Old 04-29-2014, 12:36 PM   #2791
RichBMW
RichBMW's Avatar
Oddometer: 2,086
Originally Posted by Macroenie View Post
Hey, I warned you didn't I, if I had the material I would have added some like you see in every dutch movie .
BMWJustin is right, it is a HP2 Sport dash, take a look at page #137
I am now lusting over those carbon fiber wheels also pictured on that page but have to climb that steep EUR3150 price tag (+ some EUR for tires and brake rotors).
From what I have read those wheels should add lighter steering (not really needed), improved acceleration (like adding 10bhp) and improved braking. All due to the much lower weight / rotating mass.
Thanks for the link, I might go for that.
I'd also like to fit the BMW LED indicators. Has anyone on here done the conversion?
2015 BMW S1000R Sport
2015 BMW R1200GSAW
RichBMW is offline   Reply With Quote
Old 04-29-2014, 01:07 PM   #2792
Macroenie
Macroenie's Avatar
Oddometer: 206
Added these 10 minutes ago
They are sold here and are much cheaper than the BMW ones.
Macroenie is offline   Reply With Quote
Old 04-30-2014, 07:25 AM   #2793
Macroenie
Macroenie's Avatar
Oddometer: 206
yes, check here
Old 04-30-2014, 11:18 AM   #2794
RichBMW
RichBMW's Avatar
Oddometer: 2,086
yes, check here
Great, thanks.
2015 BMW R1200GSAW
Old 05-01-2014, 07:46 AM   #2795
Macroenie
Macroenie's Avatar
Oddometer: 206
alternative windscreens
Old 05-02-2014, 01:38 AM   #2796
sailer
trained Cirus Bear
sailer's Avatar
Oddometer: 827
after 3 year of looking
I finally own my dream bike.
have a little reading to do to get caught here.
plane on using as track/race bike and Hill climber < pike peak style stuff.
should be a perfect bike for that stuff.
get out and live
sailer screwed with this post 05-02-2014 at 07:59 AM
sailer is offline   Reply With Quote
Old 05-02-2014, 03:09 AM   #2797
GSMarc
GSMarc's Avatar
Oddometer: 1,103
I did and the dealer set the info in the BMSK.
No problems at all
2014 KTM EXC450 6Days
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
2005 HP2E SM Prototype
GSMarc is offline   Reply With Quote
Old 05-02-2014, 06:44 AM   #2798
diranne
Oddometer: 32
No problems at all
I just ordered some inserts from here:
http://www.motorcycleparts-hornig.co...or-panels.html
Australia - BMW HP2 Megamoto
diranne is offline   Reply With Quote
Old 05-02-2014, 08:28 AM   #2799
Macroenie
Macroenie's Avatar
Oddometer: 206
I have those, they work perfectly without any bsmk edit.
Before putting the glass back on make sure they are in working order, you might need to reverse polarity to make them work.
Old 05-02-2014, 10:49 PM   #2800
GSMarc
GSMarc's Avatar
Oddometer: 1,103
I think that the original blinkers are too big, that's why I changed them with the new BMW's ones (on left).
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
GSMarc screwed with this post 05-02-2014 at 10:58 PM
Old 05-03-2014, 11:10 PM   #2801
diranne
Oddometer: 32
Thank you! Good tip! I have got the version for the rear that also adds some red LED for braking.. will see how that goes.
Old 05-04-2014, 07:40 PM   #2802
hillbillypolack
Grumpy Old Goat
hillbillypolack's Avatar
Oddometer: 6,218
Just today changed the dreaded fuel pump. As awkward as the fuel pump & controller are arranged, it was a straightforward repair. Re-using the pump retainer ( part between filter & pump) was a trick but no drilling carving or grinding were necessary. Went back together pretty easy.
I haven't gotten much chance in the last year to get out on 2 wheels but I know I forgot how incredibly special this bike is. I'm still grinning from the freezing ride after getting it together.
I found Jesus. He was behind the sofa the whole time.
1996 M900 2012 GS 2008 Megamoto 2008 S2R
2006 HP2e
hillbillypolack is offline   Reply With Quote
Old 05-04-2014, 09:03 PM   #2803
ViperJustin
Retired HH60G Gunner
ViperJustin's Avatar
Oddometer: 688
I've ridden about 200 miles this year. Sad, I know... I've been busy with school and being a daddy. But just a couple nights ago, I changed out the air filter and drilled out the fuel neck. The MegaMoto truly is an amazing machine.
ViperJustin is offline   Reply With Quote
Old 05-05-2014, 02:48 AM   #2804
hillbillypolack
Grumpy Old Goat
Oddometer: 6,218
If it's any consolation, looking for a house, then moving while being a daddy eclipsed a year and a half of 'normal' riding. This summer looks to be better so far.
Question on oil level in the sight glass. I noticed some oil wetting the bottom of the engine yesterday. Last oil change I added the usual 4l with filter but it read over the top of the red circle in the sight glass. Since I could not locate the source of the oil, I'm assuming it was overfilled and drained approximately 16oz so now the level is midway in the sight glass - when the bike is warmed and on the service stand. Just curious if anyone else had a similar thing happen. Bike runs & sounds normal otherwise.
2006 HP2e
Old 05-08-2014, 09:30 AM   #2805
Marczuri
Marczuri's Avatar
Oddometer: 37
I am sorry. no more production...
I just received a reponce to my query about these.
"I am sorry. no more production
Ghiretti Alessandro
349/6185777"
We could learn a lot from crayons: some are sharp,
are pretty, some are dull, some have weird names,
and all are different colors....
but they all exist very nicely in the same box.
Marczuri is offline   Reply With Quote
Times are GMT -7.   It's 02:20 PM.
