02-16-2006, 04:44 PM
#1 |
Guatemalan Import
I see that some of you guys are posting gpx files with waypoints for Garmin GPS's, but after dowloading them I haven't been able to open them with my Garmin software.
I'm no geek here, so bear with me, I'm all
Quique BMW R1200GS BMW R1100S Visit www.motoaventuras.net 'A good traveler has no fixed plans and is not intent upon arriving.' - Lao Tzu |
02-16-2006, 05:56 PM
#2 |
GPX files
[quote=Quetzal01]I see that some of you guys are posting gpx files with waypoints for Garmin GPS's, but after dowloading them I haven't been able to open them with my Garmin software.
I use LOC2WPT to convert .loc, .gpx or .csv files to be compatable with Garmins Mapsource. This freeware is available at the following link: http://homepage.ntlworld.com/mdipol/gps/
What I hear, I forget. What I see, I remember. What I do, I understand. ~ Chinese Proverb |
02-17-2006, 12:11 PM
#3 |
Guatemalan Import
02-18-2006, 01:08 PM
#4 |
El Adventurero Solitario
Oddometer: 3,047
Did it work Quetzal? My Garmin software opens GPX files with no problem. I use Mapsource 6.9.1, CityNavigator v7.
eap '01 R1150GS, Chesapeake Bay Watershed, Surf Your Watershed Save the Bewbies "Over the Mountains Of the Moon, Down the Valley of the Shadow, Ride, boldly ride," -From 'Eldorado', Edgar Allen Poe (1849) http://www.eapoe.org/works/poems/eldrdoa.htm |
02-19-2006, 05:35 PM
#5 |
Worked right from Mapsource
All I had to do when I clicked on Open was change the file type from the default type to the GPX extension. The file opened straight up.
Not that I'll be driving from Knoxville, TN to Daytona any time soon but now I know I can grab GPX files if I want to.
Andy "MakMan" 2006 BMW R1200GS For Sale!!! 2005 BMW R1200GS (RIP 10/20/2005) ![]() 2003 Yamaha VStar Classic 650 (traded) 1989 Yamaha Virago 1100 (sold long time ago) 19?? Kawasaki 454 LTD (long, long gone) |
05-10-2006, 06:51 AM
#6 |
Oddometer: 384
GDB file conversion to Lowrance ??
I have found a lot of conversion software but none that would converts these gdb
files to the correct ones for my Baja 480C ?? any suggestions??
06-21-2011, 12:55 PM
#7 |
Oddometer: 2
A great way to visualize gpx tracks (even in 3D!) is this online service:
http://www.maplorer.com/view_gpx_3D.html |
06-21-2011, 07:40 PM
#8 | |
Wannabe
Oddometer: 1,242
2008 Suzuki DRZ400S |
06-21-2011, 09:16 PM
#9 |
Osons
Oddometer: 668
As a general comment, all .gpx files are not created equal. The .gpx standard is apparently not as standard as many would hope. We have found, for example, that not all shapefiles converted to .gpx can be opened by MapSource - they just fail. But if you use something like DNR Garmin to load the troublesome shapefile into the GPS as a .gpx file, then download that same .gpx file that MapSource wouldn't open standalone into MapSource... then MapSource sees it fine and can work with it.
It often has to do with headers and extraneous characters. But the bottom line is that not all .gpx files are created equal. Some won't open and it isn't because you're doing anything wrong. |
06-22-2011, 05:29 AM
#10 |
Wannabe
Oddometer: 1,242
If you or the original poster can identify the differences (or send an example of a file that doesn't open), I'd be happy to write an app/script to massage the XML output in such a way that it'd be compatible with MapSource.
06-22-2011, 09:36 AM
#11 | |
Osons
Oddometer: 668
I don't think I have any of the troublesome .gpx files anymore, but I think I can remember the project those shapefiles came from. Some GIS guys in the modelling and customization end of things (think: coders) were explaining where the errors were usually found that caused MapSource to choke. Their solution, if I remember correctly, involved stripping out the Jäger screwed with this post 06-23-2011 at 04:22 PM Reason: Formatting made tag names disappear |
06-22-2011, 12:44 PM
#12 |
Wannabe
Oddometer: 1,242
I work with XML almost everyday as part of my job, so it's nothing for me to write some code to remove tags/attributes/elements that are causing problems.
06-22-2011, 06:49 PM
#13 | |
Oddometer: 3,982
You should not have to "download", just double click file, then choose "open" with Mapsource straight off the internet. If you like it then click "save as" and save it as .gdp, with name you like, in place you like. Is your PC set to use Mapsource as default program for .gpx?
Jerry Counts |
08-26-2012, 06:52 AM
#14 | |
Oddometer: 2
I totally agree, the formats are often different for different softwares producing the gpx files. The web site I mentioned above ( http://maplorer.com/view_gpx.html ) does a pretty good job parsing different variants.
Of course it won't catch all possibilities, either, but you should give it a try. Quote:
