19-2014, 08:42 PM   #973
GrahamM
Oddometer: 388
Took my g/s with 4860's out to some trails today. Front end was great, looks like the spring rate and valving turned out to be just the trick. In the rough stuff I used all but about .75" of travel... Observed by adding a tie wrap to the fork.
Front wheel, brake is all KTM and work great, braking is very responsive for the setup. It is the standard setup used on a typical 450, considering I have the bike as light as possible with small tank and only a solo saddle I think the setup is sufficient. Btw, s meyer seat is more comfortable than my Corbin on the GS 300km so far in a day without a butt problem.
Front tc80... Still getting use to it, a bit of sliding going on in gravel. Also steering is very light, Scott's damper to be installed once a Henderson post arrives, which is now on it's way:)
Back end is not terrible but not great either with the stock shock... After I finish the 570 conversion of the KTM 530 I will start looking for a new rear shock.
Good luck figuring out your wp problem... Enjoying mine so far, would be nice to have the full travel but enjoying it so far with stock geometry.
R's G
'09 KTM 530exc, 570 big bore kit... Sold:(
'10 Husaberg FE450
'81 R80G/S: WP4860 KTM front end, Wilber's 633 rear
'91 R100GS, bumble bee
GrahamM screwed with this post 04-19-2014 at 08:48 PM
GrahamM is online now   Reply With Quote
Old 04-20-2014, 02:23 PM   #974
Ras Thurlo
Desert Lion
Ras Thurlo's Avatar
Oddometer: 633
Am interested to hear what issue is, as 4860s should still run sweet once set up right
Btw are you using a BMW or KTM master cylinder?
Based on how my EXC front brake feels, I suspect that a KTM master cylinder is the way to go
Old 04-20-2014, 03:42 PM   #975
Airhead Wrangler OP
Adios Mexico
Oddometer: 6,468
KTM master cylinder, caliper, and line off a 950 super enduro. No regrets there at all. It's all the brake I'll ever need.
Times are GMT -7.   It's 06:02 PM.
