Old 07-13-2014, 01:10 AM   #256
jaumev OP
jaumev's Avatar
Oddometer: 1,511
I have the Akrapovic again: http://traildreamer.com/en/akrapovic-otra-vez/
Bikes, trips and farkling at http://traildreamer.com/
Yamaha Super Ténéré off road modifications: http://advrider.com/forums/showthread.php?t=797977
jaumev is offline   Reply With Quote
Old 07-13-2014, 02:38 AM   #257
motorrat
Oddometer: 94
Even better looks then the carbon version!
The heatshield is from Akra?
motorrat screwed with this post 07-13-2014 at 06:44 AM
motorrat is offline   Reply With Quote
Old 07-13-2014, 06:31 AM   #258
jaumev OP
jaumev's Avatar
Oddometer: 1,511
Yes I really like it in titanium.
If you mean the shield in the pipe it comes from ACD. The same people that build the sump guard for my Super Tenere.
Old 07-14-2014, 07:57 AM   #259
mathewst
Oddometer: 8
Shield have close to zero function :) its shielding thick steel pipe.
Got the same exhaust (titanium/carbon akrap), nice mounting plate btw (its custom I assume). For me its yet to find possibitities for second clamp (got it home, but im lazy for mounting it now).
Have you changed springs in the fork from YZ?
What about rear suspension have you checked OTR? Is it 240, is that max?
mathewst is offline   Reply With Quote
Old 07-14-2014, 02:36 PM   #260
Flat_Out
Oddometer: 14
Yes!!
Really cool videos, you run really fast. Good result?
In fact the pilot is a crazy guy and is name is Jorge Baleizăo, i believe he won the class.
Flat_Out is offline   Reply With Quote
Old 07-15-2014, 11:13 AM   #261
jaumev OP
jaumev's Avatar
Oddometer: 1,511
The shield does have a function: it prevent to burn the straps of my Giant Loop saddlebag.
I add a second clamp as the OTR system is in the end of the exhaust. Two look stronger.
Yes my dealer put the sharder springs he can find.
No I didn't check the rear suspension from OTR, I am too busy this days
Old 07-15-2014, 11:15 AM   #262
jaumev OP
jaumev's Avatar
Oddometer: 1,511
He can be crazy but he runs really fast!!
Old 07-17-2014, 03:51 PM   #263
mathewst
Oddometer: 8
steel gets hot pretty fast, i can hardly imagine it has any heat shield capability :-O
im getting done, I have checked OTR about rear suspension, but these days they can hardly answer easy installation and delivery questions. Thorsten from then states actually ohlisn is having 15-20mm less travel than stock shock. But that makes zero sense bcs spring is 5 cm longer on ohlins. god knows
they forgot to setup my front fork as well so travel is random 26-31.5, lets guess.
My build is almost finish, see :)
Old 07-17-2014, 11:01 PM   #264
jaumev OP
jaumev's Avatar
Oddometer: 1,511
I know but because the shield is a bit separate from the pipe it reduce the temperature enough to not to burn the strapes.
I don't understand the shock thing...
Your bike looks great!!... except the seat..
I hate the two levels in it
Old 07-18-2014, 03:42 AM   #265
mathewst
Oddometer: 8
its kahedo lowered one. -3cm, count find anything else lowered
seat height on mine is 97cm, would be 100cm with standard one.
Old 08-21-2014, 02:08 PM   #266
The_Italian
The_Italian's Avatar
Oddometer: 12
Question
Jaume, could the rear handles be removed ?
Did you weigh the bike recently ?
thanks
The_Italian is offline   Reply With Quote
Old 08-21-2014, 02:13 PM   #267
jaumev OP
jaumev's Avatar
Oddometer: 1,511
thanks
Yes, they are the OEM luggage racks, no problem to be removed (just two bolts)
This is the weigh aprox.
- 199,8 kg full
- 181,6 kg empty
Here it is how I did it: http://traildreamer.com/en/peso-de-l...-traildreamer/
Old 08-21-2014, 03:41 PM   #268
Rockhopper Doe
Rockhopper Doe's Avatar
Oddometer: 467
Jaume, where did you get your decals/stickers done? Do these folks take custom orders?
Rockhopper Doe is offline   Reply With Quote
Old 08-22-2014, 12:48 AM   #269
jaumev OP
jaumev's Avatar
Oddometer: 1,511
You can find my stickers here: http://www.motosausio.com/ecommerce/...0-Traildreamer
This is the factory that produce them: http://www.uniracing.es/en/
Yes they take custom orders. Call Alex: alex@uniracing.es
They are very thick and protect the paint incredibly well. I am very pleased with them.
Old 08-22-2014, 03:37 AM   #270
Rockhopper Doe
Oddometer: 467
Thank you! I've emailed Alex.
I've been trying to find that video you had when Uniracing was placing the adhesives on your bike, but I've been unable to find it. Do you know where I can find it?
Tiger 800XC stuff for sale!
Currently needing/buying for a 2014 Super Tenere: Sargent Seat.
Rockhopper Doe screwed with this post 08-22-2014 at 04:22 AM
Times are GMT -7.   It's 01:18 AM.
