Thread Tools Rating: Thread Rating: 255 votes, 4.93 average. Display Modes
Old 05-07-2014, 04:17 PM   #3376
MrGoldfish
MrGoldfish's Avatar
Oddometer: 504
Originally Posted by Geek View Post
We love all of the Highway Dirtbikes stuff... I've had it on 6 bikes so far.
This story is to be continued.. We are in the process of (hopefully) buying a home that has a "Sprinter Workshop".
If it happens... the project will continue in an enclosed environment that is going to allow me to do a lot of things I wouldn't be able to do otherwise (color change anyone? )
I'm also on the fence between buying another set of BFG AT tires and siping them for more traction or trying the Duratrac Wranglers with siping and studs (the new house is in the mountains at 7800 feet and getting up the driveway is going to be a big issue come winter )
Hopefully I can make it through the summer on what remains of these:
Sweet! I've been missing all the updates on this van.
Currently Owned: 2005 Triumph Tiger 955i
MrGoldfish is offline   Reply With Quote
Old 05-07-2014, 07:57 PM   #3377
James Adams
Misplaced
James Adams's Avatar
Oddometer: 10,020
The Goodyear Wrangler SilentArmor tires are real winter-rated (mountain/snowflake symbol) tires marketed as A/T tires. I have them on my Land Rover and they're quieter and more surefooted than the BFG A/T's that I've had in the past.
James Adams is online now   Reply With Quote
Old 05-08-2014, 11:04 AM   #3378
shores
ElBandido
shores's Avatar
Oddometer: 590
deuce and a half camper
i see your adventure van, and raise you a home made deuce and a half camper van/rv....with gun locker, hot/cold water, you name it.
it's worth the read :)
http://www.militarytrucks.ca/rv_project.htm
shores is online now   Reply With Quote
Old 05-08-2014, 02:16 PM   #3379
catalina38
Contrarian
Oddometer: 1,640
+1 I have them on my 2005 Sprinter Westfalia and with 30k miles they still have half tread depth left.
A mangy man chasing a cautionary tale
Lurking more and posting less
KTM 990R 500EXC
catalina38 is offline   Reply With Quote
Old 05-08-2014, 02:32 PM   #3380
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,677
50K service was performed today.
There is a problem with the EGR again. 30K ago it was the valve itself - this time apparently the chamber after the valve needs cleaning out. It presents itself in a slight off idle stumble/backfire every once in a while. I need to bring it back in next Tuesday for them to warranty repair it. They are also going to take a look at the rust spots on the rear doors and potentially fix that under warranty too.
I had to run up to the house today - here's the picture of the Sprinter's potential new workshop
(there is another 2 car garage and workshop as well off camera right).
Old 05-08-2014, 02:47 PM   #3381
drc42
Rally Dreamer
drc42's Avatar
Oddometer: 1,839
Nice looking place! Looks like that garage door will fit the sprinter? Or is that just an illusion due to the angle?
Also, thanks to the guys with the tire info. Planning on replacing my sprinter tires this week, fronts are worn badly on the outside edges. A smart man would have been rotating them to get even wear. Either way, been wanting something with more mud/snow traction and sounds like those goodyears are just the thing.
Looking like an alignment check is in order as well given the wear.
follow my journey: Dreaming of Dakar
drc42 is offline   Reply With Quote
Old 05-08-2014, 02:51 PM   #3382
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,677
My Sprinter with awning and big tires is about 9'6". The workshop behind the Sprinter has an 11 foot door. There is room inside for a few sprinters :) The garage off camera only has a regular 2-car-sized garage door
BTW, you likely do NOT need an alignment.
Mine wear like that too - I asked about it and they told me that it is normal. The camber of the vehicle is designed in such a way to deal with the side loads of crosswinds and stuff - a byproduct of this is the outsides of the front wheels wear.
There "official solution" is "rotate your tires more".
Old 05-09-2014, 06:42 AM   #3383
drc42
Rally Dreamer
drc42's Avatar
Oddometer: 1,839
I wondered if that might be the case since left and right look like they wore identically.
I have some serious garage envy now.
Sent from my C811 4G using Tapatalk
Old 05-09-2014, 09:16 PM   #3384
neanderthal
globeriding wannabe
neanderthal's Avatar
Oddometer: 1,891
Building an Adventure garage thread now!!!!!
'O=00=O'
BMW 2002. long live the legend
neanderthal is offline   Reply With Quote
Old 05-10-2014, 08:48 AM   #3385
SR75
Oddometer: 92
p.s. The van is going in for its 50K service tomorrow
Curious, how much does MB charge for the 50K service?
SR75 is offline   Reply With Quote
Old 05-10-2014, 08:54 AM   #3386
James Adams
Misplaced
Oddometer: 10,020
$50k?
505 XC-F DUKE 690
Old 05-10-2014, 09:03 AM   #3387
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,677
The full price is something like $470.
I told them not to fill the DEF and not to fill the Washerfluid as I'd just done both.
That reduced the cost to something like $390.
There were a few little things that I also had them do so the total bill ended up being something like $490.
This was the cheaper of the service schedules... it goes on an A -> B -> A -> B schedule
10k = A
20k = B
30k = A
40k = B
50k = A
The B schedule is a few hundred more
Old 05-10-2014, 11:46 AM   #3388
SR75
Oddometer: 92
Thanks, that's cheaper than a Ducati service!
Old 05-11-2014, 06:56 PM   #3389
KrustyKustom
Lets Go....
KrustyKustom's Avatar
Oddometer: 639
My Sprinter tires
No to go tire crazy but I wanted to second the experience wit front tire outside wear, particular to the drivers side. I just replaced my originals on my 2012 model which were the Cotinental Vancos, got 43k out of them to the bitter end. I rotate really like clockwork at 5k. But the camber affect definitely is there.
Replaced with standard fare Michelins LTX MS2. Got three sets on my last sprinter through its life with me and 75 to 77k miles was attainable. My opinion on Sprinters off pavement is they get stuck in wet grass so I avoid it. That is until you are in Moab in back country on a red dirt road....and it starts raining!
Krusty Kustom,
Houston Texas
2013 KTM 500exc
KrustyKustom is offline   Reply With Quote
Old 05-12-2014, 05:14 AM   #3390
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,677
...or snowing
.mobile
Thread Tools
Times are GMT -7.   It's 08:01 PM.
