Old 04-29-2014, 03:28 AM   #1306
Flydream
King of the Atlantic
Flydream's Avatar
Oddometer: 378
+1
Flydream is offline   Reply With Quote
Old 04-30-2014, 06:54 AM   #1307
Just Dan
Bugger, Burnt toast
Just Dan's Avatar
Oddometer: 1,882
Originally Posted by Muruk59 View Post
Where sis you source the rack for your bike from Dan, looking for one myself :-)
Cheers
Greg
The rack i have came from German ebay. http://tinyurl.com/mvrkngnIf If I was going to buy a new rack, I would prefer a rentec one, as it lower than mine. When you put top box on it. My top box is high and way back.
I have only just got back from being on the road and living off W800 for a few weeks.
Goes anywhere a R80gs can go. Surprising easily.
The blingy bits on my W800 have to be useful.
CNC sump guard
Gazi rear shocks with compression and rebound. Plus adjustable ride height
13' kawasaki W800, Yep the twin
13' Skyteam Ace 125 BIG BORE
81' BMW R100 CS
Old bikers don't get old by accident.
Just Dan is offline   Reply With Quote
Old 05-01-2014, 01:11 AM   #1308
Scrivens
Scrivens's Avatar
Oddometer: 553
At Cape Jervis with Ed and Don, Kangaroo Island in the background. Managed to miss the rain for most of the day and did a bit over 300km for the run.
Scrivens is offline   Reply With Quote
Old 05-17-2014, 09:55 AM   #1309
Scrivens
Scrivens's Avatar
Oddometer: 553
I installed an EJK EFI tuner a week or so back, and have done about 500km with it so far. It comes pre-configured with a "Stage 1" setup - basically only an increase in the "acceleration" fuelling - but it can easily be tweaked significantly across "cruise", "acceleration" and "full throttle", plus the rev ranges where the shifts in fuelling take place. It also comes with an O2 sensor plug which sets the O2 rate for the factory EFI unit at a constant value, just like the Xieds on Sportsters.
My W800 currently has no changes apart from modified final baffle tubes but even with the standard setup it makes a noticeable difference. Like the Xieds on my Sportster, it makes idle to 2500rpm running much smoother - the bike will also pull cleanly in top from 1500rpm now (no I don't ride like that, testing only) and the extra bit of fuel does make the acceleration a tad quicker and smoother. So far the fuel usage hasn't changed from the previous tank averages over the same sorts of riding conditions including a couple of hundred km of caning it through the Hills. I bought it with the intention of putting a Staintune or BEET full system on at some point, but installed it on the standard bike first out of curiosity. Around $300 shipped from the USA, takes 10 minutes to install and can be reset to factory specs in seconds or even tuned while riding if you mount the controller panel somewhere accessible.
Old 05-29-2014, 11:35 AM   #1310
Flydream
Flydream's Avatar
Oddometer: 378
New modif.
Remus exhaust
Old 05-29-2014, 11:40 AM   #1311
Flydream
Flydream's Avatar
Oddometer: 378
Small video... db killer out
https://m.youtube.com/watch?v=tD_XuV...ature=youtu.be
Old 05-31-2014, 12:50 PM   #1312
lloydpb
lloydpb's Avatar
Oddometer: 46
Got it!
Collected my 2011 W800 today. Had a great ride back along most of the A272 and really enjoyed it. Great torque, great handling and a pleasure to ride.
A couple of pics below - 1 when I got home with the windshield on it, and one after I had removed the windshield. I will try it without tomorrow, Actually I think I will get the matching bikini cowl - if anyone has one fitted can you let me know what they are like to ride with please?
Lloyd.
lloydpb is offline   Reply With Quote
Old 06-01-2014, 05:27 AM   #1313
Speedo66
Transient
Oddometer: 6,742
Nice bike, looks great.
Why does Japan shun us?
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 06-01-2014, 07:35 AM   #1314
Scrivens
Scrivens's Avatar
Oddometer: 553
Quick update on the EJK tuner. I have put around 1000km with it on the bike now and the tuner is worth the money in my opinion. It has made no difference to the fuel economy and in fact it might be slightly better; 72mpg (Imperial) on a recent whole-tank country road run, mid 60's in town. I have knocked the acceleration setting back to 4.5 from 5.5 (as shipped pre-configured for the bike, 3 is stock W800) as I felt it was a bit rich under 4500rpm. As mentioned before the O2 sensor plug has made the low end a lot smoother and cleaner and the extra fuel under throttle does make for quicker pickup and the bike feels a lot livelier. No odd side effects have come up, fuelling appears perfect, idle and starting is just as before although the annoyingly lengthy time the cold start auto fast-idle runs for does seem to be significantly shortened.
And greetings to you Lloyd. You'll love the bike, a lot of fun, a "real bike" and they are very robust. Met another w800 rider at the tyre shop the other day with over 80,000km on his (hi Bart, we'll get to KI one day.)
Scrivens screwed with this post 06-01-2014 at 09:32 AM Reason: typo
Old 06-01-2014, 08:54 AM   #1315
folmonty
folmonty's Avatar
Oddometer: 282
Adv w
To Just Dan, you're a true ADV Rider!
PS - that sump guard is a nice bit of work. The oil filter actually fits underneath it? Kaw should design the W into a scrambler model IMO.
Monty
Nor CA
TS, XLH, GT500
R5, RD (x's3),W, ZRX
R100GS, GSA, KLR
folmonty is offline   Reply With Quote
Old 06-02-2014, 01:03 PM   #1316
drcooke
Oddometer: 11
Originally Posted by Flydream View Post
My new modif.
Same as the original...
Hi, 1st of all, I am a newcomer. I've owned a 2011 W800 for 3 yrs now, but dd not put many miles on it. Now I have decided to make some mods and already ordered front and rear fenders and those badges. They seem to be fully flat, how did you stick them on? did you need to bend them beforehand?
Next step will be saddle, front light and tank paint. Exhaust just at the end of the process.
Well, thanks for any input and happy to have found the group
https://flic.kr/p/9m66Kt
https://flic.kr/p/9m9jt1
https://flic.kr/p/9m6kft
drcooke is offline   Reply With Quote
Old 06-03-2014, 09:27 AM   #1317
Flydream
Flydream's Avatar
Oddometer: 378
Welcome to our small group
I use this product ...
http://www.archiproducts.com/en/prod...el-italia.html
That's a kind of glue+silicone+rubber, all together.
Yes, they are very easy to bend , but go slowly ...
Good luck with your mods and keep sending pics
Flydream screwed with this post 06-03-2014 at 09:32 AM
Old 06-03-2014, 09:36 AM   #1318
Teckel
As If I Care
Teckel's Avatar
Oddometer: 3,434
We are not worthy.
During the time the w650 was here, sales were so poor the bikes sat on sales floors for years and finally had to sell at cost or just slightly above. I bought mine as a leftover which had sat on the dealer's floor for 2 years. It was costing them money to sit there every month so I got it at a bargain.
I think kawasaki got butt hurt by this and decided we weren't gonna get the shiny new toy.
But you knew this already, right?
Teckel is offline   Reply With Quote
Old 06-03-2014, 12:35 PM   #1319
drcooke
Oddometer: 11
WoW!! you even added some fake (I gess) screws! Good Idea, I'll copy that if you allow....
Old 06-03-2014, 12:45 PM   #1320
Flydream
Flydream's Avatar
Oddometer: 378
Times are GMT -7.   It's 12:35 AM.
