Old 04-20-2014, 02:41 AM   #16
pizellu OP
Oddometer: 43
Plugs are fine
Checked the plugs, color is a light grey with no carbon.. So i guess the bike is a bit lean? Will change the fuel lines and connectors next week! Hopefully that will fix it!!
pizellu is offline   Reply With Quote
Old 04-20-2014, 10:06 AM   #17
Sniperx
Oddometer: 465
It's probably your plastic connectors. My GSA lobe joint broke during a trip in Death Valley. Fortunately tbarstow was around and he knew exactly what was needed. The other connectors on the side are also weeping....so those are next. Change them out for the metal ones and need think about it again.
Motorcycles are like chlorine for the gene pool. 8/31/2013
Sniperx is offline   Reply With Quote
Old 04-20-2014, 02:46 PM   #18
estlerd
TXRider
estlerd's Avatar
Oddometer: 188
Laugh Fuel Lines
My 01 did the exact same thing. After riding I smelled like gasoline. i found the crimped on connector loose where the upper hose connects to the tank. While riding the wind would catch the seeping fuel & mist it on me. You can reach the down the right side of the tank from the front & touch the ends of the fuel lines. If your fingers smell of gas you found your problem. Simply remove the tank & replace both lines. Discard the crimp on clamps & use proper clamps designed for fuel injection & you will be all set.
Dave in Denton
Current
01 R1150 GS
Former
99 Ducati Monster
97 BWW F650
96 Honda CBR 600
91 GSXR 750
90 Honda CBR1000F
83 Suzuki GS1100E
79 BMW R100RS
77 BMW R75/7
more dirt bikes than I can remember
estlerd is offline   Reply With Quote
Times are GMT -7.   It's 10:05 PM.
